Old 02-09-2017, 12:21   #1 (permalink)
maplegsm's Avatar
Member: 391664
Sonork: Python
Thanks Meter: 1,063
LG LS775 stuck in download mode in unlocking
LG 2-3G Tool v9.30
supported models: 1426
Mode: Normal
Model: LS775ZV8
Build version: Dec 23 201611:58:01Nov 18 201604:00:00LS775ZV8
SW Version: MPSS.DPM.2.0.c11-00069-M8936FAAAANUZM-1
IMEI: 35630407647022-4
BlueTooth Address: 00:00:00:00:00:00
Phone Code:
Elapsed: 1 secs. --> (v9.30)
Mode: Normal
Model: LS775ZV8
Phone Code:
Checking phone at COM624
Detected ID: 00000FFE (MSM8916)
Reading ESN... OK
Read SPC...
Unlock SPC... error
Mode: Normal
Model: LS775ZV8
BlueTooth Address: 00:00:30:30:30:30
Phone Code:
Reading ESN... OK
Read SPC...
Unlock SPC... error
Reading timeout, check cable
Error Code: ReadInfo,1,1
Elapsed: 3 secs. --> (v9.30)
Mode: Normal
Model: LS775ZV8
Phone Code:
Phone mode is NORMAL
Switch to DOWNLOAD mode
Phone detected!
Start unlock Sprint...
Model name: LGLS775
Software verion: LS775ZV8
Android verion: 7.0
IMEI: 356304076470224
Backup carrier... done
Init EXT4 ...
/apps
/apps/node.db
/apps/node.db-journal
Laf flash ext4 error: [ChmodChown] could not find root inode.
Error change rights for /cust...
Error change rights for /omadm...
Save EXT4...
Laf cmd error: LAF_CMD_WRITE fail[LAF_ERROR_UNKNOWN[80000121]].
Elapsed: 45 secs. --> (v9.30)
The Following User Says Thank You to maplegsm For This Useful Post:
Old 02-10-2017, 13:21   #2 (permalink)
Member: 190274
Thanks Meter: 47
Me too. Octoplus doesn't mess up the phone like this. Kindly fix this problem asap!
LG 2-3G Tool v9.32
supported models: 1440
Mode: Normal
Model: LS775ZV8
IMEI: 356304079xxxxxxx
Phone Code:
Elapsed: 1 secs. --> (v9.32)
Mode: Normal
Model: LS775ZV8
IMEI: 356304079xxxxxxxx
Phone Code:
Phone detected!
Model name: LGLS775
Android verion: 7.0
Init EXT4 ...
/apps
/apps/node.db
Save EXT4...
Elapsed: 53 secs. --> (v9.32)
The Following User Says Thank You to hiroprotagonist For This Useful Post:
Old 02-10-2017, 13:51   #3 (permalink)
maplegsm's Avatar
Member: 391664
Sonork: Python
Thanks Meter: 1,063
waiting for support answer i want to restore back in Normal state if we cant unlock
i downloaded its tot
https://forum.xda-developers.com/and...-0-lg-t3552990
but z3x unable to flash
always same error battery 50% charged
2/9/2017 8:44:59 PM: LG 2-3G Tool v9.32
2/9/2017 8:44:59 PM: supported models: 1440
2/9/2017 8:48:02 PM: Reading timeout, check cable
2/9/2017 8:48:02 PM: Error Code: ReadInfo,1,1
2/9/2017 8:48:02 PM: Elapsed: 2 secs. --> (v9.32)
2/9/2017 8:49:48 PM: Reading timeout, check cable
2/9/2017 8:49:48 PM: Error Code: ReadInfo,1,1
2/9/2017 8:49:48 PM: Elapsed: 2 secs. --> (v9.32)
Old 02-10-2017, 14:59   #4 (permalink)
Member: 190274
Thanks Meter: 47
Flashing mine with same file. Its currently at 40%. You should charge battery at external source before flashing. It will work.
Old 02-10-2017, 15:00   #5 (permalink)
Member: 190274
Thanks Meter: 47
It looks like the unlock process messes with a partition, which makes it get stuck in download mode. Repartition during flash process should change that.
Old 02-10-2017, 15:04   #6 (permalink)
Member: 190274
Thanks Meter: 47
Process is done sucessfully. Phone is back to working state.
LG 2-3G Tool v9.32
Mode: Emergency
Model: LS775
Read info...
Model name: LGLS775
Android verion: 7.0
Phone mode is DOWNLOAD
Start flashing.
