12-29-2017, 14:38 | #738 (permalink) |
No Life Poster Join Date: Feb 2005 Location: GSM WORLD
Member: 118520 Status: Offline Thanks Meter: 3,551 | XIAOMI REDMI 4X SANTONI ANDROID:7.1.2 SNAPDRAGON 435(MSM8940) MI ACCOUNT REMOVE Done SUCCESSFULLY REMOVE MI ACCOUNT(XIAOMI REDMI 4X SANTONI ANDROID:7.1.2 SNAPDRAGON 435(MSM8940))USB SUCCESS REPORT THANKS MRT-TOOL TEAM |
12-29-2017, 18:08 | #739 (permalink) |
No Life Poster Join Date: Jan 2011 Location: Erth Age: 40
Member: 1497980 Status: Offline Thanks Meter: 1,266 | Story of Success MRT Product [ Read/Write/Format/Unlock...etc ] Nokia 3 FRP LOCK DONE WITH MRT DONGLE NO NEED BOOT FILE ETC ETC Disconnect Mobile... Re-Put the Mobile Bettery... Then Connect your Phone to Computer again.... Please Make sure Mobile better has Power... >>> Searching Mobile Port... Get Mobile Port is: COM5 >>> Device driver identification: PreLoader USB VCOM (Android) >>> Mobile Has Connect... CPU_NAME: MT6735 >>> Reading Mobile Hardware Info...Success HW_Inf: 8A00 SW_Inf: CB00 >>> Initialization Mobile ...Success >>> Downloading Boot1 To Mobile Phone...Success The Flash Hardware Info:QE13MB >>> Downloading Boot2 To Mobile Phone...Success =====================Flash Type(eMMC)============== Flash Size: 0x00000003A3E00000 -> 14910M Flash ID: 0x150100514531334D Flash Name: Samsung_Unknow Flash symbol: QE13MB >>> Software Auto Switch Hight Speed Has Enable... >>> Swich Mobile to Hight Speed Re\Wr Port... Get Mobile Port is: COM16 >>> Device driver identification: DA USB VCOM (Android) >>> Reading Mobile Map Data...Success >>> Software Auto Switch Hight Speed Has Enable... >>> Swich Mobile to Hight Speed Re\Wr Port... Get Mobile Port is: COM16 >>> Device driver identification: DA USB VCOM (Android) >>> Reading Mobile Map Data...Success >>> Extracting valid data from partition data... >>>>Formating Mobile USER Data... ADD(HEX):0x0009B20000 Size(HEX):0x0000100000 Corresponding operation completed!!! |
12-30-2017, 05:51 | #740 (permalink) |
Freak Poster Join Date: May 2007 Location: BetaMax Tester
Member: 516470 Status: Offline Thanks Meter: 70 | Oppo A37f pattern removed >>>>Auto search Mobile port... >>>Try connect to mobile...Success CPU_SN: 0x246350A1 MSM_ID: 0x007050E1 CPU型号: MSM8916 >>>Try connect to mobile...Success >>>init mobile...Success >>>Downloading boot...Success >>>Switch mobile to RE\WR ...Success Flasy type: eMMC >>>>正在读取手机分区数据...Success Clear Moblile Lock data... After Click Mobile userdata will be lost... Format add: ADD:0x00E2788000 Size:0x02C8C73E00 Erase Userdata.. Success Erase Userdata Block 2... Erase Userdata.. Success Erase Userdata Block 3... Erase Userdata.. Success Erase Userdata Block 4... Erase Userdata.. Success >>>all is done ******************************** Please disconnect mobile set,and hold vol up and power key Mobile will be into recovery Click Restart ******************************** if mobile hand on logo or auto restart... You can in recovery erase data After ease data in recovery mobile will working normal |
The Following 2 Users Say Thank You to J_M For This Useful Post: |
12-30-2017, 06:42 | #741 (permalink) |
Freak Poster Join Date: Jul 2016
Member: 2604648 Status: Offline Thanks Meter: 346 | Oppo F3 Remove Pattern done Code: Disconnect Mobile... Re-Put the Mobile Bettery... Then Connect your Phone to Computer again.... Please Make sure Mobile better has Power... >>> Searching Mobile Port... Get Mobile Port is: COM376 >>> Device driver identification: MTK USB Port >>> Mobile Has Connect... CPU_NAME: MT6755 >>> Reading Mobile Hardware Info...Success HW_Inf: 8A00 SW_Inf: CB00 >>> Initialization Mobile ...