Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > BlackBerry (RIM)
BlackBerry (RIM) Blackberry phones discussion, firmwares, tutorial, media, repairs.
Old 03-02-2015, 22:45   #16 (permalink)
Member: 1860527
My Z10 Stl-100 1
is stuck at the boot logo
once i insert the battery it boots and gets stuck at the blackberry logo.
I have replaced the battery and even plugged it in the wall charger for over 5hours
it just get stuck at the logo
i decided to reload it but blackberry link wont even detect it.
i downloaded the latest autoloader for my z10 .but it wont detect the phone unless i remove the battery and usb cord and insert them back while the autoloader is still open. it then asks for my password on the autoloader, after typing the password on the autoloader, then nothing else happens but the phones led will blink twice and pause for 3 secs and blink thrice ,making it 5 blinks
please kindly help ideas
Old 03-03-2015, 04:28   #17 (permalink)
aZimBahar's Avatar
Member: 1174508
Sonork: 100.1593820
Thanks Meter: 11,979
@.... phantorm
If not detect on autoloader thats means its usb connecting problem
For confirmation check Device manager ! If no respond on device manager Check usb post !
AzimBahar/ParvezAhmed
Old 03-06-2015, 11:31   #18 (permalink)
Member: 985933
Thanks Meter: 13
10 Attempt Left Solution not worked for my Z-30........
Do you have any solutions ?
Thanks.
Old 03-06-2015, 11:44   #19 (permalink)
aZimBahar's Avatar
Member: 1174508
Sonork: 100.1593820
Thanks.
Password Block/10 Left :
  • 1st you need use CFP For Blackberry Z10 By AzimBahar . This case connecting is impotent . You may connect too way . 1st run WIPE from CFT tools then connect phone and entry password 10 time. If same, Once again Run WIPE and connect phone without battery and entry password 10 time.
  • After wipe update your phone that's it
Details - http://forum.gsmhosting.com/vbb/f489...t-etc-1916898/
This solution for Z3-Z10-Z30 !
Old 03-06-2015, 11:48   #20 (permalink)
Member: 985933
Thanks Meter: 13
I can not entry password 10 time..... only 1 time and "enter" not worked
Old 03-06-2015, 11:52   #21 (permalink)
aZimBahar's Avatar
Member: 1174508
Sonork: 100.1593820
You entry password on Auto loader or in CFP ?
Post screenshot !
Read it :
Originally Posted by ..::One-Man::.. View Post
Already posted , Did you try my method. I already done many time 10 attempt problem its software issue. you can solve by CFP WIPE But if red light with 10 attempt then if my method fail. So phone hardware failure.
Old 03-06-2015, 11:58   #22 (permalink)
Member: 985933
Thanks Meter: 13
Z-30 @ EX.UA
in CFP
Old 03-06-2015, 12:05   #23 (permalink)
aZimBahar's Avatar
Member: 1174508
Sonork: 100.1593820
What is phone status ?
Try to connect with battery also try without battery
Then entry any password then ENTER
Like this 10 time, should be work
Old 03-06-2015, 12:25   #24 (permalink)
Member: 985933
Thanks Meter: 13
I connect without battery and I can entry password only 1 time.......
if I press "enter" - I can not entry password.........
you can see on photo....
Old 03-16-2015, 20:57   #25 (permalink)
Member: 2292018
Thanks Meter: 8
Hi Bro I Have a BB Q10 Which is stuck on 100% Boot Screen PLz Help Me Urgent
Old 03-17-2015, 03:21   #26 (permalink)
aZimBahar's Avatar
Member: 1174508
Sonork: 100.1593820
Create a new thread , I will provide you link
Old 03-22-2015, 21:03   #27 (permalink)
sweetboy's Avatar
Member: 146939
Sonork: 100.1609615
Thanks Meter: 245
AzimBahar/ParvezAdmed
hi bro can u provide code reset for 9800 like u have for z10
thank you
Old 03-23-2015, 03:16   #28 (permalink)
aZimBahar's Avatar
Member: 1174508
Sonork: 100.1593820
thank you
I am not understand what you mean, Anyway create a new tharead with details. This thread only for z10 !!!
Old 08-13-2015, 03:15   #29 (permalink)
Crazy Poster
Member: 207365
Thanks Meter: 3
HI Guys,
I seen in forum always user posting to BB Section about z10 hang on logo , Red light , blocked password Etc problem . So let's me explain here about these problem and solution . Kindly next time before post fellow my solution
Update With BB Link/Autoloader :
You can update your phone with Autoloader Remember you must use your same STL OS (EXAMPLE - STL100-1 ETC). STL version have in your phone back side . So you can download correct OS for your Phone . Also you can update your phone with BB Link Its Online updater , 1st time take long time for Os downloading 2nd time no need long time , Cases you have download already ! Remember Some time unable to detect on BB Link , This case Simple wipe your Phone With CFP ( I already share in below ) Then connect to BB Link !
Hang On Logo / Red light :
  • 1st try to update Autoloader Or BB Link . Remember if you try with Autoloader you must you same STL Version
  • If after update Still hang on logo , your problem is not solve So just wipe your phone with CFP For Blackberry Z10 By AzimBahar Then Update your phone
Impotent note :
  1. If after wipe phone not connect to PC , Then connect battery to phone wait few min
These way tested By me 50 more time
When making wipe of the device reached 16%
Now the machine died. There is no any connection with the computer
Old 08-13-2015, 05:01   #30 (permalink)
aZimBahar's Avatar
Member: 1174508
Sonork: 100.1593820
What is before phone status ?
Try without battery using good cable , also try with good battery
After wipe you must update with Blackberry Link
Br:-)
Page generated in 0.24504 seconds with 8 queries
