03-27-2010, 16:20 | #1 (permalink) |
Freak Poster Join Date: Jul 2005 Location: Manchester Age: 43
Member: 160666 Status: Offline Thanks Meter: 7 | GT505 problem after unlock |
03-27-2010, 16:29 | #3 (permalink) |
Member: 160666 Status: Offline Thanks Meter: 7 | SIGNED MODE (USING SERVER) CFG:100000000000 ChipID900,EMP protocol:0401 BOOTROM MODE DETECTED OTP DBG: [1,54,0,35469503006149] OTP LOCKED:1 CID:54 PAF:0 IMEI:35469503006149 CERT:RED LDR:080805 1255 YTRCXC1723918_A2_DB3200_PRODUCTION_LOADER_ACC_SDRA M_P2B LDR CAPS:SYSTEM SIGNATURE LDR:080905 0936 YTRCXC1723919_1A2_DB3200_PRODUCTION_LOADER_APP_SDR AM_JEFF_CABS_P2D LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM writing "C:\Documents and Settings\Owner\My Documents\Setool Flash File\GT505\cxc000000_APPLICATION_PHONE_SB_IAR-ARM-NAND.ssw" ALLOWED DOMAINS:BLUE BROWN RED MAXIMUM CID:54 Will flash 634 blocks... ssw file accepted writing "C:\Documents and Settings\Owner\My Documents\Setool Flash File\GT505\CXC_FS_CABS_LP_NAND_commercial_STL.ssw" ALLOWED DOMAINS:BLUE BROWN RED MAXIMUM CID:54 Will flash 1556 blocks... ssw file accepted writing "C:\Documents and Settings\Owner\My Documents\Setool Flash File\GT505\CXC_LGPXO_SYS_CABS_LP_NAND_commercial.s sw" ALLOWED DOMAINS:BLUE BROWN RED MAXIMUM CID:54 Will flash 335 blocks... ssw file accepted Phone detached Elapsed: 642 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED PLEASE CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5") CFG:110000000000 ChipID900,EMP protocol:0401 BOOTROM MODE DETECTED OTP DBG: [1,54,0,35469503006149] OTP LOCKED:1 CID:54 PAF:0 IMEI:35469503006149 CERT:RED ALTERNATIVE SECURITY BYPASS NOT SUPPORTED FOR THAT PHONE Elapsed: 6 secs. SIGNED MODE (USING SERVER) CFG:100000000000 ChipID900,EMP protocol:0401 BOOTROM MODE DETECTED OTP DBG: [1,54,0,35469503006149] OTP LOCKED:1 CID:54 PAF:0 IMEI:35469503006149 CERT:RED LDR:080805 1255 YTRCXC1723918_A2_DB3200_PRODUCTION_LOADER_ACC_SDRA M_P2B LDR CAPS:SYSTEM SIGNATURE LDR:080905 0936 YTRCXC1723919_1A2_DB3200_PRODUCTION_LOADER_APP_SDR AM_JEFF_CABS_P2D LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM writing "C:\Documents and Settings\Owner\My Documents\Setool Flash File\GT505\cxc000000_APPLICATION_PHONE_SB_IAR-ARM-NAND.ssw" ALLOWED DOMAINS:BLUE BROWN RED MAXIMUM CID:54 Will flash 635 blocks... ssw file accepted writing "C:\Documents and Settings\Owner\My Documents\Setool Flash File\GT505\GT505_CXC_FS_CABS_LP_NAND_EUR_Open_comm ercial.ssw" ALLOWED DOMAINS:BLUE BROWN RED MAXIMUM CID:54 Will flash 1425 blocks... ssw file accepted writing "C:\Documents and Settings\Owner\My Documents\Setool Flash File\GT505\GT505_CXC_LGPXO_SYS_CABS_LP_NAND_EUR_Op en_commercial.ssw" ALLOWED DOMAINS:BLUE BROWN RED MAXIMUM CID:54 Will flash 332 blocks... ssw file accepted Phone detached Elapsed: 607 secs. |
03-27-2010, 16:41 | #4 (permalink) |
No Life Poster Join Date: Jun 2006 Location: {JUST@PRAY@FOR@ME} Age: 39
Member: 288504 Status: Offline Sonork: .:100.1587032:. Thanks Meter: 2,266 | first reflash phone fully with latest firmware version. if that not help, then 1. select proper model, on settings check only "signed mode" 2. add to firmware area gt505_syspart_fix.ssw 3. press unlock 4. press clear name 5. reflash phone fully if phone still hangs on lg logo, redo operation with different step 2: add to firmware area gt505_syspart_fix.ssw,gt505_drm_fix.ssw 6. if needed, write gdfs package from proper model working phone, unlock phone after. |
03-27-2010, 16:49 | #7 (permalink) |
Freak Poster Join Date: May 2007 Location: aiurea`n tramvai !
