03-22-2010, 04:47 | #646 (permalink) |
No Life Poster Join Date: Jan 2010 Location: Sydney Age: 37
Member: 1205146 Status: Offline Thanks Meter: 879 | E1080T Unlock Done! Code: Last version on support: 2G tools v3.4.0034 Selected model: E1080T Selected com port: COM16 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Sending loader1... OK Flash ID: 54 Sending loader2... OK Unlock block Unlock block Unlock - ok If lock - not deactivate: Please make full reset *2767*3855# + input code #7465625*638*00000000# Elapsed time: 53 second, sw ver: 3.4.0034 ------------------------------------------------------------------------------- |
The Following User Says Thank You to Little_Master For This Useful Post: |
03-22-2010, 19:19 | #648 (permalink) |
No Life Poster Join Date: Jan 2009 Location: cameroon
Member: 953931 Status: Offline Sonork: 1652252 Thanks Meter: 897 | samsung u600 unlock done!! Last version on support: 2G tools v3.4.0034 Selected model: U600 Selected com port: COM146 Selected speed port: 460800 Phone must be ON! Please, connect phone Entering TestMode... OK SW: U600XXGD2 Langpack: Austria, Belgium, France, Germany, Hungary, Italy, Spain, United Kingdom IMEI: Read - fail! S/N: Read - fail! HW-> Read - fail! Phone password: Read - fail! Sum Flash: 1 Flash Prod ID: 0ec Flash Device ID: 22fd0000 Flash size: 33554432 Bytes Flash sectors: 519 sectors Bluetooth ID: BT not found Status OTP: OTP is dead ! MSL DEACTIVATED - TRUE Locks is active [NETLOCK]: Use #0111*11287813# for deactivate this lock [SIMLOCK]: Use #0141*00000000# for deactivate this lock Read info - ok Elapsed time: 70 second, sw ver: 3.4.0034 ------------------------------------------------------------------------------- |
03-23-2010, 08:27 | #651 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Timeless zone! Age: 35
Member: 152244 Status: Offline Sonork: 100.1591179 Thanks Meter: 162 | I8320 Unlock successful! Thats how do it! Enter *#7284# select usb settings....Select Usb-Phone(Modem) Chip and press select button (Top right side of screen) Now Enter *#9090# and select 1st option! Now connect cable to phone and phone will ask "Diagnose WM Port" drivers just install and open z3x soft! select correct model and select Diagnose port number in soft and press Unlock SP! Here is Log! |
03-23-2010, 14:23 | #655 (permalink) |
No Life Poster Join Date: Sep 2005 Location: Africa
Member: 181277 Status: Offline Thanks Meter: 84 | S8000 DONE AFTER PATCH HERE IS THE LOG Reading file as S8000... ok Model: S8000 Version: S8000XEIG2 Info: Patched for unlock Checking ports... ok Searching Samsung USB interface... detected (COM58) Checking mobile state... flash Searching phone at COM interface... unable to find phone Searching Samsung USB Flash interface... detected (COM58) Request error! Searching Qualcomm USB interface... not found Searching phone at COM interface... unable to find phone COM or QUALCOMM interface required Searching Samsung USB Flash interface... not found Set phone in flash mode Searching Samsung USB Flash interface... detected (COM58) Sending file 1 of 5... sended Sending file 2 of 5... sended Sending file 3 of 5... sended Sending file 4 of 5... sended Sending last file... sended Flashing done (time - 00:04:19) Searching Samsung USB interface... detected (COM58) Checking mobile state... normal Model: S8000 SW: S8000XEIG2 IMEI: 352028031974236 Unlock as MSL3... Calculating codes... OK (time - 00:00:36) Freeze code... 68586936 NET lock code... 30206481 Sub lock code... 00000000 SP lock code... 00000000 CP lock code... 00000000 SIM lock code... 00000000 Multi lock... 00000000 How to enter codes: NET: #7465625*638*30206481# Sub: #7465625*782*00000000# SP: #7465625*77*00000000# CP: #7465625*27*00000000# SIM: #7465625*746*00000000# For check lock status: *#7465625# Searching Samsung USB interface... detected (COM58) Checking mobile state... normal Model: S8000 SW: S8000XEIG2 IMEI: 352028031974236 Unlock as MSL3... OK (time - 00:00:01) |
