Old 12-31-2013, 16:59   #46 (permalink)
robean's Avatar
Member: 538410
Sonork: 100.1590750
Thanks Meter: 193
same problem tried everything so waiting for redsn0w update hope to get soon
Old 12-31-2013, 17:34   #47 (permalink)
.::MASTER ALONE::.'s Avatar
Member: 1587480
Sonork: 100.1618317
Thanks Meter: 2,165
Download Again IPSW Other Site..
WBR.
Arsalan gsm2000.
Old 01-01-2014, 19:21   #48 (permalink)
robean's Avatar
Member: 538410
Sonork: 100.1590750
Thanks Meter: 193
WBR.
Arsalan gsm2000.
tried by restoring by only clicking restore and downloaded files perfectly work to other iphones 4 expect i got two phones facing 3194 error in middle currently in desk which are working fine in ios 6.1.3 before
Old 01-01-2014, 20:18   #49 (permalink)
GSMTURBO's Avatar
Member: 479496
Sonork: 1592751
Thanks Meter: 404
its hardware open is there any shortge ? post result
Old 01-02-2014, 01:03   #50 (permalink)
taleb_amine8's Avatar
Member: 223552
Thanks Meter: 63
this error come when using tinyumbrella
you can fix it by deleting host file from c:- windows - system32 - driver -etc
Old 01-02-2014, 04:59   #51 (permalink)
Member: 1625592
Thanks Meter: 6
Exactly it's hw and only sw way may help us is to wait for sn0wbreez or other custom fw makers to make some fw to restore w/o bb chk.
Sent from my HTC Desire SV using Tapatalk
Old 01-02-2014, 05:25   #52 (permalink)
mmrozibul's Avatar
Member: 725443
Sonork: 100.1601305
Thanks Meter: 330
Its not hardware its host issue, 100% solved by edit host...
Do it step by step
FIRST CHECK BATTERY IS WELL CHARGED
1.disconnect internet
2.uninstall itunes
3.restart pc > install again
4. go to windows>system32>Drivers>etc>hosts
5. open file in notepad and edit like below..
# 127.0.0.1 localhost > keep till this line
74.208.10.249 gs.apple.com > delete this line or any extra line below this
6. Restart pc
7. disable antivirus and windows firewall or all firewall
8. Reconnect internet
9. Open itunes now then shift+Restore (USE GOOD CABLE and BACK USB PORT ,dont use front usb or hub or usb extension cable)
will be Done 100000%....
[PS:If not ok , then try to change phone battery or charge manually and try again..]
Br, Rozibul Islam
Old 01-02-2014, 05:33   #53 (permalink)
nnaeem11's Avatar
Member: 144640
Sonork: nnaeem11
Thanks Meter: 238
error 3194 comes in between the flashing like the last part of writing the modem file so its a hardware issue so better test for the hardware
some lucky guys can bypass this error try after some time of rest some this this error passes automatically
Old 01-09-2014, 15:28   #54 (permalink)
Member: 2024585
[14:26:28.0265] Failure Description:
[14:26:28.0265] Depth:0 Error:AMRestorePerformRestoreModeRestoreWithError failed with error: 3194
[14:26:28.0265] Depth:1 Error:The operation couldn’t be completed. (AMRestoreErrorDomain error 3194 - Failed to handle data request message)
[14:26:28.0265] Depth:2 Error:The operation couldn’t be completed. (AMRestoreErrorDomain error 3194 - Failed to handle baseband updater request)
any ideas?
Old 01-18-2014, 10:06   #55 (permalink)
Member: 375784
Sonork: 100.112240
Thanks Meter: 75
I have 3 board iphone 4
when i change 8824 To 337S its ok and restore complate
but dont active with new imei
error 3194 is HW
if U can downgrad to ios 6 solved your problam
cpu 8824 dont update
just use 4.12.05 can not update to 4.12.09
u can change a new 8824 and change imei and sn with unlock dongle
Old 01-18-2014, 16:32   #56 (permalink)
Member: 709604
Thanks Meter: 173
Error 3194: Resolve error 3194 by updating to the latest version of iTunes. "This device is not eligible for the requested build" in the updater logs confirms this is the root of the issue.
Old 02-16-2014, 20:01   #57 (permalink)
gwlime's Avatar
Member: 1493085
Sonork: n/a
Thanks Meter: 92
Do it step by step
2.uninstall itunes
6. Restart pc
Br, Rozibul Islam
thx bro
but i use this method without uninstall iTunes & restar my PC
just edit my host file like bro mmrozibul say
win7 ultimate x86
iTunes v.11.1.4.62 last update 17feb2014
Old 02-17-2014, 18:22   #58 (permalink)
Cheater -Don't Deal with him-
Member: 2089356
Sonork: Threema: 3N5W6VV9
Thanks Meter: 520
man a lot of this issue from ioos 6.1.3 to ios 7 so screw you iphone switch to android
Old 02-18-2014, 10:19   #59 (permalink)
Member: 1481927
exit recovery using tinyumbrella and update your itunes to last version then try again
Old 03-18-2014, 17:37   #60 (permalink)
saydajan's Avatar
Member: 1318893
Sonork: 100.1640487
Thanks Meter: 279
yes bro this is hard ware problem , its bcs of baseband ic, bcws in some phones the base band is chage in Dubai and hongkong after they put another ic which cant be restor to other version any more. check inside the u will find chines sticcker in it,
Page generated in 0.20795 seconds with 8 queries