Member: 514081 Status: Offline Thanks Meter: 82 | After unlock GT505 die but unlock is ok !!! After unlock GT505 die but unlock is ok !!! solution : after unlock FLASH phone with gt505 and everything is ok !!! do NOT write GDFS or another metod.... BR , dan.g |
03-27-2010, 17:26 | #11 (permalink) | |
Member: 288504 Status: Offline Sonork: .:100.1587032:. Thanks Meter: 2,266 | Quote:
For More Help Read FAQ step by step thx.... | |
03-29-2010, 08:23 | #15 (permalink) |
No Life Poster Join Date: Apr 2006
Member: 263686 Status: Offline Thanks Meter: 62 | gt500 suc flash with setool RUNNING v0.915061/UNI CARD SERIAL 00108977 PLEASE UPGRADE USBFLASH DRIVER 02.01.00.00 SIGNED MODE (USING SERVER) CFG:100100000000 ChipID900,EMP protocol:0401 BOOTROM MODE DETECTED OTP DBG: [1,54,0,35469403069340] OTP LOCKED:1 CID:54 PAF:0 IMEI:35469403069340 CERT:RED LDR:080805 1255 YTRCXC1723918_A2_DB3200_PRODUCTION_LOADER_ACC_SDRA M_P2B LDR CAPS:SYSTEM SIGNATURE LDR:080905 0936 YTRCXC1723919_1A2_DB3200_PRODUCTION_LOADER_APP_SDR AM_JEFF_CABS_P2D LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM writing "D:\dongle original\setool\FLASH ALL\lg\gt500\BIN-GT500AT-00-V10c-EUR-XXX-OCT-01-2009+0.rar" bad file, will not flash it. Elapsed: 53 secs. SIGNED MODE (USING SERVER) CFG:100100000000 ChipID900,EMP protocol:0401 BOOTROM MODE DETECTED OTP DBG: [1,54,0,35469403069340] OTP LOCKED:1 CID:54 PAF:0 IMEI:35469403069340 CERT:RED LDR:080805 1255 YTRCXC1723918_A2_DB3200_PRODUCTION_LOADER_ACC_SDRA M_P2B LDR CAPS:SYSTEM SIGNATURE LDR:080905 0936 YTRCXC1723919_1A2_DB3200_PRODUCTION_LOADER_APP_SDR AM_JEFF_CABS_P2D LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM writing "D:\dongle original\setool\FLASH ALL\lg\gt500\BIN-GT500AT-00-V10c-EUR-XXX-OCT-01-2009+0\cxc000000_APPLICATION_PHONE_SB_IAR-ARM-NAND.ssw" ALLOWED DOMAINS:BLUE BROWN RED MAXIMUM CID:54 Will flash 632 blocks... ssw file accepted writing "D:\dongle original\setool\FLASH ALL\lg\gt500\BIN-GT500AT-00-V10c-EUR-XXX-OCT-01-2009+0\CXC_FS_CABS_LP_NAND_commercial.ssw" ALLOWED DOMAINS:BLUE BROWN RED MAXIMUM CID:54 Will flash 1461 blocks... ssw file accepted writing "D:\dongle original\setool\FLASH ALL\lg\gt500\BIN-GT500AT-00-V10c-EUR-XXX-OCT-01-2009+0\CXC_LGPXO_SYS_CABS_LP_NAND_commercial.ssw" ALLOWED DOMAINS:BLUE BROWN RED MAXIMUM CID:54 Will flash 332 blocks... ssw file accepted |
R210 - dispaly contrast problem after unlock - help pls! | chrisro | VLSI, Conexant, Skyworks and Old Models | 20 | 11-23-2006 00:52 |
Problem after unlock be5 123 call provider | indel306 | Alcatel & TCL Old Models | 1 | 05-30-2002 09:06 |
Display problem after unlocking T10s 00w48 | Rik | Old Ericsson Phones & Sony Phones | 9 | 03-20-2001 19:07 |
SH 888 - problem after unlocking | mobitech | Old Ericsson Phones & Sony Phones | 0 | 08-20-2000 12:42 |
Help on GD90 non-stop charging problem after unlocking... | X-Shadow | Various | 1 | 02-08-2000 19:44 |
