Old 04-22-2015, 06:26   #1 (permalink)
Luckey1's Avatar
Member: 2197212
Sonork: N/A
Thanks Meter: 680
How to solve this problem ?
How to solve this problem already un installed previous version and also root folder is also deleted
The Following 2 Users Say Thank You to Luckey1 For This Useful Post:
Old 04-22-2015, 07:04   #2 (permalink)
Member: 757799
Thanks Meter: 782
just off your pc and on again
Old 04-22-2015, 09:10   #3 (permalink)
Luckey1's Avatar
Member: 2197212
Sonork: N/A
Thanks Meter: 680
ALREDY TRiED RESTART POWER OFF ALL BUT SAME PROBLEM MANUALLY DELETED ALL FILES FROM ROOT FOLDER NAMED SAMSUNG STILL SAME ISSUE .
Old 04-22-2015, 09:19   #4 (permalink)
div_raj's Avatar
Member: 59732
Thanks Meter: 47
how to solve this same problem me also all done but not only stuck at logo
pls help.........
Old 04-22-2015, 09:22   #5 (permalink)
Akhtar Ali Jatt's Avatar
Member: 953334
Sonork: 100.1614005
Thanks Meter: 15,428
i Am also facing same problem ,
is new exe need additional software support like Net framework ,java,flash player ?
Old 04-22-2015, 10:28   #6 (permalink)
Registered User
Member: 669673
Thanks Meter: 301
Did you download new setup from shell using ?
Old 04-22-2015, 10:56   #7 (permalink)
div_raj's Avatar
Member: 59732
Thanks Meter: 47
yes download new setup from shell
Old 04-22-2015, 11:18   #8 (permalink)
Member: 1228517
Thanks Meter: 39
run samsung tool as administrator
Old 04-22-2015, 11:33   #9 (permalink)
div_raj's Avatar
Member: 59732
Thanks Meter: 47
yes same problem in with administrator also
Old 04-22-2015, 12:43   #10 (permalink)
Member: 908175
Thanks Meter: 314
Did u found any way to get this sort thanks I am facing same problem
The Following User Says Thank You to qasi786 For This Useful Post:
Old 04-22-2015, 13:46   #11 (permalink)
van_gsm's Avatar
Member: 1311694
Sonork: 100.1606976
Thanks Meter: 107
am also facing the same problem but i was it in the morning
Old 04-22-2015, 13:54   #12 (permalink)
ashik.telecom's Avatar
Member: 1524668
Sonork: n/a
Thanks Meter: 468
run as admin.......................................
Old 04-22-2015, 14:04   #13 (permalink)
aikonmani's Avatar
Member: 304090
Thanks Meter: 210
same problem...
i did run as admin...
restarted pc....
not work.
Old 04-22-2015, 15:24   #14 (permalink)
Member: 953334
Sonork: 100.1614005
Yes Downloaded 2 Setup one inside shell ,
2nd From Shell Via idm ,
Both Have Same problem .
Old 04-22-2015, 15:29   #15 (permalink)
Member: 228579
Sonork: 100.1612511
Thanks Meter: 100
remove shell
remove v20.
restart
instal only v20.0
Page generated in 0.24201 seconds with 8 queries
