Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > SPT BOX
Old 03-19-2014, 20:19   #31 (permalink)
gsm_new1's Avatar
Member: 1189306
Sonork: 100.1589231
Thanks Meter: 273
Hello
for Default efs put ur set in download mode and use the USB..
and for write the ime use the RJ45 cable...
bro
Old 03-20-2014, 13:58   #32 (permalink)
Member: 2066290
Thanks Meter: 11
what about unlocking N900A ???
Old 03-20-2014, 21:32   #33 (permalink)
dannyogolo's Avatar
Member: 18200
Sonork: 100.1608286
Thanks Meter: 82
N900T v4.3 Repair 3G Freezes System
Originally Posted by BABAK NURI View Post
Who have problem for detecting phone with repair 3g button....Follow This:
1-enable "USB Debauging"
2-Accept HW Fingerprint
3-Dial *#0808#
4-Select "DM+ADB+Modem"
5-Press "Scan" and Now You Must See 2 Port(with usb).... JUST SELECT Higher Number
for example if you see port 100 and 101.....Need select port 101
6-Now Press repair 3G Button
if any one sucess repair 3g and phone back to work,,,Please report ...Plus Tell us for which firmware have on the phone
Thanks again
N900T Repair 3G Not working for this particular phone.
When I select the higher Port number, and click Repair 3G, Software will freeze and show Not Responding. Software will only get back to normal if you disconnect USB Cable.
Old 03-21-2014, 00:04   #34 (permalink)
Member: 2139835
I have N900t , can never get "default efs" done . I don't know why
Old 03-21-2014, 06:56   #35 (permalink)
Member: 70463
Thanks Meter: 6
Originally Posted by XpErTsGsM View Post
NOTE: ( N9005 AND N900w8 are Similer You can Reset EFS and repair IMEI and 3g Network for N9005 in N900w8 )
you can chose N9005 if N900w8 is not working both are same models
how about n900...?tried to use n900w8 but cant repair 3g network
here is the logs....
is n900 really works to repair 3g network?
any screen shots in successful repair for n900 3g network
here is my logs....
starting from reset default efs
here is for super imei repair
as you can see the repair 3g network on n900 model is not high-lighten, so l use n900w8 model to repair 3g network...but having error
*#7284# choose uart ---- modem
*#0808# choose DM + modem + ADB
any other solution to repair 3g network?and for product supporter please add other super imei for this model because in this version there is only 1 in super imei option.
Old 03-21-2014, 11:03   #36 (permalink)
dannyogolo's Avatar
Member: 18200
Sonork: 100.1608286
Thanks Meter: 82
DONE IT N900T.
I was getting error on Repair 3G, So I decided to flash phone.
I flashed with N900TUVUBMI7_N900TTMBBMI7_N900TUVUBMI7_HOME.tar.md 5
Rooted
Hard Reset everything
And tried Repair 3G again.
And it worked
Old 03-21-2014, 15:54   #37 (permalink)
gsm_new1's Avatar
Member: 1189306
Sonork: 100.1589231
Thanks Meter: 273
@sanflora
hello
for n900 did't need the repair the 3g its work with out repair. just check...
bro
Old 03-21-2014, 22:43   #38 (permalink)
Member: 2151956
Thanks Meter: 6
Obviously he was not wrong. You yourself said you need a special file and riff box as well. So he is correct that spt team is misleading people into believing that you can repair IMEI of n900t with just their box alone. I cant believe i wasted all this money on this box. I already have nspro, octopus and z3x and they do any phone spt does plus more and they actually work right. If you need to repair IMEI on n900t do not buy the SPT box it will not work. Save your money and time.
The Following User Says Thank You to lucky4me For This Useful Post:
Old 03-22-2014, 04:06   #39 (permalink)
Member: 1595179
so, you cannot simply do it with ONLY the SPT box ?
Old 03-22-2014, 06:25   #40 (permalink)
Member: 2151956
Thanks Meter: 6
No you cannot. And the SPT team keeps giving us the same instructions that do not work. They tell you to select dm over uart. And anyone who has held a n900t in their hands knows that option does not exist. There is no *#9090# service mode menu on a n900t. It is obvious the SPT team never had a n900t in their hands. More proof that they have not had one in their hands is if you go into the adb folder in the spt software you will notice there is no efs file for the n900t that is why you have to reset the efs with n9005 selected. I guess they thought that since it worked on a n9005 it would work on the n900t as well since they have same processor. The bottom line is that you can not repair the IMEI of a n900t with the spt box alone. Do not waste your time or money.
Old 03-22-2014, 11:16   #41 (permalink)
Member: 329458
Thanks Meter: 153
If n9005 show "DIAG CONFIG NOT SUPPORTED" with diallig *#9090# what is the solution?
Old 03-22-2014, 14:24   #42 (permalink)
Member: 75838
Thanks Meter: 67
Today i buy spt box. Plz help me,step by step how to change OR REPAIR imei. sm-n900(note3) 4.4.2
Old 03-22-2014, 16:19   #43 (permalink)
Member: 1847451
Thanks Meter: 45
Hey bro n900w8 unlocks and imei repair works on 4.3 without imei certi damage. But of you have kitkat it will damage the certificate. I did 2 phones one on 4.3 works great other one is 4.4.2 doesn't work.
Sent from my SGH-I337M using Tapatalk
Old 03-22-2014, 16:56   #44 (permalink)
Member: 2100387
Thanks Meter: 6
if i wright the super imei need to unlock from my country
my country now use security of imei
10x
Old 03-23-2014, 04:57   #45 (permalink)
Member: 472160
Help With n900t
Please help I have followed the instructions at the beginnig of this thread and retried following them to a T, but cannot seem to get anywhere.
I am getting the default efs to reset but it kinda seems like nothing happens just says a really low # like 1.8s (which from what im reading seems correct), but my main concern is that after switching to my c3300k cable I keep getting a simlock data error... Here is my log output, again please help
Please Wait Enter Test Mode ...
Enter Test Mode OK!
Model Name: SM-N900T
S/W Version: N900TUVUBMI7
Phone SN: RV1DA0WS86
IMEI: 35732165120225
Repair New IMEI: 000000000000000
Read SIMLOCK Data Failure !
Total Time: 7.0 s
Page generated in 0.18565 seconds with 9 queries
