04-04-2009, 11:13 | #1 (permalink) |
No Life Poster Join Date: Aug 2002 Location: Island Garden City Of Samal,Ph
Member: 14852 Status: Offline Sonork: 100.1608716 Thanks Meter: 503 | 1680 unlocking error Failed to Unlock DCT4 -> Possible cause: HW Signature Invalid Handling device: [Cyclone Team], [Cyclone Box] Initializing box... Box Firmware: Cyclone Nokia Application v1.00, (Mar 13 2009 20:30:35, gcc-4.2.2, RTOS V5.1.0), Type: Signed Production Application Box Serial Number: jakoy HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2008, wk32 Initializing security card... Card Serial Number: jakoy Card Firmware Revision: 0109 Card is activated Box is activated Started box selftests procedure USB Voltage 5.23v PASSED MCU Voltage 3.28v PASSED Core Voltage 1.81v PASSED VBAT Voltage 1.41v PASSED VBAT Voltage 5.16v PASSED Box VPP disabled VPP Voltage 0.00v PASSED Internal Box VPP Enabled VPP Voltage 5.15v PASSED Box VPP disabled VPP Voltage 0.00v PASSED External Box VPP Enabled VPP Voltage 0.04v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Initializing FBUS... All initialized - Ready to work Booting UPP... Failed to Check DCT4 Flashing Bus -> UPP Not Responding Booting UPP... UPP ID: 3162 [HW_UNKNOWN] Flashbus Write baud set to 100Kbits u3_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.77.0, Algo: DCT4 PLL Factor: 3 FlashChip[0]: 0x0001317E @ 0x01000000, AMD, SectorSize: 128kB, Ext: 00419221 Signature: AD7EB61B00FF10400000000000000000 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 4Kbits u3_amd.fia, Type: Algorithm, Target: FlashChip[0] 0x0001317E (256Mbits), Rev: 7.4.77.0, Algo: DCT4 ALGORITHM Nominal VPP Voltage: 9V, Detected: 0.04V Terminating flash session Boot operation took 6.148s Check Flashing Bus finished MCU Version V 06.82 MCU Date 26-09-08 Product RM-394 Manufacturer (c) Nokia IMEI 2, 26-09-08, RM-394, (c) Nokia Asic 41 HW Signature 6F6B6961001B0100 Simlock Server 1953030447184 Simlock Key 3533303330343437 Simlock Profile 31383400342C2028 Simlock Aux 6329204E Simlock IMEI 00014114001033353139 Simlock Key Cnt 15 Simlock FBUS Cnt 15 Selecting unlock method... Search in: C:\Program Files\Cyclone Box\UnlockData\ Searching for: RM-394_V 06.82.unlock_img Asking card to sign HW Signature... Signed OK (FD8044A530A313DA0463BB583ACCDA578F3871BA) Writing patch file... Booting UPP... UPP ID: 3162 [HW_UNKNOWN] shadow, Type: Flash Image, Algo: DCT4, DCT4 ALGORITHM Flashbus Write baud set to 100Kbits u3_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.77.0, Algo: DCT4 Box VPP disabled Internal Phone VPP Selected PLL Factor: 3 FlashChip[0]: 0x0001317E @ 0x01000000, AMD, SectorSize: 128kB, Ext: 00419221 FlashChip[1]: 0x0001317E @ 0x02000000, AMD, SectorSize: 128kB, Ext: 00419221 Signature: AD7EB61B00FF10400000000000000000 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 51Kbits u3_amd.fia, Type: Algorithm, Target: FlashChip[0] 0x0001317E (256Mbits), Rev: 7.4.77.0, Algo: DCT4 ALGORITHM Nominal VPP Voltage: 9V, Detected: 0.02V MSID-Crypted: 8409AB46E7FAFDEA0595C60D24 MSID-Plain: 2C40BAE9004A4301AA000000 FAID-Crypted: 899E916F124EDF04F8965F28 Flashbus Write baud set to 6.50Mbits 2 Region(s) to erase Erasing NOR Region [0x01000000-0x0101FFFF] Erasing NOR Region [0x01080000-0x0109FFFF] Erase taken 1.302s Writing 10 blocks... All blocks written OK! Time taken 4.887s Terminating flash session Box VPP disabled Writing SP... Failed to Unlock DCT4 -> Possible cause: HW Signature Invalid |
04-04-2009, 11:47 | #2 (permalink) |
Banned Join Date: Apr 2005 Age: 42
Member: 137474 Status: Offline Sonork: 100.109924 Thanks Meter: 471 | REFLASH phone and try again I unlock 5-10 pcs 1680c and all unlock ok but got few 1680c that got the same problem and this was software problem after reflash unlock work great. bye |
04-04-2009, 18:49 | #5 (permalink) |
No Life Poster Join Date: Feb 2005 Location: Poland Age: 34
Member: 117496 Status: Offline Sonork: 100.83919 Thanks Meter: 22,689 | It's beause some garbage are readed from FBUS and HWSIG is not correct (here: 6F6B6961001B0100, ascii: okia....), so trying unlock again should do the job |
Failed to Unlock 2323c Using Super DCT4 Activation [Solved Thanks to Alex] | tims | Cyclonebox | 7 | 07-31-2010 10:31 |
Failed to Unlock DCT4 -> Possible cause: Other error (0x02) | merlin4 | Cyclonebox | 3 | 04-16-2010 22:48 |
whats the error -> Failed to Write PM -> Access violation at address 005AE2F5 | Y.P.Y | Cyclonebox | 6 | 03-09-2010 22:12 |
Failed to Calculate DCT4 RPL -> Server transaction failed | abi.m | Cyclonebox | 1 | 08-08-2009 16:02 |
Nokia 2630 unlock error! Failed to power! | Soap8 | Nokia Digital Core Technology 4 ( DCT-4 ) | 3 | 04-04-2009 13:45 |
