Old 02-06-2018, 16:04   #16 (permalink)
Registered User
Member: 1295987
Thanks Meter: 4
i got s3 gear frontier with samsung lock ,can you help me please
sm-r760
Old 02-09-2018, 04:04   #17 (permalink)
Member: 420658
Thanks Meter: 211
Okidoki...
ODIN Protocol maybe easier...
Seems require TCP Server... Upload protocol was TCP Client...
First success... ODIN answer over WiFi with:
LOKE
Need some time to prepare files for sending few lines of HEX...
So I hope I will manage this year... dumping PIT from Gear over Wifi...
Best Regards
The Following 3 Users Say Thank You to adfree For This Useful Post:
Old 02-11-2018, 01:24   #18 (permalink)
Member: 420658
Thanks Meter: 211
Mühseelig ernährt sich das Eichhörnchen...
Its not so easy to find fully usable and easy to handle TCP Server Tool to fire up 25 Commands in a row...
Tried few Android apps on my GT-I9300... but limitation is to use more then 1 Command with 1024 byte to send... in HEX...
Similar problems with free available PC Windows Tools...
On Screenshot is result visible... after sent Command 2
First Command is easy... in ASCII or HEX...
ODIN or 4F44494E
Second command seems to show ODIN Protocol Version... IMHO.
Screenshot is valid for my both Wearables:
SM-R732
and
SM-R760
This shows my SM-Z130H also via USB...
And my old GT-I9300 shows lower "Protocol Version"... but Commands are same to dump PIT...
Now I think maybe I have more luck with NetCat on Windows PC...
And creating stupid Batch file *.bat
Maybe something like this work:
https://stackoverflow.com/questions/...tcp-connection
found the solution. Its nc 127.0.0.1 1200 < binary.bin In addition, if the response needs to be saved then
nc 127.0.0.1 1200 < binary.bin > response.bin
Need some time for tests...
Best Regards
Old 02-11-2018, 04:30   #19 (permalink)
Member: 420658
Thanks Meter: 211
Untested!
Status:
Feuchter Traum
Under Construction...
Based on this Theory:
This is my idea how to dump PIT... partition.pit from Wearables over WiFi... instead USB cable.
I will check my theory on my SM-R732 first... if nothing explode...
Then my SM-R760...
Now I have to fight with NetCat on my old Vista Notebook.
Best Regards
Old 02-11-2018, 06:26   #20 (permalink)
Member: 420658
Thanks Meter: 211
Seems easier... with NetCat...
Command looks like this:
nc -l -p 13579 < ODINcommand_full.bin > response_full.bin
But I have to put all 25 files -->into 1 single file
Best Regards
The Following 2 Users Say Thank You to adfree For This Useful Post:
Old 02-11-2018, 07:28   #21 (permalink)
Member: 420658
Thanks Meter: 211
First success to dump PIT partition.pit from Wearables over WiFi...
Tested with my 2 devices:
SM-R732
SM-R760
I see some red text on Screen... but at the moment I can ignore...
Tested only with Combination Firmware...
Own risk!
NetCat I have taken from here:
https://eternallybored.org/misc/netcat/
Tested on my old Windows Vista Notebook... with this Version:
netcat-win32-1.12.zip
I will check now if I can use Phone + Android App... to send these 25 KB...
to receive 7 KB result...
Best Regards
File Type: zip v4untested.zip (482 Bytes, 114 views)
The Following User Says Thank You to adfree For This Useful Post:
Old 02-13-2018, 03:54   #22 (permalink)
Member: 420658
Thanks Meter: 211
Stuck with Upload Commands...
As I have no newer device to connect via USB and to sniff what is send...
