Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > HTC > HTC Android based
HTC Android based General HTC Android phones discussion, firmwares, solution, root, help
Old 06-22-2015, 21:04   #16 (permalink)
Member: 1804483
Sonork: 100.1641314
Thanks Meter: 50
Originally Posted by Faheem Anjum View Post
@All
there is many firmware which have limited language infect if you delete are replace and the xml file . still you cant get these arabic language . i have a solution which can help to add these language which not enabled with xml file
faheem bhai u have without root or with root solution if u have with root it mean u adding fonts or region changer language enabler or u edit xml if u have any authentic solution shre with me if it paid then also ready to pay
Old 06-25-2015, 12:34   #17 (permalink)
Member: 839471
Thanks Meter: 34
ser its not working for my htc d816x need arabic plzzz help me
The Following User Says Thank You to shafee3113 For This Useful Post:
Old 06-25-2015, 13:17   #18 (permalink)
Member: 2291149
I have Htc desire 616 dual sim..I have used Root explore but there is no CID directory in the given path, there are only "ACC and Resorce" directories....what is the solution for this case?
Old 06-27-2015, 18:58   #19 (permalink)
Member: 2142741
Sonork: 100.1607386
not working
not working for old models
Old 07-01-2015, 20:38   #20 (permalink)
Member: 630795
Thanks Meter: 177
In addition to what mr jamesjerss has said, in some phones the CID folder is in the following place as in Desire 626G+
System/customize/resource/11111111/customizedata/CID
But Still no Arabic
Old 07-02-2015, 16:45   #21 (permalink)
Member: 630795
Thanks Meter: 177
Hello guys. My Desire 626G+ is Arabic now but 1 problem . i cannot make settings arabic
tried to delete settings.apk but i cannot install another one
my settings version is 4.4.2-11
Any suggestions please?
Old 07-02-2015, 17:15   #22 (permalink)
Member: 1314938
Sonork: 100.1672340
Thanks Meter: 5,373
To install system apps Root yur device copy the apk to Root /system/ apps folder reboot yur device or use any system app installer apk frm playstore
Old 07-02-2015, 18:13   #23 (permalink)
Member: 630795
Thanks Meter: 177
Already did that sir. If I install any settings.apk it gives error. And if I put the apk in app folder and reboot ,nothing happens. Anyways I give the handy back to customer. Thank you
Sent from my Nexus 4 using Tapatalk
Old 07-02-2015, 19:01   #24 (permalink)
Faheem Anjum's Avatar
Member: 399832
Sonork: Faheem Anjum
Thanks Meter: 24,310
In some firmwares you can get update.zip folder copy it on phone mmc and put phone in recovery and select install from update.zip when done restart and check language .also have another way to add language with root
The Following 2 Users Say Thank You to Faheem Anjum For This Useful Post:
Old 07-14-2015, 08:50   #25 (permalink)
Registered User
Member: 1725884
Sonork: swimming
Thanks Meter: 293
the other way as i know is to take full dump like bin file from working phone and the flash to other phone,it will show the arabic language and also fix imei invalid in htc mtk....
Old 07-21-2015, 13:56   #26 (permalink)
Member: 1827050
working 100% HTC One
thank you
Old 07-30-2015, 07:37   #27 (permalink)
Member: 1044410
Thanks Meter: 23
no file cid in HTC 616 how to arabic ??
Old 07-30-2015, 08:07   #28 (permalink)
saifjaan009's Avatar
Member: 2340225
Sonork: 100.1662389
Thanks Meter: 367
Arrow Root Ur Htc Via IROOT
Download Here IRoot
Download iRoot v2.2.1
And Install After Install Go To Setting Developer Option USB Dubbing Mode On
Connect Device Via Cable To Pc And Run IROOT EXE
When Root Successfully Go To Playstore and Install Region Changer APK
After Install apk open and select Arabic language and done
Best Regards
Saif Ur Rahman
The Following 2 Users Say Thank You to saifjaan009 For This Useful Post:
Old 07-30-2015, 08:30   #29 (permalink)
Member: 1044410
Thanks Meter: 23
Thanks dear saifjaan009 done Arabic lang working 100%
Old 08-05-2015, 22:35   #30 (permalink)
Member: 1170008
Thanks Meter: 21
htc one mini2
On htc one mini2 don't work
Page generated in 0.19427 seconds with 8 queries
