Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > PolarBox 3
Old 09-13-2009, 04:45   #1 (permalink)
aslam870's Avatar
Member: 383033
Sonork: 100.1580642
Thanks Meter: 441
Smile Samsung GT-S5600 ERROR Phone Not Readed... [SOLVED]
A few minutes ago I try to Unlock one piece of S5600 but I canīt connect it with Polar. Try in all possible way but always an ERROR message.
1. Without check New Security Tab
2. Checking New Security Tab
3. It havīnt Personal Lock Code
Maybe Drivers error????
Or I need use the last update????
Any answer????
Thanks like always Polar Team.
Best Regards.................aslam870
Old 09-13-2009, 04:53   #2 (permalink)
y3kt's Avatar
Member: 238127
Sonork: 100.1574867
Thanks Meter: 3,526
Try with latest version, (2.2.5) i read something was fixed in it, luck
The Following User Says Thank You to y3kt For This Useful Post:
Old 09-13-2009, 04:54   #3 (permalink)
The_Gorr's Avatar
Member: 145648
Sonork: 100.100487 The_Gorr
Thanks Meter: 23,034
u using old update
last one is 2.2.5
use last update and post report
PS: i forget to tell u that u have to use only drivers from support area, if u have other drivers installed in ur computer, plz remove, restart pc, install those u download from support.
this should work 100%
waiting ur report
br
<= The_Gorr =>
The Following User Says Thank You to The_Gorr For This Useful Post:
Old 09-13-2009, 10:24   #4 (permalink)
Member: 71492
Thanks Meter: 119
Hi
Remember put you phone in qualcom mode
Regards
^FiStrO^
Old 09-13-2009, 12:32   #5 (permalink)
aslam870's Avatar
Member: 383033
Sonork: 100.1580642
Thanks Meter: 441
Smile
Originally Posted by ^FiStrO^ View Post
Hi
Regards
^FiStrO^
Thanks by your advice my friend but this was worst. In Qualcom mode is the same message but at the moment. ĻERROR... Phone Not ConnectedĻ
Uninstall all Samsung drivers and reinstall using drivers downloaded from Polar Support Site........Nothing, the same message.
Now Iīm using the last update............Nothing, the same message.
Maybe later I try in other PC.
Any idea??????
Any way, thanks Polar Team. The Gorr, Fistro and Y3KT (Almost a Polar Supporter) by yours advices and help. We continue trying.
Best Regards...................aslam870
Old 09-13-2009, 12:43   #6 (permalink)
Member: 71492
Thanks Meter: 119
Hi
You need put phone in qualcom mode (with keyboard sequence) and install qualcom drivers
Access Control panel->System->Hardware->Disp.Adm.
You need this 2 ports:
1 - Modem Samsung (In Modems)
2 - Diag Comport (In Ports COM&LPT)
I think you not have Diag Comport installed Ok
You can testing change Usb port and testing you cable
Regards
^FiStrO^
Old 09-13-2009, 13:36   #7 (permalink)
aslam870's Avatar
Member: 383033
Sonork: 100.1580642
Thanks Meter: 441
This is a Screen Capture now:
I unistall all again and make all manually. Then I post what happend.
Thanks and best regards my fiend.....................aslam870
Old 09-13-2009, 14:06   #8 (permalink)
aslam870's Avatar
Member: 383033
Sonork: 100.1580642
Thanks Meter: 441
Another answer. How can I unistall or remove all Samsung driver on my PC. Because I unistall all Samsung driver from Control Panel and then restar the PC but still drivers installation run automatically. I want to install all drivers manually using divers downloaded from Polar Support Site.
Best Regards..............aslam870
Old 09-13-2009, 15:24   #9 (permalink)
Member: 71492
Thanks Meter: 119
Hi
You have phone connected with Zte drivers
Replace this drivers with Samsung qualcom drivers and problem solved
Regards
^FiStrO^
Old 09-13-2009, 15:58   #10 (permalink)
The_Gorr's Avatar
Member: 145648
as Fistro sayed, ur phone is connected with Zte drivers
if u don't know how to remove drivers, i suggest u to use a clean computer, will 100% work
br
<= The_Gorr =>
Old 09-13-2009, 16:09   #11 (permalink)
toutou_gsm's Avatar
Member: 628112
Sonork: 100.1589052
Thanks Meter: 3,726
br
<= The_Gorr =>
@zied
please where can i find clean computer
i need it too
The Following User Says Thank You to toutou_gsm For This Useful Post:
Old 09-13-2009, 16:13   #12 (permalink)
The_Gorr's Avatar
Member: 145648
clean computer mean, a computer with new installed windows (no drivers conflict inside)
br
<= The_Gorr =>
Old 09-13-2009, 16:49   #13 (permalink)
toutou_gsm's Avatar
Member: 628112
Sonork: 100.1589052
Thanks Meter: 3,726
format OS, i mean if there is any software to clean just drivers
thanks
regards,
Old 09-13-2009, 20:48   #14 (permalink)
Member: 71492
Thanks Meter: 119
Hi again
Not remove drivers or clean computer
I add this name drivers in Polar and please not open new post for this
Contactme ... [email protected]
Regards
^FiStrO^
The Following User Says Thank You to ^FiStrO^ For This Useful Post:
Old 09-14-2009, 03:12   #15 (permalink)
aslam870's Avatar
Member: 383033
Sonork: 100.1580642
Thanks Meter: 441
Smile Problem solved
br
<= The_Gorr =>
Thanks both Fistro and The Gorr.
Of course that I know how remove drivers but the problem was that I unistall all Samsung drivers and still run automatically.
The solution was very simple, the delay of my post because I only can connect to Internet at night.
I change ZTE drivers manually and one by one using Qualcom drivers of Polar Support Site.
Now all is ok. Here is an screen capture of the devices connected:
And here is an image of Polar Soft:
Thanks all by his advices and Thanks Like Always Polar Team.
Polar never fail. Sometimes we fail with Polar. Thatīs all the problem.
Best Regards....................aslam870
The Following 6 Users Say Thank You to aslam870 For This Useful Post:
Alc. Ot-s920.....error phone not respond ??? SOLVED !!! eskerra PolarBox 3 18 07-18-2013 21:17
Samsung gt-s5600 not picking all networks xxyyzzz2 QUALCOMM Models (3G) 5 01-18-2010 12:07
Samsung gt s5600 phone freeze ysanghie SPT BOX 7 09-24-2009 00:22
S5600 Reading security... error! (SIM not inserted) [Solved] gsm-faruks.com Z3X-Team Products 2 09-09-2009 18:25
L700 ERROR...Phone Not Readed... :::ANSWERED::: G3N3RAL PolarBox 3 3 06-01-2009 10:33
Page generated in 0.27228 seconds with 9 queries
