Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Panasonic
Panasonic Panasonic-News...
Old 11-18-2015, 08:57   #1 (permalink)
Member: 973227
Sonork: 100.1583121
Thanks Meter: 270
panasonic p-55 strange issue
hi
i have panasonic P-55 model
which is hang on logo ,i flashed this phone with file " Panasonic_P55_4.4.028.P3.141231.7298D_I01_"
flash success 100%
but after power on phone starts goes on first screen logo then with blank screen shows " 1/1. Modem Up and Down"
can anybody guide me for this issue?
also tried this ver but flash fails at start -(Panasonic_P55_4.4.021.P1.141118.7298D_I01)
thank you
The Following User Says Thank You to sureshshetty For This Useful Post:
Old 11-18-2015, 10:48   #2 (permalink)
ashishsingh's Avatar
Member: 1424659
Sonork: 100.1648352
Thanks Meter: 142
Dev-Host - Factory mode fix by Pinto.zip - The Ultimate Free File Hosting / File Sharing Service
downlode this file bro and do this job 1000% done ur set on in normal mode...
1. Download and extract all the Files in a folder that's easy to find
2. On ur Phone then connect it to a PC
3. Open cmd to run as administrator
4. type- adb shell
5. Type-
-b fctd normal or fctest system reboot
6.Press Enter
7. Phone will restart automatically,
8. Click "unFactroy Mode.bat" when open cmd screen press Enter, wait for it to finish and then press Enter again, Phone again will restart automatically and return to normal
br
ashish singh
The Following 3 Users Say Thank You to ashishsingh For This Useful Post:
Old 11-18-2015, 13:55   #3 (permalink)
Member: 973227
Sonork: 100.1583121
Thanks Meter: 270
great
ashish singh thank you so much
i was thinking last way to send customer to service centre but you did my job
thank you once again
The Following 2 Users Say Thank You to sureshshetty For This Useful Post:
Old 11-19-2015, 13:00   #4 (permalink)
ramrajbhopal's Avatar
Member: 768205
Thanks Meter: 45
not working salution
Old 11-19-2015, 14:03   #5 (permalink)
Member: 973227
Sonork: 100.1583121
Thanks Meter: 270
ramrajbhopal this working solution
you need to copy and paste above command correctly
you may be need pc restart if it fails though you gave correct command , i faced so
keep patience and try
goodluck
Old 11-21-2015, 14:15   #6 (permalink)
Member: 953066
Thanks Meter: 7
unFactroy Mode.bat
how to download this file
Old 11-21-2015, 15:16   #7 (permalink)
Member: 973227
Sonork: 100.1583121
Thanks Meter: 270
copy first line of ashishsingh post and search in google you will find all
Old 11-28-2015, 12:03   #8 (permalink)
Member: 2317380
Thanks Meter: 16
Originally Posted by sureshshetty View Post
hi
flash success 100%
thank you
check the volume keys
waseem raja
Old 01-12-2016, 15:13   #9 (permalink)
RICKY great's Avatar
Member: 641849
Sonork: 100.1619689
Thanks Meter: 44
hi i had the same issue earlier before trying this wht i did is i tried with a sp tool scatter file now its on logo then off then again i tried to flash with ygdp tool now flashing always stops with 75% kindly revert if anyone having a solution
Old 01-20-2016, 10:59   #10 (permalink)
simcityreal's Avatar
Member: 955971
Sonork: 100.1638835
Thanks Meter: 115
Device Not Found...in adb shell....,
Device Manager Detected And Show"CMCC Composite ADB Interface".......
Thanks....
Old 01-20-2016, 11:04   #11 (permalink)
faisalkhan12345's Avatar
Member: 1969619
Sonork: 100.1670362 QQ3052215670
Thanks Meter: 1,587
https://drive.google.com/file/d/0B2E...l5b0pkeGs/view
rung modem press 1 n enter ur problem solved
The Following 3 Users Say Thank You to faisalkhan12345 For This Useful Post:
Old 01-20-2016, 11:19   #12 (permalink)
Member: 955971
Sonork: 100.1638835
Thanks Meter: 115
Not Solved...
Old 01-21-2016, 11:34   #13 (permalink)
Member: 955971
Sonork: 100.1638835
Thanks Meter: 115
problem solved with http://forum.gsmhosting.com/vbb/f811.../#post11565894
Page generated in 0.19307 seconds with 8 queries
