12-06-2013, 19:18 | #16 (permalink) | |
No Life Poster Join Date: Mar 2010 Location: unlockprice.com
Member: 1263622 Status: Offline Thanks Meter: 149 | Quote:
Change pc & use itunes 11 your problem solved 100% tested me.few time latest itunes problem.so use old version. | |
12-07-2013, 06:12 | #17 (permalink) |
Junior Member Join Date: Jul 2011 Location: Iran
Member: 1625592 Status: Offline Thanks Meter: 6 | that's right, it seems to be hardware BUT if there is any custom firmware for that then we could restore ios 7.0.4 or later without any 3194 at the middle of restore! |
12-07-2013, 06:38 | #18 (permalink) |
Insane Poster Join Date: Jun 2009 Location: chennai
Member: 1054903 Status: Offline Thanks Meter: 4 | Me to have same 3194 error on my windows pc when I try to update my customers ipad2 to ios 7.0.4. . Only this iPad is stuck at recovery mode. After some research I found that some times it's happens because of OS intrupt. So I installed another os inside my pc (VMware workstation.) and do the same thing. Succeed. Try in another operating system. |
12-07-2013, 08:42 | #20 (permalink) |
Crazy Poster Join Date: Dec 2010 Location: jakarta
Member: 1474081 Status: Offline Thanks Meter: 16 | I agree with haroon75 Edit host make this trouble (3194) Because my 4G 10000000000% good on 6.1.2 Then error when update to 7.0.4 on mac. But restore on windows with itunes 11.0.3 successss I am forget restore host on mac to standart. And success to downgrade again to 6.1.3 or 6.1.2 on windows using ifaith *itunes must lower 11.0.5 (recomended 11.0) doest work with latest itunes Sent from my iPhone using Tapatalk |
12-07-2013, 10:09 | #21 (permalink) | |
Member: 1625592 Status: Offline Thanks Meter: 6 | Quote:
also for downgrading : there was no shsh for that phone. | |
12-07-2013, 11:21 | #22 (permalink) | |
but: I've used to edit host file 2- i've used tiny here 3- i've used shsh using ifaith, redsnow and also tiny BUT NO SUCCESS | |
12-07-2013, 14:41 | #23 (permalink) | |
Freak Poster Join Date: Aug 2005
Member: 172543 Status: Offline Thanks Meter: 126 | Quote:
it is very easy just delet the host file from XP C:\WINDOWS\system32\drivers\etc and your problem will solve ERROR 3194 that because of using tinny umbrella regards | |
12-07-2013, 19:09 | #25 (permalink) |
Junior Member Join Date: Aug 2010 Location: India
Member: 1374289 Status: Offline Thanks Meter: 1 | That is not a hardware problem. Error 3194 means there is error between verifying the iOS with apple servers. This usually happen with unsigned / no longer signed by apple / custom firmwares. As already suggested by other members you can manipulate host file. Try latest iTunes version with another copy iOS 7.0.4. Disable any anti virus / firewall in use. Try different machine. |
12-08-2013, 00:10 | #29 (permalink) |
No Life Poster Join Date: May 2010 Location: EGYPT Age: 39
Member: 1298774 Status: Offline Sonork: 100.1584126 Thanks Meter: 94 | I think this error from apple maybe im not sure but i have this problem in iphone 4g work ok before make restore to 7.0.4 MAHMOUD™ |
12-08-2013, 04:02 | #30 (permalink) |
Member: 1474081 Status: Offline Thanks Meter: 16 | Before all of you doing anything if got this error First see itunes error log restore if you are on mac : ~/Library/Log/iPhone Updater Logs/ i dont know if on windows Sent from my iPhone using Tapatalk |
