Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > SPT BOX
Old 03-23-2014, 09:26   #46 (permalink)
Member: 75838
Thanks Meter: 67
Originally Posted by sunil kumar View Post
Today i buy spt box. Plz help me,step by step how to change OR REPAIR imei. sm-n900(note3) 4.4.2
In my note3 also not working *#7284#
But *#0808# working fine,any solution plz
Old 03-24-2014, 04:52   #47 (permalink)
compicarlos's Avatar
Member: 1330441
Thanks Meter: 95
Note3 OFF, conect Uart Cable and Power ON.
test again *#7284#
Old 03-24-2014, 16:17   #48 (permalink)
Member: 1744748
Thanks Meter: 752
Originally Posted by harpreetbraich View Post
Hey bro n900w8 unlocks and imei repair works on 4.3 without imei certi damage. But of you have kitkat it will damage the certificate. I did 2 phones one on 4.3 works great other one is 4.4.2 doesn't work.
Sent from my SGH-I337M using Tapatalk
Try downgrading the modem... may be that might help... I haven't done one my self... yet...
Old 03-24-2014, 19:40   #49 (permalink)
Member: 2097414
Thanks Meter: 12
Reset EFS is ok... write IMEI is error... RJ 45 port is not working ... help SPT Team
Old 03-24-2014, 19:43   #50 (permalink)
Member: 1847451
Thanks Meter: 45
I can't reset efs for sm-n900w8 on 4.4.2 Says completed but nothing happens on the phone....but when I select N9005 and click reset efs it works. But still Imei certi fail after super imei
Old 03-24-2014, 20:44   #51 (permalink)
Member: 1295004
Sonork: 100.1610057
Thanks Meter: 29
I too need 4.4.2 imei cert
kind regards
Old 03-24-2014, 21:01   #52 (permalink)
Member: 1851293
Thanks Meter: 19
For everyone having problem working with N900A, N900T and other Note 3 Models, here is a quick guide that works for me. I’m running Win 7 64b
1. If you already change something on 7284/0808 it will be best to do a factory reset.
2. Make sure your running the SPT Box as admin.
3. The 1st step is selecting the N9005 or N900W8, I have done all with N9005.
4. Phone must be in download mode
5. Select the right USB port on “port” use USB cable and connect directly to the computer(not to the box) and do reset, when done your device will reboot by itself.
7. Go back to “port” and change to the box serial port, connect UART cable, select your Super Imei, click on Unlock/Imei repair and click on Factory mode, DONE!
The Following 3 Users Say Thank You to silvertigre2012 For This Useful Post:
Old 03-24-2014, 21:07   #53 (permalink)
Member: 1847451
Thanks Meter: 45
I do the same procedure it works on android 4.3. Have you successfully done any unit with android 4.4.2??
Old 03-24-2014, 21:17   #54 (permalink)
Member: 1295004
Sonork: 100.1610057
Thanks Meter: 29
harpreetbraich what store do you work?
br
Old 03-24-2014, 21:22   #55 (permalink)
Member: 1847451
Thanks Meter: 45
br
Full time student.....unlocks And repair for some extra money for college
The Following User Says Thank You to harpreetbraich For This Useful Post:
Old 03-25-2014, 02:02   #56 (permalink)
Member: 1847451
Thanks Meter: 45
Thanks everyone for your replies......finally after countless flashing back to stock and superimei. I managed to get IMEI CERTI: Pass on my sm-n900w8 on 4.4.2 and calls LTE data everything works great.
Old 03-25-2014, 02:43   #57 (permalink)
Member: 1744748
Thanks Meter: 752
Please explain how you were able to manage it... many of us are stuck with this situation...
The Following User Says Thank You to ysr84 For This Useful Post:
Old 03-25-2014, 17:46   #58 (permalink)
Registered User
Member: 1748578
Thanks Meter: 4
worried and help
please suport and people im trying to use the uart port but the its stuck wayting for test mode and wont do nothing after efs reset please spt team help how can i get a connection or i need a uart driver to et the connection reply back thanks
Old 03-25-2014, 17:57   #59 (permalink)
Registered User
Member: 1748578
Thanks Meter: 4
i already did all the procedure but it still ot connecting to uart comport just stuck in waiting for test mode timeout please help team and people
Old 03-25-2014, 18:03   #60 (permalink)
Member: 1234013
Thanks Meter: 3
Note 3 n9005 no 2g signals 3g 4g working fine in 4.4.2 after repair imei
Repaired imei of my note 3 n9005..
done the 3g networks repaired,every thing went well just not getting
any 2g signals,3g 4g working fine..how to fix this issue..?
please help..
Page generated in 0.26126 seconds with 9 queries
