HTC Android based General HTC Android phones discussion, firmwares, solution, root, help |
06-22-2015, 21:04 | #16 (permalink) |
Freak Poster Join Date: Aug 2012 Location: muscat india
Member: 1804483 Status: Offline Sonork: 100.1641314 Thanks Meter: 50 | |
06-25-2015, 13:17 | #18 (permalink) |
Junior Member Join Date: Nov 2014
Member: 2291149 Status: Offline Thanks Meter: 0 | I have Htc desire 616 dual sim..I have used Root explore but there is no CID directory in the given path, there are only "ACC and Resorce" directories....what is the solution for this case? |
07-01-2015, 20:38 | #20 (permalink) |
No Life Poster Join Date: Nov 2007 Location: Arizona Age: 38
Member: 630795 Status: Offline Thanks Meter: 177 | In addition to what mr jamesjerss has said, in some phones the CID folder is in the following place as in Desire 626G+ System/customize/resource/11111111/customizedata/CID But Still no Arabic Last edited by sobaro; 07-01-2015 at 20:47. |
07-02-2015, 16:45 | #21 (permalink) |
Member: 630795 Status: Offline Thanks Meter: 177 | Hello guys. My Desire 626G+ is Arabic now but 1 problem . i cannot make settings arabic tried to delete settings.apk but i cannot install another one my settings version is 4.4.2-11 Any suggestions please? |
07-02-2015, 17:15 | #22 (permalink) |
No Life Poster Join Date: May 2010 Location: India,Tamilnadu-Nagercoil Age: 37
Member: 1314938 Status: Offline Sonork: 100.1672340 Thanks Meter: 5,373 | To install system apps Root yur device copy the apk to Root /system/ apps folder reboot yur device or use any system app installer apk frm playstore |
07-02-2015, 18:13 | #23 (permalink) |
Member: 630795 Status: Offline Thanks Meter: 177 | Already did that sir. If I install any settings.apk it gives error. And if I put the apk in app folder and reboot ,nothing happens. Anyways I give the handy back to customer. Thank you Sent from my Nexus 4 using Tapatalk |
07-02-2015, 19:01 | #24 (permalink) |
No Life Poster Join Date: Nov 2006 Location: (United States Of Islam) Age: 37
Member: 399832 Status: Offline Sonork: Faheem Anjum Thanks Meter: 24,310 | In some firmwares you can get update.zip folder copy it on phone mmc and put phone in recovery and select install from update.zip when done restart and check language .also have another way to add language with root |
The Following 2 Users Say Thank You to Faheem Anjum For This Useful Post: |
07-14-2015, 08:50 | #25 (permalink) |
Registered User Join Date: Feb 2012 Location: swimming
Member: 1725884 Status: Offline Sonork: swimming Thanks Meter: 293 | the other way as i know is to take full dump like bin file from working phone and the flash to other phone,it will show the arabic language and also fix imei invalid in htc mtk.... |
07-30-2015, 08:07 | #28 (permalink) |
No Life Poster Join Date: Feb 2015 Location: PAKISTAN (OMAN) Age: 35
Member: 2340225 Status: Offline Sonork: 100.1662389 Thanks Meter: 367 | Root Ur Htc Via IROOT Download Here IRoot Download iRoot v2.2.1 And Install After Install Go To Setting Developer Option USB Dubbing Mode On Connect Device Via Cable To Pc And Run IROOT EXE When Root Successfully Go To Playstore and Install Region Changer APK After Install apk open and select Arabic language and done Best Regards Saif Ur Rahman |
The Following 2 Users Say Thank You to saifjaan009 For This Useful Post: |
