12-13-2007, 07:18 | #1 (permalink) |
Freak Poster Join Date: Nov 2006
Member: 384472 Status: Offline Thanks Meter: 45 | N75 1000% unlocked Susesfull with BB5 box P-key nokia module version 01.00 Detected JAF INTERFACE version: 01.B0, Driver version: 40000, Library version: 30107 JAF DCT4/BB5 LOADERS DIR: C:\Program Files\ODEON\JAF\Flash\ JAF DCT4/BB5 PRODUCT DIR: C:\Program Files\Nokia\Phoenix\Products\ JAF USB LOADERS DIR: C:\Program Files\ODEON\JAF\FlashUSB\ JAF DCT3/DCTL LOADERS DIR: C:\Program Files\ODEON\JAF\Flash3\ Changing mode...Done! FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Searching for phone...Detected P-KEY: 90011B83 P-key nokia module version 01.00 Init usb communication... Found MCU SW version: V 06wk15v37 08-03-07 RM-128 (c) Nokia. HW version: 4202 PCI version: RFIC version: 17141714 DSP version: chx_06wk14v44 LCD version: 8621376 APE SW Core version: V 10.2.055 24-04-07 RM-128 (C)Nokia APE Variant version: V 10.2.055-01.02 24-04-07 RM-128 (C)Nokia Retu version: 15 Tahvo version: 22 APE HW version: 1 APE ADSP SW version: 256 Camera version: 1028 APE BT version: HCI Version 3 (rev. 1740). LMP Version 3 (rev. 1740). Manufacturer 10. Production serial number: SFG494121 Product code: 0527376 Module code: Basic production code: 0527375 Flash code: Order number: Product specific data: Long production SN: ATO: Default SN type: IMEI plain: 354815010678871 IMEI spare to net: 3A 45 18 05 01 76 88 07 IMEI SV to net: 33 45 18 05 01 76 88 37 F0 LOCK STATUS: CONFIG KEY: 3101700000000000 Provider: CINGULAR - Pacific Bell Wireless;U.S.A. Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: CLOSED -> Lock Data: 310150 Block 2: Lock 1: CLOSED -> Lock Data: 310150 Block 3: Lock 1: CLOSED -> Lock Data: 310170 Block 4: Lock 1: CLOSED -> Lock Data: 310170 Block 5: Lock 1: CLOSED -> Lock Data: 310410 Block 6: Lock 1: CLOSED -> Lock Data: 310410 Block 7: Lock 1: CLOSED -> Lock Data: 311180 Block 8: Lock 1: CLOSED -> Lock Data: 311180 Loading INI list... No ini files found... FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Done! Last edited by Bao Tran; 12-28-2009 at 08:24. |
12-13-2007, 07:58 | #2 (permalink) | |
Member: 384472 Status: Offline Thanks Meter: 45 | Quote:
Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-128 Version: V_06wk15v37_08-03-07_RM-128_(c)_Nokia. IMEI: 354815010678871 SP LOCK status: Config Key: 3101700000000000 Block 1: CLOSED Type 5 Data: 310150 Block 2: CLOSED Type 5 Data: 310150 Block 3: CLOSED Type 5 Data: 310170 Block 4: CLOSED Type 5 Data: 310170 Block 5: CLOSED Type 5 Data: 310410 Block 6: CLOSED Type 5 Data: 310410 Block 7: CLOSED Type 5 Data: 311180 Block 8: CLOSED Type 5 Data: 311180 Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-128_354815010678871_Locked_Keycnt_0_Fbuscnt_0__V_0 6wk15v37_08-03-07_RM-128_(c)_Nokia..bin already exist Auto Write PM 308 procedure started Searching for backup file with lowest FBUS count ... Finded backup file: RM-128_354815010678871_Locked_Keycnt_0_Fbuscnt_0__V_0 6wk15v37_08-03-07_RM-128_(c)_Nokia..bin Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 3101700000000000 Block 1: CLOSED Type 5 Data: 310150 Block 2: CLOSED Type 5 Data: 310150 Block 3: CLOSED Type 5 Data: 310170 Block 4: CLOSED Type 5 Data: 310170 Block 5: CLOSED Type 5 Data: 310410 Block 6: CLOSED Type 5 Data: 310410 Block 7: CLOSED Type 5 Data: 311180 Block 8: CLOSED Type 5 Data: 311180 Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Delaying unlock procedure with 5000 miliseconds Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 3101700000000000 Block 1: OPEN Type 5 Data: 310150 Block 2: OPEN Type 5 Data: 310150 Block 3: OPEN Type 5 Data: 310170 Block 4: OPEN Type 5 Data: 310170 Block 5: OPEN Type 5 Data: 310410 Block 6: OPEN Type 5 Data: 310410 Block 7: OPEN Type 5 Data: 311180 Block 8: OPEN Type 5 Data: 311180 Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull...... | |
problem unlock 3250 with BB5-BOX | iran-mobile-team | BB5BOX | 3 | 04-08-2008 11:51 |
Trouble Unlocking 6300 With BB5 Box - Nokia 6300 Using Test Point Jig- Please Help :) | dave.cullen | BB5BOX | 7 | 02-04-2008 09:23 |
6086 unlock fail with bb5 box | Bao Tran | BB5BOX | 22 | 12-25-2007 01:06 |
6131 unlock fail with bb5 box | RamazanUsta | BB5BOX | 3 | 10-29-2007 22:38 |
5300b ver 4.51 unlocked susecfull with BB5 Box.....100000% | Bao Tran | BB5BOX | 0 | 10-15-2007 08:10 |
