10-01-2013, 00:10 | #21 (permalink) |
Junior Member Join Date: Jun 2010 Location: morocco
Member: 1320807 Status: Offline Thanks Meter: 2 | procedure for 5 locks repair: * no need credits * A2 tab select model * click browse file under MISCfiles: * load backup * click Write ****** * your done in restoring locks * then click J108i Bypass tab * click step 3 Unlock again * then follow procedure * your done ..... no need credits |
10-01-2013, 10:32 | #22 (permalink) |
Freak Poster Join Date: Jan 2011 Location: bangladesh
Member: 1483660 Status: Offline Sonork: 100.1601918 Thanks Meter: 155 | j108 unlock 2 set unlock problem OTP: LOCKED:1 CID:81 PAF:1 IMEI:01248600682668 CERT:RED Checking for signature ... Waiting for calculation process ... request denied. signature calculation not done,err: 144 Elapsed: 10 secs. SIGNED MODE (USING SERVER) CFG:100000000000 my 6 CREDITS is gone but set not unlock current updater version: 0.95 current setool2 version: 1.1301 SERVER CREDITS LEFT/USED: 23/7 pls talk me what can i do thans setool team |
04-17-2014, 09:42 | #24 (permalink) | |
No Life Poster Join Date: Oct 2011 Location: Punjab
Member: 1675429 Status: Offline Sonork: 1609235 Thanks Meter: 174 | Quote:
Its working solution. i don,t install new firmware as mention, i just unlock on giving setting and unlock done without cutting credits. Thanks | |
04-21-2014, 09:57 | #25 (permalink) |
No Life Poster Join Date: Nov 2005 Location: india Age: 45
Member: 201107 Status: Offline Sonork: 100.1576954 Thanks Meter: 737 | I need to restore back up once, but i do it smoothly. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:110010000000 ChipID: F100, EMP protocol: 0401 BOOTROM MODE DETECTED OTP DBG: [1,81,1,01261100xxxxx] OTP: LOCKED:1 CID:81 PAF:1 IMEI:012611002xxxxx CERT:RED LDR: 2010-03-02 18:05 1212-4656_DB3350_CS_LOADER_ACC_SDRAM_R2A096 LDR: 2010-03-02 18:06 1212-4655_DB3350_CS_LOADER_APP_SDRAM_R2A096 Insert Memory CARD into phone Insert TEST SIM CARD into phone POWER ON phone After setup complete, POWER OFF phone Then proceed to Step 2 Elapsed: 13 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:110010000000 ChipID: F100, EMP protocol: 0401 BOOTROM MODE DETECTED OTP DBG: [1,81,1,01261100xxxxx] OTP: LOCKED:1 CID:81 PAF:1 IMEI:01261100xxxxx CERT:RED LDR: 2010-03-02 18:05 1212-4656_DB3350_CS_LOADER_ACC_SDRAM_R2A096 LDR: 2010-03-02 18:06 1212-4655_DB3350_CS_LOADER_APP_SDRAM_R2A096 Insert Memory CARD into phone Insert TEST SIM CARD into phone POWER ON phone Set "USB MODE" in phone settings to "File transfer" Copy file from card folder other\executor.b to : C:\Documents and Settings\ultimate\Desktop\v1.1404\backup\01261100x xxxx POWER OFF phone Then proceed to Step 3 Elapsed: 13 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:110010000000 ChipID: F100, EMP protocol: 0401 BOOTROM MODE DETECTED OTP DBG: [1,81,1,01261100xxxxx] OTP: LOCKED:1 CID:81 PAF:1 IMEI:01261100xxxxx CERT:RED SECURITY UNITS NOT PREPARED Elapsed: 8 secs. SIGNED MODE (USING SERVER) CFG:100000000000 Processing script "C:\Documents and Settings\ultimate\Desktop\v1.1404\backup\012611002 xxxxx\01261100xxxxx_4_21_2014_2_08_49_ ... ChipID: F100, EMP protocol: 0401 BOOTROM MODE DETECTED OTP DBG: [1,81,1,01261100xxxx] OTP: LOCKED:1 CID:81 PAF:1 IMEI:01261100 CERT:RED LDR: 2010-03-02 18:05 1212-4656_DB3350_CS_LOADER_ACC_SDRAM_R2A096 LDR CAPS: SYSTEM FLASH SIGNATURE AUTH LDR: 2010-03-02 18:06 1212-4655_DB3350_CS_LOADER_APP_SDRAM_R2A096 LDR CAPS: SYSTEM FLASH GDFS FILESYSTEM TA Writing TA var 0002/1062/01AE Writing TA var 0002/1063/006A Writing TA var 0002/1064/0028 Writing TA var 0002/1037/044D Elapsed: 12 secs. SIGNED MODE (USING SERVER) CFG:100000000000 ChipID: F100, EMP protocol: 0401 BOOTROM MODE DETECTED OTP DBG: [1,81,1,012611002xxxxx] OTP: LOCKED:1 CID:81 PAF:1 IMEI:012611002xxxxx CERT:RED SECURITY UNITS NOT PREPARED Elapsed: 6 secs. SIGNED MODE (USING SERVER) CFG:100000000000 ChipID: F100, EMP protocol: 0401 PHONE DOMAIN: "RETAIL" PHONE CID: 0081 OTP: LOCKED:1 CID:81 PAF:1 IMEI:01261100xxxxx