Open TOT File : M:\Work\LG\LS775\LS775ZV8_07.tot
Model : LGLS775
SwVersion : LS775ZV8
BuildTime :
Total Files : 22
Model name: LGLS775
Android verion: 7.0
Laf flash error: incompatible partition table [start] 01D56000:01D5BFDD, grow
Start direct download mode
Write "PrimaryGPT" partition #1 of 22
Write "sbl1" partition #2 of 22
Write "tz" partition #3 of 22
Write "hyp" partition #4 of 22
Write "rpm" partition #5 of 22
Write "aboot" partition #6 of 22
Write "sbl1bak" partition #7 of 22
Write "tzbak" partition #8 of 22
Write "hypbak" partition #9 of 22
Write "rpmbak" partition #10 of 22
Write "abootbak" partition #11 of 22
Write "persist" partition #12 of 22
Write "metadata" partition #13 of 22
Write "laf" partition #14 of 22
Write "boot" partition #15 of 22
Write "recovery" partition #16 of 22
Write "recoverybak" partition #17 of 22
Write "sec" partition #18 of 22
Write "factory" partition #19 of 22
Write "modem" partition #20 of 22
Write "carrier" partition #21 of 22
Write "system" partition #22 of 22
Erase "rct" partition
Done.
Elapsed: 286 secs. --> (v9.32)
Make sure to boot to recovery mode and do hard reset to prevent force close of settings app after flashing
The Following 5 Users Say Thank You to hiroprotagonist For This Useful Post:
Old 02-10-2017, 19:46   #7 (permalink)
Member: 383903
Thanks Meter: 3
can you please share the flash file???
The Following User Says Thank You to john r For This Useful Post:
Old 02-10-2017, 19:47   #8 (permalink)
Member: 383903
Thanks Meter: 3
LG 2-3G Tool v9.32
Mode: Emergency
Model: LS775
Read info...
Model name: LGLS775
Android verion: 7.0
Start flashing.
Model : LGLS775
BuildTime :
Total Files : 22
Model name: LGLS775
Android verion: 7.0
Done.
please share the flash file, link not working.... thaks
Old 02-10-2017, 19:48   #9 (permalink)
Member: 383903
Thanks Meter: 3
can you please share the flash file?? link not working!!
thanks
Old 02-11-2017, 09:52   #10 (permalink)
maplegsm's Avatar
Member: 391664
Sonork: Python
Thanks Meter: 1,063
thanks
link working perfect just login facebook id in browser than download
Old 02-13-2017, 09:08   #11 (permalink)
Member: 190274
Thanks Meter: 47
Here it is: Download LS775ZV8 zip
The Following 6 Users Say Thank You to hiroprotagonist For This Useful Post:
Old 02-25-2017, 17:39   #12 (permalink)
Member: 2382052
Thanks Meter: 1,511
i can flash this file in zv9 , my phone stuck in logo but have zv9
The Following User Says Thank You to maxpatri9 For This Useful Post:
Old 02-27-2017, 10:17   #13 (permalink)
andrew_tm's Avatar
Member: 445973
Thanks Meter: 3,489
You can't more unlock Sprint phone with Android 7 because LG add firmware sign. You can't write in phone only signed firmware.
For repair phone:
Put phone in Download mode
Reflash with last firmwares
The Following User Says Thank You to andrew_tm For This Useful Post:
Old 03-15-2017, 14:51   #14 (permalink)
Member: 593061
Thanks Meter: 19
downgrade is possible
LG 2-3G Tool v9.32
Mode: Emergency
Model: LS775
Read info...
Model name: LGLS775
Software verion: LS775ZV9
Android verion: 7.0
IMEI: 990002070889009
Start flashing.
Open TOT File : Y:\Celulares\GSM\Flash\LG LS775\LS775ZV8_07\LS775ZV8_07.tot
Model : LGLS775
BuildTime :
Total Files : 21
Model name: LGLS775
Android verion: 7.0
Write "PrimaryGPT" partition #1 of 21
Write "sbl1" partition #2 of 21
Write "tz" partition #3 of 21
Write "hyp" partition #4 of 21
Write "rpm" partition #5 of 21
Write "aboot" partition #6 of 21
Write "sbl1bak" partition #7 of 21
Write "tzbak" partition #8 of 21
Write "hypbak" partition #9 of 21
Write "rpmbak" partition #10 of 21
Write "abootbak" partition #11 of 21
Write "persist" partition #12 of 21
Write "metadata" partition #13 of 21
Write "laf" partition #14 of 21
Write "boot" partition #15 of 21
Write "recovery" partition #16 of 21
Write "recoverybak" partition #17 of 21
Write "sec" partition #18 of 21
Write "factory" partition #19 of 21
Write "modem" partition #20 of 21
Write "system" partition #21 of 21
Done.
Elapsed: 249 secs. --> (v9.32)
after hard reset
The Following 3 Users Say Thank You to juan_junior99 For This Useful Post:
Old 03-16-2017, 07:22   #15 (permalink)
Redtan_70's Avatar
Member: 785142
Sonork: 100.1606160
Thanks Meter: 177
can you share the firmware pls....LS775ZV5
The Following User Says Thank You to Redtan_70 For This Useful Post:
Page generated in 0.25410 seconds with 8 queries