03-24-2010, 04:59 | #658 (permalink) |
No Life Poster Join Date: Nov 2007 Location: United State Of Islam Age: 34
Member: 624551 Status: Offline Sonork: 100.1584837 Thanks Meter: 737 | successfull unlocked U600 and J700i.........thanx to zx3 team.... ======================================= Selected model: U600 Selected com port: COM38 Selected speed port: 460800 Phone must be ON! Please, connect phone Entering TestMode... OK SW: U600BBIHC1 Langpack: Not found langpack ! IMEI: 35300502982220 S/N: R1VQ620537 HW-> MP 0.500 Phone password: 00000000 Sum Flash: 1 Flash Prod ID: 0ec Flash Device ID: 22fd0000 Flash size: 33554432 Bytes Flash sectors: 519 sectors Bluetooth ID: 0021d1-46e3e5 Status OTP: OTP is ok ! MSL DEACTIVATED - TRUE Locks is active [NETLOCK]: Use #0111*61275917# for deactivate this lock [SIMLOCK]: Use #0141*00000000# for deactivate this lock Read info - ok Elapsed time: 9 second, sw ver: 3.4.0033 ------------------------------------------------------------------------------- Selected model: U600 Selected com port: COM38 Selected speed port: 460800 Phone must be ON! Please, connect phone Entering TestMode... OK Start unlock........ SW: U600BBIHC1 IMEI: 35300502982220 MSL DEACTIVATED - TRUE NET and SIM lock - deactivated Phone password change into -> 00000000 Unlock - ok ============================= J700i logs............ ============== ------------------------------------------------------------------------------- Selected model: J700I Selected com port: COM38 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Use automatic parameters Phone in TAT MODE Phone IMEI: 35245003634476 Phone SW: J700IXAID1 Phone BT ADDR: 0025-66-5D32B2 Phone SN: RPDS593644 Deactivated MSL - TRUE [FREZEE]: 10924590 [NET Lock]: 00000000 [Subset Lock]: 00000000 [SP Lock]: 00000000 [CP Lock]: 00000000 [Sim Lock]: 00000000 Read info - ok Elapsed time: 6 second, sw ver: 3.4.0030 ------------------------------------------------------------------------------- Selected model: J700I Selected com port: COM38 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Use automatic parameters Phone in TAT MODE Phone IMEI: 35245003634476 Phone SW: J700IXAID1 Phone BT ADDR: 0025-66-5D32B2 Phone SN: RPDS593644 Deactivated MSL - TRUE All Code change to -> 00000000 Unlock - ok Elapsed time: 31 second, sw ver: 3.4.0030 ========================== with best wishes... |
The Following User Says Thank You to khalidjan For This Useful Post: |
03-24-2010, 10:12 | #660 (permalink) |
Member: 953931 Status: Offline Sonork: 1652252 Thanks Meter: 897 | samsung c140 read code done!! Phone must be ON! Please, connect phone Entering TestMode... OK SW: C140LPEHE1 Langpack: Not found langpack ! IMEI: 35694502344505 S/N: RUPQ953872 HW-> MPW0.901 Phone password: 00000000 Sum Flash: 1 Flash Prod ID: 0b0 Flash Device ID: 008d0000 Flash size: 8388608 Bytes Flash sectors: 67 sectors Bluetooth ID: BT not found Status OTP: OTP not present MSL DEACTIVATED - TRUE Locks is active [NETLOCK]: Use #0111*31338851# for deactivate this lock [SIMLOCK]: Use #0141*00000000# for deactivate this lock Read info - ok Elapsed time: 9 second, sw ver: 3.4.0034 ------------------------------------------------------------------------------- |
The Following User Says Thank You to fokal2008 For This Useful Post: |
Post here successfully unlock or IMEI repair LG | andrew_tm | Z3X-Team Products | 1841 | 07-06-2022 14:14 |
Post here successfully unlock or IMEI repair Infinity Box | R@ZIB-BD | Infinity-Box | 3 | 07-04-2014 16:37 |
Post here successfully unlock or IMEI repair LG | R@ZIB-BD | Z3X-Team Products | 2 | 02-01-2011 17:29 |