CERT:RED Checking for signature ... Waiting for calculation process ... RESPONSE: "SUCCESS" [1038] LDR: 2010-03-02 18:05 1212-4656_DB3350_CS_LOADER_ACC_SDRAM_R2A096 LDR: 2010-03-02 18:06 1212-4655_DB3350_CS_LOADER_APP_SDRAM_R2A096 DISCONNECT PHONE NOW INSERT SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN INSTALL PHONE MODEM DRIVERS IF NEEDED SEARCHING FOR PHONE, "STOP" TO ABORT PHONE FOUND AT COM6 PHONE READY TO PROCEED EXECUTOR STARTED SEARCHING FOR PHONE, "STOP" TO ABORT PHONE FOUND AT COM6 PHONE READY TO PROCEED. GOT SEED: 002B8F19 ACTIVATION COMPLETED. USERCODE RESET TO "0000" DO NOT DISCONNECT PHONE FROM CABLE UNTIL PHONE TURNS ON BY ITSELF Elapsed: 201 secs. b.r. kalpesh varia |
06-16-2015, 10:58 | #28 (permalink) | |
Freak Poster Join Date: Oct 2006 Location: uk
Member: 372163 Status: Offline Thanks Meter: 57 | Quote:
12-28-2019, 22:55 | #29 (permalink) |
No Life Poster Join Date: Jan 2005 Location: ALGERIA Age: 53
Member: 112185 Status: Offline Sonork: 100.1612613 Thanks Meter: 163 | RUNNING v 1.1436/01.15/UNI SIGNED MODE (USING SERVER) CFG:101000000000 ChipID: F100, EMP protocol: 0401 R7EA011_1239-0125_GENERIC_HO PHONE DOMAIN: "RETAIL" PHONE CID: 0081 OTP: LOCKED:1 CID:81 PAF:1 IMEI:01248500153098 CERT:RED LDR: 2010-03-02 18:05 1212-4656_DB3350_CS_LOADER_ACC_SDRAM_R2A096 LDR CAPS: SYSTEM FLASH SIGNATURE AUTH LDR: 2010-03-02 18:06 1212-4655_DB3350_CS_LOADER_APP_SDRAM_R2A096 LDR CAPS: SYSTEM FLASH GDFS FILESYSTEM TA writing "C:\nacer\PHONE-FIRMWARE\SONY\R7EA011.APP_SW_1239_0125_GENERIC_HO_ REDBROWNBLUE_CID81_80_53_52_49_DB3350.SOFTWARE" ALLOWED DOMAINS: BLUE BROWN RED MAXIMUM CID: 81 Will flash 1009 blocks ... SSW file accepted writing "C:\nacer\PHONE-FIRMWARE\SONY\R7EA011.FS_ADRIATIC_HO_REDBROWNBLUE_ CID81_80_53_52_49.SOFTWARE" ALLOWED DOMAINS: BLUE BROWN RED MAXIMUM CID: 81 Will flash 2338 blocks ... SSW file accepted using GENERIC phone customization tpa/preset/custom/CONTENT_DOWNLOAD_HOOK.itm tpa/preset/custom/FM_PICTURES_HOOK_3.itm tpa/preset/custom/FM_SOUNDS_HOOK_3.itm tpa/preset/custom/FM_THEMES_HOOK_3.itm tpa/preset/custom/FM_VIDEOS_HOOK_3.itm tpa/preset/custom/GAMES_HOOK_3.itm tpa/preset/custom/MC_MUSIC_HOOK_3.itm tpa/preset/custom/MC_PHOTO_HOOK_3.itm tpa/preset/custom/MC_VIDEO_HOOK_3.itm tpa/preset/custom/ORG_APPLICATIONS_HOOK_3.itm tpa/preset/custom/preloaded_config.xml tpa/preset/custom/SETT_RINGTONE_HOOK_1.itm tpa/preset/custom/SETT_SCREENSAVER_HOOK_1.itm tpa/preset/custom/SETT_STARTSHOW_HOOK_1.itm tpa/preset/custom/SETT_WALLPAPER_HOOK_1.itm tpa/preset/custom/Customize.xml Elapsed: 1316 seconds SIGNED MODE (USING SERVER) CFG:100011000000 ChipID: F100, EMP protocol: 0401 R7EA011_1239-0125_GENERIC_HO PHONE DOMAIN: "RETAIL" PHONE CID: 0081 OTP: LOCKED:1 CID:81 PAF:1 IMEI:01248500153098 CERT:RED LDR: 2010-03-02 18:05 1212-4656_DB3350_CS_LOADER_ACC_SDRAM_R2A096 LDR CAPS: SYSTEM FLASH SIGNATURE AUTH LDR: 2010-03-02 18:06 1212-4655_DB3350_CS_LOADER_APP_SDRAM_R2A096 LDR CAPS: SYSTEM FLASH GDFS FILESYSTEM TA Executing CSCA-based unlock Checking for signature ... Waiting for calculation process ... RESPONSE: "SUCCESS" [1038] Backup security data ... Erasing locks ... DISCONNECT PHONE NOW REMOVE SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN INSTALL PHONE MODEM DRIVERS IF NEEDED SEARCHING FOR PHONE, "STOP" TO ABORT PHONE FOUND AT COM87 PHONE READY TO PROCEED GOT SEED: 00F38042 ACTIVATION COMPLETED. USERCODE RESET TO "0000" DO NOT DISCONNECT PHONE FROM CABLE UNTIL PHONE TURNS ON BY ITSELF Unlock DONE Elapsed: 375 seconds thanks! j108_CEDAR 5 locks unlocked for free ! |
need ericsson 88 cable | migdamas | Old Ericsson Phones & Sony Phones | 2 | 03-24-2017 16:24 |
Help: Forgot my 6110 user lock code!! | GByte9 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 02-26-2016 14:52 |
SP Lock 1&4 | dw | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 11 | 06-26-1999 06:22 |
Need info for unliocking 2 lock (with pic microprocesors) | Tomas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-26-1999 01:00 |
