Old 06-07-2018, 19:16   #31 (permalink)
Member: 321632
Thanks Meter: 21
Pls help
Originally Posted by blang View Post
use last version of samsung tool pro with tab via server
Phone is rooted but when i unlock i had this problem
UNLOCK INSTRUCTIONS:
Phone must be rooted!
If the software can't root the phone automatically,
then you must root your device manually.
1. Power on the phone.
2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options',
go to 'Settings'-'Developer options' and enable 'USB debugging'.
3. Connect the phone to PC with USB cable, install drivers if needed.
4. Select device in ADB settings.
5. Press 'Unlock TMB via Server' button for direct unlock, write your login and password in window if it will appear.
(Login and password will be saved as default after first input and can be changed in settings)
To reset Google account activation lock:
1. ADB must be activated in any way (you can flash sBoot from combination firmware,
make sure, that you are not upgrade sBoot).
2. Connect the phone to PC with USB cable, install drivers if needed.
3. Select device in ADB settings.
4. Press 'Reset FRP' and follow the instructions in program.
5. When process done, press 'Back' on phone and perform factory reset from phone settings.
To reset Google account activation or Samsung reactivation lock:
1. Power on the phone in download mode (turn off phone, press vol.down + home + power).
3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock.
4. After phone reboot, go to settings and perform factory reset.
Operation: Unlock
Selected model: SM-G530T
Software version: 32.6
Checking Login and Password... OK
Ballance: 30 crd.
You have 30 credit(s) left. This operation takes 10 credits.Continue? Yes
Waiting ADB device... OK
Reading phone info...
Model: SM-G530T
Android version: 5.1.1
PDA version: G530TUVU1AOF8
CSC version: G530TTMB1AOF8
Phone version: G530TUVU1AOF8
Product code: SM2G530TZAATMB
CSC country code: USA
CSC sales code: TMB
Phone SN: R28GA194F6T
IMEI: 35912806447*****
HW version: REV0.1
RF cal date: 2015.10.15
Chip name: MSM8916
Modem board: MSM8916
Boot Warranty bit: 1
File not found, reinstall application
Done with Samsung Tool PRO v.32.6
Old 06-08-2018, 09:00   #32 (permalink)
Member: 321632
Thanks Meter: 21
Its look like nobody is here to help me.
Other box read phone correctly but dont have server logs in it.
Welcome to Octoplus Box Samsung software version 2.6.9
Connecting to server...
Username: ............
Authorizing...
Login error: Incorrect Username!
Performed by 2.6.9 Software version.
Platform: Samsung Android
Selected port: COM15
Phone was not found on the selected port!
Searching for USB diagnostic port...
Connecting to phone on COM447
Mode: Normal
Phone model: SM-G530T
Firmware compiled date: May 29 2015
Firmware compiled time: 04:00:00
Firmware released date: Jul 30 2015
Firmware released time: 13:09:01
Phone IMEI: 359128-06-447481-6
SW version: MPSS.DPM.2.0.c5-00083-M8936FAAAANUZM-1
Selected port: COM447
Operation: Unlock
Detected phone model: SM-G530T
Firmware compiled date: Thu Jul 30 13:55:26 KST 2015
SW version: G530TUVU1AOF8
Android version: 5.1.1 (LMY47X)
Sales code: TMB
Country: USA
HW platform: msm8916
HW Chip: MSM8916
HW Modem: MSM8916
SIM 1 status: absent
Codename: gprimeltetmo
Checking Root:
Phone is Rooted.
Connecting to modem port...
Found phone on COM448
Reading IMEI...OK
Connecting to server...OK
Checking smart card...OK
Username: ...............
Authorizing...failed
Login error: Wrong username!
Phone unlocking failed
This is purely Z3X software issue
Old 06-10-2018, 13:44   #33 (permalink)
Member: 2373688
Thanks Meter: 57
unlock for this model works fine. make sure you have enough server credit and also Samsung Pro Tool is updated to latest version. i have unlocked 4 of this model without problem.
check from here:
http://forum.gsmhosting.com/vbb/f453...l#post13150480
Old 06-10-2018, 13:46   #34 (permalink)
Member: 2373688
Thanks Meter: 57
Authorizing...
Mode: Normal
Operation: Unlock
Sales code: TMB
Country: USA
HW Chip: MSM8916
HW Modem: MSM8916
Checking Root:
Phone is Rooted.
Reading IMEI...OK
From your logs you are using Octopus and not Z3X. post in correct forum. dnt blame z3x please.
Old 09-09-2018, 20:03   #35 (permalink)
GalaxyVibe's Avatar
Member: 2577670
Thanks Meter: 883
I noticed that this model can be unlocked already when it has its original ESN. My question is, if I changed the cert file/ESN/IMEI, would I be able to still unlock the phone using the Z3X?
Old 09-11-2018, 22:47   #36 (permalink)
GalaxyVibe's Avatar
Member: 2577670
Thanks Meter: 883
Guys, the question is still unanswered: I noticed that this model can be unlocked already when it has its original ESN. My question is, if I changed the cert file/ESN/IMEI, would I be able to still unlock the phone using the Z3X?
Page generated in 0.17380 seconds with 8 queries
