01-01-2014, 19:21 | #48 (permalink) |
No Life Poster Join Date: Jul 2007 Location: Vancouver BC & Kathmandu Nepal
Member: 538410 Status: Offline Sonork: 100.1590750 Thanks Meter: 193 | tried by restoring by only clicking restore and downloaded files perfectly work to other iphones 4 expect i got two phones facing 3194 error in middle currently in desk which are working fine in ios 6.1.3 before |
01-02-2014, 04:59 | #51 (permalink) |
Junior Member Join Date: Jul 2011 Location: Iran
Member: 1625592 Status: Offline Thanks Meter: 6 | Exactly it's hw and only sw way may help us is to wait for sn0wbreez or other custom fw makers to make some fw to restore w/o bb chk. Sent from my HTC Desire SV using Tapatalk |
01-02-2014, 05:25 | #52 (permalink) |
No Life Poster Join Date: Mar 2008 Location: Inside Technology
Member: 725443 Status: Offline Sonork: 100.1601305 Thanks Meter: 330 | Its not hardware its host issue, 100% solved by edit host... Do it step by step FIRST CHECK BATTERY IS WELL CHARGED 1.disconnect internet 2.uninstall itunes 3.restart pc > install again 4. go to windows>system32>Drivers>etc>hosts 5. open file in notepad and edit like below.. # 127.0.0.1 localhost > keep till this line 74.208.10.249 gs.apple.com > delete this line or any extra line below this 6. Restart pc 7. disable antivirus and windows firewall or all firewall 8. Reconnect internet 9. Open itunes now then shift+Restore (USE GOOD CABLE and BACK USB PORT ,dont use front usb or hub or usb extension cable) will be Done 100000%.... [PS:If not ok , then try to change phone battery or charge manually and try again..] Br, Rozibul Islam |
01-02-2014, 05:33 | #53 (permalink) |
No Life Poster Join Date: May 2005 Location: MIND MAKING COMPANY Age: 44
Member: 144640 Status: Offline Sonork: nnaeem11 Thanks Meter: 238 | error 3194 comes in between the flashing like the last part of writing the modem file so its a hardware issue so better test for the hardware some lucky guys can bypass this error try after some time of rest some this this error passes automatically |
01-09-2014, 15:28 | #54 (permalink) |
Junior Member Join Date: Sep 2013
Member: 2024585 Status: Offline Thanks Meter: 0 | [14:26:28.0265] Failure Description: [14:26:28.0265] Depth:0 Error:AMRestorePerformRestoreModeRestoreWithError failed with error: 3194 [14:26:28.0265] Depth:1 Error:The operation couldn’t be completed. (AMRestoreErrorDomain error 3194 - Failed to handle data request message) [14:26:28.0265] Depth:2 Error:The operation couldn’t be completed. (AMRestoreErrorDomain error 3194 - Failed to handle baseband updater request) any ideas? |
01-18-2014, 10:06 | #55 (permalink) |
Insane Poster Join Date: Oct 2006 Age: 37
Member: 375784 Status: Offline Sonork: 100.112240 Thanks Meter: 75 | I have 3 board iphone 4 when i change 8824 To 337S its ok and restore complate but dont active with new imei error 3194 is HW if U can downgrad to ios 6 solved your problam cpu 8824 dont update just use 4.12.05 can not update to 4.12.09 u can change a new 8824 and change imei and sn with unlock dongle |
01-18-2014, 16:32 | #56 (permalink) |
Freak Poster Join Date: Feb 2008 Location: mumbai Age: 44
Member: 709604 Status: Offline Thanks Meter: 173 | Error 3194: Resolve error 3194 by updating to the latest version of iTunes. "This device is not eligible for the requested build" in the updater logs confirms this is the root of the issue. |
02-16-2014, 20:01 | #57 (permalink) | |
Freak Poster Join Date: Jan 2011 Location: Manila Age: 37
Member: 1493085 Status: Offline Sonork: n/a Thanks Meter: 92 | Quote:
but i use this method without uninstall iTunes & restar my PC just edit my host file like bro mmrozibul say win7 ultimate x86 iTunes v.11.1.4.62 last update 17feb2014 | |
03-18-2014, 17:37 | #60 (permalink) |
No Life Poster Join Date: Jun 2010 Location: Jalal Abad , Afghanistan
Member: 1318893 Status: Offline Sonork: 100.1640487 Thanks Meter: 279 | yes bro this is hard ware problem , its bcs of baseband ic, bcws in some phones the base band is chage in Dubai and hongkong after they put another ic which cant be restor to other version any more. check inside the u will find chines sticcker in it, |
