Panasonic Panasonic-News... |
11-18-2015, 08:57 | #1 (permalink) |
No Life Poster Join Date: Feb 2009 Location: INDIA
Member: 973227 Status: Offline Sonork: 100.1583121 Thanks Meter: 270 | panasonic p-55 strange issue i have panasonic P-55 model which is hang on logo ,i flashed this phone with file " Panasonic_P55_4.4.028.P3.141231.7298D_I01_" flash success 100% but after power on phone starts goes on first screen logo then with blank screen shows " 1/1. Modem Up and Down" can anybody guide me for this issue? also tried this ver but flash fails at start -(Panasonic_P55_4.4.021.P1.141118.7298D_I01) thank you |
The Following User Says Thank You to sureshshetty For This Useful Post: |
11-18-2015, 10:48 | #2 (permalink) |
No Life Poster Join Date: Oct 2010 Location: ahmdabad India
Member: 1424659 Status: Offline Sonork: 100.1648352 Thanks Meter: 142 | Dev-Host - Factory mode fix by Pinto.zip - The Ultimate Free File Hosting / File Sharing Service downlode this file bro and do this job 1000% done ur set on in normal mode... 1. Download and extract all the Files in a folder that's easy to find 2. On ur Phone then connect it to a PC 3. Open cmd to run as administrator 4. type- adb shell 5. Type- Quote: -b fctd normal or fctest system reboot 6.Press Enter 7. Phone will restart automatically, 8. Click "unFactroy Mode.bat" when open cmd screen press Enter, wait for it to finish and then press Enter again, Phone again will restart automatically and return to normal br ashish singh |
The Following 3 Users Say Thank You to ashishsingh For This Useful Post: |
11-18-2015, 13:55 | #3 (permalink) |
Member: 973227 Status: Offline Sonork: 100.1583121 Thanks Meter: 270 | great ashish singh thank you so much i was thinking last way to send customer to service centre but you did my job thank you once again Last edited by sureshshetty; 11-18-2015 at 14:03. |
The Following 2 Users Say Thank You to sureshshetty For This Useful Post: |
11-19-2015, 14:03 | #5 (permalink) |
Member: 973227 Status: Offline Sonork: 100.1583121 Thanks Meter: 270 | ramrajbhopal this working solution you need to copy and paste above command correctly you may be need pc restart if it fails though you gave correct command , i faced so keep patience and try goodluck |
11-28-2015, 12:03 | #8 (permalink) | |
Freak Poster Join Date: Dec 2014 Location: srinagar jammu and Kashmir
Member: 2317380 Status: Offline Thanks Meter: 16 | Quote:
check the volume keys waseem raja | |
01-12-2016, 15:13 | #9 (permalink) |
No Life Poster Join Date: Dec 2007 Location: INDIA BHUBANESWAR
Member: 641849 Status: Offline Sonork: 100.1619689 Thanks Meter: 44 | hi i had the same issue earlier before trying this wht i did is i tried with a sp tool scatter file now its on logo then off then again i tried to flash with ygdp tool now flashing always stops with 75% kindly revert if anyone having a solution |
01-21-2016, 11:34 | #13 (permalink) |
Freak Poster Join Date: Jan 2009 Location: india,kerala..in NAJMU
Member: 955971 Status: Offline Sonork: 100.1638835 Thanks Meter: 115 | problem solved with http://forum.gsmhosting.com/vbb/f811.../#post11565894 |