>>> Sending Auth File To Mobile...Success >>> Downloading Boot1 To Mobile Phone...Success Mobile phone status:SYNC... Mobile phone status swtich to :brom...Success Success Make sure Mobile status has in :brom... Init Mobile BOOT2 ... =====================Flash Type(eMMC)============== Flash Size: 0x0000000E8F800000 -> 59640M Flash ID: 0x150100524836344D Flash Name: Samsung_Unknow Flash symbol: RH64MB >>> Swich Mobile to Hight Speed Re\Wr Port... Get Mobile Port is: COM172 >>> Device driver identification: MTK DA USB VCOM (Android) >>> Reading Mobile Map Data...Success >>>>Formating Mobile USER Data... ADD(HEX):0x0137000000 Size(HEX):0x0D577FBE00 Corresponding operation completed!!! |
12-30-2017, 09:28 | #742 (permalink) | |
No Life Poster Join Date: Sep 2009
Member: 1109337 Status: Offline Thanks Meter: 197 | Cherry Mobile Flare S6 FRP done Cherry Mobile Flare S6 FRP done Quote:
The Following User Says Thank You to wohlstand For This Useful Post: |
01-01-2018, 08:06 | #744 (permalink) |
No Life Poster Join Date: Jan 2015 Location: Narsingdi, Dhaka, Bangladesh Age: 28
Member: 2325851 Status: Offline Sonork: 100.1680491 Thanks Meter: 2,363 | Symphony v80 imei repair done with greate mrt dongle SYMPHONY V80 IMEI REPAIR DONE WITH GREATE MRT DONGLE [IMG][/IMG] Disconnect Mobile... Re-Put the Mobile Bettery... Then Connect your Phone to Computer again.... Please Make sure Mobile better has Power... >>> Searching Mobile Port... Get Mobile Port is: COM66COM66 >>> Device driver identification: MediaTek PreLoader USB VCOM (Android) Set Port To COM66Success Into Meta Mode...Success Switch Moile to Repair IMEI Port... >>> Searching Mobile Port... Get Mobile Port is: COM452COM452 >>> Device driver identification: MediaTek USB VCOM (Android) >>> Into META Repair IMEI Mode...Success reading the relevant parameters of the phone information... CPU_TYPE:MT6582,S01 Bulid_Time:Wed Apr 29 22:21:19 CST 2015 Base_Ver:V80_0_XXX_V01.9_V1.0 Soft_Ver:LRX21M test-keys Original_IMEI 1: New_IMEI 1: 353642078840511 Original_IMEI 2: New_IMEI 1: 353642078875913 Corresponding operation completed!!! |
01-01-2018, 14:40 | #745 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Sydney
Member: 153695 Status: Offline Sonork: srkhan Thanks Meter: 788 | world first Lee account unlock done (not frp) LeEco Le S3 X622 Disconnect Mobile... Re-Put the Mobile Bettery... Then Connect your Phone to Computer again.... Please Make sure Mobile better has Power... >>> Searching Mobile Port... Get Mobile Port is: COM28 >>> Device driver identification: MediaTek USB Port >>> Mobile Has Connect... CPU_NAME: MT6797 >>> Reading Mobile Hardware Info...Success HW_Inf: 8A00 SW_Inf: CA01 >>> Initialization Mobile ...>>> Sending Auth File To Mobile...Success >>> Downloading Boot1 To Mobile Phone...Success Mobile phone status:SYNC... Mobile phone status swtich to :brom...Success Make sure Mobile status has in :brom...Success Init Mobile BOOT2 ... =====================Flash Type(eMMC)============== Flash Size: 0x0000000747C00000 -> 29820M Flash ID: 0x1101003033324733 Flash Name: Toshiba_Unknow Flash symbol: 032G34 >>> Swich Mobile to Hight Speed Re\Wr Port... Get Mobile Port is: COM29 >>> Device driver identification: MediaTek DA USB VCOM (Android) >>> Reading Mobile Map Data...Success >>>>Formating Mobile USER Data... ADD(HEX):0x012D800000 Size(HEX):0x06193FBE00 >>>>Formating Mobile USER Data... ADD(HEX):0x0002108000 Size(HEX):0x0000080000 Corresponding operation completed!!! |
The Following 3 Users Say Thank You to srkhan For This Useful Post: |
01-02-2018, 15:27 | #748 (permalink) |
Member: 118520 Status: Offline Thanks Meter: 3,551 | XIAOMI REDMI 3S LAND ANDROID VER:6.0.1 SNAPDRAGON 430(MSM8937)MI ACCOUNT REMOVE Done SUCCESSFULLY REMOVE MI ACCOUNT(XIAOMI REDMI 3S LAND ANDROID VER : 6.0.1 SNAPDRAGON 430(MSM8937))USB SUCCESS REPORT THANKS MRT-TOOL TEAM |
