Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > BB5BOX Products > BB5BOX
Old 10-21-2007, 13:37   #1 (permalink)
iran-mobile-team's Avatar
Member: 305053
Thanks Meter: 16
problem unlock 3250 with BB5-BOX
i have a 3250 which i wanted to unlock with bb5 box(version 0.02.6)
but after pressing the unlock botton in program the error writing(no support model or version)
phone software version is 3.24
help plzz
Old 10-21-2007, 13:54   #2 (permalink)
midou01's Avatar
Member: 40632
Sonork: 98231
Thanks Meter: 1,658
because version supported is 4.21 Please read everything before you unlock with bb5box
Old 10-21-2007, 18:11   #3 (permalink)
Member: 305053
Thanks Meter: 16
3250
Searching for phone ...
Phone found on FBUS interface
Reading phone info ...
Type: RM-38
Version: V__04.21_16-02-07_RM-38_(c)_Nokia.
IMEI: 357934006834823
SP LOCK status:
Config Key: 2320500000000000
Block 1: CLOSED Type 5 Data: 23205F
Keyboard wrong codes counter: 0 wrong tries from max. 3 tries
Cable wrong codes counter: 0 wrong tries from max. 10 tries
Set Full Factory Defaults ...
Reset phone ...
Reset phone in TEST mode ...
Full Factory Defaults set OK
Skip autobackup of PM 308
Autobackup file:
RM-38_357934006834823_Locked_Keycnt_0_Fbuscnt_0__V__0 4.21_16-02-07_RM-38_(c)_Nokia..bin
already exist
Auto Write PM 308 procedure started
Searching for backup file with lowest FBUS count ...
Finded backup file: RM-38_357934006834823_Locked_Keycnt_0_Fbuscnt_0__V__0 4.21_16-02-07_RM-38_(c)_Nokia..bin
Writting PM Field 308 Subfield 1 with length 8192 bytes
Reset phone ...
PM Field 308 Subfield 1 written OK
Reading SP Locks after Auto Write PM 308 ...
SP LOCK status:
Checking if model/version is supported for unlock ...
Please connect testpoints
Testpoints connected OK
Keep Testpoints connected until unlock finish!
Unlocking phone ...
Try number: 1
Sending SP code: #pw+012345678901234+7#
Response byte: 00
Reading again SP Locks ...
SP LOCK status:
Block 1: OPEN Type 5 Data: 23205F
Phone unlocked succesfull
tnx
i upgrade version and unlocked phone
Old 04-08-2008, 11:51   #4 (permalink)
Member: 79291
Thanks Meter: 9
hello
wich testpoint did you use cause i found 2 kind of testpoints
Trouble Unlocking 6300 With BB5 Box - Nokia 6300 Using Test Point Jig- Please Help :) dave.cullen BB5BOX 7 02-04-2008 09:23
6086 unlock fail with bb5 box Bao Tran BB5BOX 22 12-25-2007 01:06
N75 1000% unlocked Susesfull with BB5 box Bao Tran BB5BOX 10 12-15-2007 04:08
6131 unlock fail with bb5 box RamazanUsta BB5BOX 3 10-29-2007 22:38
5300b ver 4.51 unlocked susecfull with BB5 Box.....100000% Bao Tran BB5BOX 0 10-15-2007 08:10
Page generated in 0.16553 seconds with 9 queries
