04-11-2009, 05:03 | #1 (permalink) |
Freak Poster Join Date: Apr 2005 Age: 44
Member: 133351 Status: Offline Thanks Meter: 20 | need to remove phone lock code but when i try format i get this error that flash chip is empty what flash do i need to use to flash it good? COM3 [VCP6] selected module v2.80 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection disabled Action: repair security area Boot ... Press and HOLD Power button now ! baud autodetection active 19200 autodetect Connecting, wait... Initializing [6205:8B00]... CPU: MT6205 high speed boot On boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 01227E221A2201:FFFFFF00000000 flash: Amd S29GL032A-T r3,r4,w3,w4,r3 T 4Mb detecting chip #01 in region #00... flash: 01227E221A2201:FFFFFF00000000 flash: Amd S29GL032A-T r3,r4,w3,w4,r3 T 4Mb detecting chip #02 in region #00... flash: 01227E221A2201:FFFFFF00000000 flash: Amd S29GL032A-T r3,r4,w3,w4,r3 T 4Mb detecting chip #03 in region #00... flash: 01227E221A2201:FFFFFF00000000 flash: Amd S29GL032A-T r3,r4,w3,w4,r3 T 4Mb detecting chip #04 in region #00... flash: 01227E221A2201:FFFFFF00000000 flash: Amd S29GL032A-T r3,r4,w3,w4,r3 T 4Mb detecting chip #05 in region #00... flash: 01227E221A2201:FFFFFF00000000 flash: Amd S29GL032A-T r3,r4,w3,w4,r3 T 4Mb detecting chip #06 in region #00... flash: 01227E221A2201:FFFFFF00000000 flash: Amd S29GL032A-T r3,r4,w3,w4,r3 T 4Mb detecting chip #07 in region #00... flash: 01227E221A2201:FFFFFF00000000 flash: Amd S29GL032A-T r3,r4,w3,w4,r3 T 4Mb detecting chip #08 in region #00... flash: 01227E221A2201:FFFFFF00000000 flash: Amd S29GL032A-T r3,r4,w3,w4,r3 T 4Mb detecting chip #09 in region #00... flash: 01227E221A2201:FFFFFF00000000 flash: Amd S29GL032A-T r3,r4,w3,w4,r3 T 4Mb detecting chip #0A in region #00... flash: 01227E221A2201:FFFFFF00000000 flash: Amd S29GL032A-T r3,r4,w3,w4,r3 T 4Mb detecting chip #0B in region #00... flash: 01227E221A2201:FFFFFF00000000 flash: Amd S29GL032A-T r3,r4,w3,w4,r3 T 4Mb detecting chip #0C in region #00... flash: 01227E221A2201:FFFFFF00000000 flash: Amd S29GL032A-T r3,r4,w3,w4,r3 T 4Mb detecting chip #0D in region #00... flash: 01227E221A2201:FFFFFF00000000 flash: Amd S29GL032A-T r3,r4,w3,w4,r3 T 4Mb detecting chip #0E in region #00... flash: 01227E221A2201:FFFFFF00000000 flash: Amd S29GL032A-T r3,r4,w3,w4,r3 T 4Mb detecting chip #0F in region #00... flash: 01227E221A2201:FFFFFF00000000 flash: Amd S29GL032A-T r3,r4,w3,w4,r3 T 4Mb number of flash chip/regions detected: 10/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 01227E221A2201:FFFFFF00000000 flash: Amd S29GL032A-T r3,r4,w3,w4,r3 T 4Mb Warning: probably flash chip is empty, erased, incorrectly flashed or damaged ! What to do: 1. go to software "Settings" page 2. set "Advanced chip detection method" box CHECKED ! 3. make flash write operation If still no luck: send mail to support ([email protected]) with detailed description of problem, attach the next files in your e-mail: 1. C:\Program Files\InfinityBox\ChineseMiracle\operation.log 2. C:\Program Files\InfinityBox\ChineseMiracle\cfi_xxxx_xxxx.bin detecting chip #01 in region #00... flash: 01227E221A2201:FFFFFF00000000 flash: Amd S29GL032A-T r3,r4,w3,w4,r3 T 4Mb it's time to stop: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF number of flash chip/regions detected: 01/01 total flash region size: 00400000 detect device identification#1... detection phase #1... . detection phase #2... .............................. warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detecting security area (code #2)... ... security area (code #2) is absent detect device identification#2... detection phase #1... . detect device identification#2 finished Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... flash: 01227E221A2201:FFFFFF00000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... Write Done Finalization ... Finalization Done Finished, time used: 51 sec Remove/Install battery now ! thanks! |
04-14-2009, 20:50 | #3 (permalink) |
Member: 133351 Status: Offline Thanks Meter: 20 | Hi there thanks for the reply i managed to read the user code by searching for second set of RX/TX pins as they are for the first sim its a dual sim phone . it says TV-MOBILE N99i the problem i have now its restarting where can i download the flash and how do i flash it? its my first try to flash a chinese phone any help would be greatly appreciated thanks and best regards SEWKAR |
04-15-2009, 06:13 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | 1. read phone information 2. make full flash for emergency case (it's VERY important) 3. where to get files: in support area \flashfiles\ChineseMiracle How to write flash (upgrade/downgrade firmware, change language): 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Flash" page and load required files 8. press "Write" button and follow instruction given by software How to read flash: 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Service" page 8. press "Read flash" (or "Read full flash") button and follow instruction given by software How to unlock (remove sp-lock, provider lock etc.): 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Service" page 8. press "SP-Unlock" button and follow instruction given by software How to reset/format ffs (reset setting to default values, repair freez/restart etc.): - at first try to make "safe format" (if this option exist) - if "safe" option is not works try to make "complete" format (if this option exist) 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Service" page 8. select format mode "safe" or "complete" (if mode is available) 9. press "Reset" or "Format" button and follow instruction given by software |
04-20-2009, 05:28 | #6 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, You do not need to flash phone. Just try to make "format ffs" as a first step. Do not forget to make full flash backup before "format" operation for emergency case. |
04-20-2009, 08:37 | #7 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @kawish here is Infinity-Box support forum. If you have a problems with JAF please, post your questions in JAF support forum. Your offtopic message was deleted. |
How to remove phone lock code G810??? | jham | UST Pro II | 19 | 10-04-2009 12:11 |
Is possible to remove Phone Lock Code on DB-2020 phone without Unlock RSA? | Jazz | Cruiser Suite | 6 | 09-18-2008 01:01 |
All Pda Smartphone Pna Soft And Hard Reset, To Remove Phone Lock Code | aikonmani | GSM Mobile Links | 1 | 07-06-2008 22:50 |
How to remove phone lock code on x70? | sutiee | Panasonic | 9 | 04-21-2005 08:38 |
how to remove phone lock code on k508i | jusluke | Cruiser Suite | 4 | 01-27-2005 10:42 |
