06-07-2018, 19:16 | #31 (permalink) |
Insane Poster Join Date: Jul 2006 Location: Ghana, Akyem Oda
Member: 321632 Status: Offline Thanks Meter: 21 | Pls help UNLOCK INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock TMB via Server' button for direct unlock, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings) To reset Google account activation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP' and follow the instructions in program. 5. When process done, press 'Back' on phone and perform factory reset from phone settings. To reset Google account activation or Samsung reactivation lock: 1. Power on the phone in download mode (turn off phone, press vol.down + home + power). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. 4. After phone reboot, go to settings and perform factory reset. Operation: Unlock Selected model: SM-G530T Software version: 32.6 Checking Login and Password... OK Ballance: 30 crd. You have 30 credit(s) left. This operation takes 10 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-G530T Android version: 5.1.1 PDA version: G530TUVU1AOF8 CSC version: G530TTMB1AOF8 Phone version: G530TUVU1AOF8 Product code: SM2G530TZAATMB CSC country code: USA CSC sales code: TMB Phone SN: R28GA194F6T IMEI: 35912806447***** HW version: REV0.1 RF cal date: 2015.10.15 Chip name: MSM8916 Modem board: MSM8916 Boot Warranty bit: 1 File not found, reinstall application Done with Samsung Tool PRO v.32.6 |
06-08-2018, 09:00 | #32 (permalink) |
Member: 321632 Status: Offline Thanks Meter: 21 | Its look like nobody is here to help me. Other box read phone correctly but dont have server logs in it. Welcome to Octoplus Box Samsung software version 2.6.9 ----------------------------------------------------------------------------------- Connecting to server... Username: ............ Authorizing... Login error: Incorrect Username! Performed by 2.6.9 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM15 Selected model: SM-G530T Phone was not found on the selected port! Searching for USB diagnostic port... Connecting to phone on COM447 Mode: Normal Phone model: SM-G530T Firmware compiled date: May 29 2015 Firmware compiled time: 04:00:00 Firmware released date: Jul 30 2015 Firmware released time: 13:09:01 Phone IMEI: 359128-06-447481-6 SW version: MPSS.DPM.2.0.c5-00083-M8936FAAAANUZM-1 Performed by 2.6.9 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM447 Selected model: SM-G530T Operation: Unlock Detected phone model: SM-G530T Firmware compiled date: Thu Jul 30 13:55:26 KST 2015 PDA version: G530TUVU1AOF8 CSC version: G530TTMB1AOF8 SW version: G530TUVU1AOF8 Phone SN: R28GA194F6T Android version: 5.1.1 (LMY47X) Sales code: TMB Country: USA HW platform: msm8916 HW Chip: MSM8916 HW Modem: MSM8916 SIM 1 status: absent Codename: gprimeltetmo Checking Root: Phone is Rooted. Connecting to modem port... Found phone on COM448 Reading IMEI...OK ----------------------------------------------------------------------------------- Connecting to server...OK Checking smart card...OK Username: ............... Authorizing...failed Login error: Wrong username! Phone unlocking failed Performed by 2.6.9 Software version. ----------------------------------------------------------------------------------- This is purely Z3X software issue |
06-10-2018, 13:44 | #33 (permalink) |
Freak Poster Join Date: Apr 2015 Location: GHANA Age: 28
Member: 2373688 Status: Offline Thanks Meter: 57 | unlock for this model works fine. make sure you have enough server credit and also Samsung Pro Tool is updated to latest version. i have unlocked 4 of this model without problem. check from here: http://forum.gsmhosting.com/vbb/f453...l#post13150480 |
06-10-2018, 13:46 | #34 (permalink) | |
Member: 2373688 Status: Offline Thanks Meter: 57 | Quote:
From your logs you are using Octopus and not Z3X. post in correct forum. dnt blame z3x please. | |
09-09-2018, 20:03 | #35 (permalink) |
No Life Poster Join Date: May 2016
Member: 2577670 Status: Offline Thanks Meter: 883 | I noticed that this model can be unlocked already when it has its original ESN. My question is, if I changed the cert file/ESN/IMEI, would I be able to still unlock the phone using the Z3X? |
09-11-2018, 22:47 | #36 (permalink) |
Member: 2577670 Status: Offline Thanks Meter: 883 | Guys, the question is still unanswered: I noticed that this model can be unlocked already when it has its original ESN. My question is, if I changed the cert file/ESN/IMEI, would I be able to still unlock the phone using the Z3X? |