Download (Wireless) and
Upload (Wireless)
in rootfs.img
/usr/bin/wireless-download
Upload "Commands" RDX related seems:
wu_rdx_cmd_search_idx
wu_rdx_cmd_powerdown
wu_rdx_get_cmd_size
wu_rdx_cmd_preamble
wu_rdx_init
wu_rdx_cmd_search_addr
wu_rdx_cmd_data_transfer
wu_rdx_generate_log
wu_rdx_dump_info_init
wu_rdx_add_dump_entry
wu_rdx_handle_cmd
wu_rdx_do_upload_file
wu_rdx_send_cmd
wu_rdx_cmd_probe
wu_rdx_recv_ack
Download "Commands" netODIN related:
wd_odin_send_ack
wd_odin_handle_cmd
wd_odin_get_cmd_size
wd_odin_get_version
wd_odin_cmd_pit
wd_odin_cmd_xmit
My IDA qualities still 0
Attached are files from SM-R760... taken from different Firmware Versions...
Best Regards
Old 02-15-2018, 02:35   #23 (permalink)
Member: 420658
Thanks Meter: 211
Please I need Tester for dump/read PIT partition.pit via WiFi.
Thanx in advance.
I have tested with my SM-R732 and my SM-R760...
... with Combination Firmware only
On my old Notebook with 32 bit Windows Vista...
Need help to confirm it work... on normal Stock Firmware...
On Tizen 3 Firmware...
I have attached netcat + Batchfile + Command Binary in 1 package...
+ Video
Maybe somebody can test or have ideas how to improve netcat Batch...
So I don't need to press ctrl + c
Thanx in advance.
Best Regards
Old 02-15-2018, 03:11   #24 (permalink)
Member: 420658
Thanks Meter: 211
nc -l -w 5 -p 13579 < ODINcommand_full.bin > response_full.bin
-w 5 Parameter is for listen 5 seconds... so ctrl + c is obsolete...
Added corrected Version...
Best Regards
Old 03-09-2018, 14:13   #25 (permalink)
Member: 2806418
i write combination file on my gear s3.
Old 03-10-2018, 03:38   #26 (permalink)
Member: 420658
Thanks Meter: 211
If you need help.
Feel free to PM me.
@all
Meanwhile we have RL removed from few more devices.
For instance:
SM-R360 Gear Fit 2 = STEADY partition is on p15
SM-R730 series = STEADY partition is on p22
All possible if Combination Firmware is available...
And simple with WiFi only...
NO wires NO USB cable required
Only as info.
Still I need Korean Firmware or PIT file for:
SM-R765S
SM-R765K
SM-R765L
Nothing avalaible yet...
No Stock Firmware nor Combination FTMA nor FT30...
Best Regards
Old 03-10-2018, 04:35   #27 (permalink)
Member: 420658
Thanks Meter: 211
I am too old as it seems... or too much Vodka.
SM-R730 series have STEADY on partition 26...
Attached new RL off collection...
But SM-R360 p15 like SM-R760/SM-R770 is correct.
In theory it is very easy to identify where STEADY is...
1 way is to check simple PIT file... partition.pit
So no device mandatory to search for STEADY or to confirm it is correct...
Best Regards
The Following 5 Users Say Thank You to adfree For This Useful Post:
Old 03-10-2018, 05:43   #28 (permalink)
Member: 420658
Thanks Meter: 211
SM-R600 Gear Sport not tested...
No idea if Samsung changed something in Security...
STEADY partition is p17...
If somebody willing to test...
PM me for help.
Best Regards
Old 03-14-2018, 09:24   #29 (permalink)
Member: 420658
Thanks Meter: 211
CSC_OKS_R775SOKS2CQL2_usr.tar.md5
CP_R775SKSU2CQJ4_CL401035_QB7878159_SIGNED.tar.md5
BL_R775SKSU2CQL2_usr.tar.md5
AP_R775SKSU2CQL2_usr.tar.md5
We are coming closer...
Will test if PIT is signed with same key like SM-R765S...
Best Regards
Old 03-19-2018, 23:21   #30 (permalink)
Member: 420658
Thanks Meter: 211
Meanwhile we have 1 SM-R765 alive again.
With mix of sboot.bin + cm.bin from SM-R765S...
+ PIT from SM-R775
+ Firmware from SM-R775 (few files removed)...
We have now working CQL2 Firmware.
Best Regards
Page generated in 0.25343 seconds with 9 queries
