Join Date: Feb 2006 Location: ROMANIA/Alexandria Age: 44
Member: 230301
Sonork: 100.106864 Thanks Meter: 1,434 | 2630 vers 57.20 unlock problem Unlock ok but no signal , in manual search see all network but not have acces.is any solution , i flash whit same version but same. Quote:
Nokia DCT4/WD2/BB5 Service Tool Initialization Started, Engine Revision: 1.0.0.7828
Handling device: [Cyclone Team], [Cyclone Bootloader]
Handling device: [Cyclone Team], [Cyclone Box]
Initializing box...
Box Firmware: Cyclone Nokia Application v1.07, (Sep 11 2009 03:35:10, gcc-4.2.2, RTOS v5.2.0), Type: Signed Production Application, Flags: NoFlags
Box Serial Number: C00015CC
HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: Unknown
Initializing security card...
Card Serial Number: D30000F1
Card Firmware Revision: 0109
Card is activated
Box is activated
Started box selftests procedure
USB Voltage 5.02v PASSED
MCU Voltage 3.30v PASSED
Core Voltage 1.78v PASSED
VBAT Voltage 0.54v PASSED
VBAT Voltage 4.99v PASSED
Box VPP disabled
VPP Voltage 0.04v PASSED
Internal Box VPP Enabled
VPP Voltage 5.01v PASSED
Box VPP disabled
External Box VPP Enabled
VPP Voltage 0.04v FAILED - IGNORED - Probably power supply is not connected
Box VPP disabled
All box selftests passed!
Initializing FBUS...
All initialized - Ready to work
Processing pre-flash tasks...
Pre-flash tasks finished
Booting UPP...
UPP ID: 3168 [HW_UNKNOWN]
rm298__57.20.mcusw, Type: Flash Image, Algo: DCT4, DCT4 ALGORITHM
Flashbus Write baud set to 100Kbits
u3_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.79.0, Algo: DCT4
Box VPP disabled
Internal Phone VPP Selected
PLL Factor: 3
FlashChip[0]: 0x00EC2208 @ 0x01000000, Samsung, SectorSize: 128kB, Ext: 00009121
FlashChip[1]: 0x00EC2208 @ 0x02000000, Samsung, SectorSize: 128kB, Ext: 00009121
Signature: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
Flashbus Write baud set to 1.0Mbits
Flashbus Read baud set to 51Kbits
u3_amd.fia, Type: Algorithm, Target: FlashChip[0] 0x00EC2208 (256Mbits), Rev: 7.4.79.0, Algo: DCT4 ALGORITHM
Nominal VPP Voltage: 9V, Detected: 0.04V
MSID-Crypted: 84D8AC2291AEA6025E62D4D768
MSID-Plain: 2C40BAE90042D405A9000000
FAID-Crypted: 30554CE673ADEDB37E68A00A
Flashbus Write baud set to 6.50Mbits
2 Region(s) to erase
Erasing NOR Region [0x01000000-0x0101FFFF]
Erasing NOR Region [0x01020000-0x01C3FFFF]
Erase taken 36.531s
Writing 343 blocks...
All blocks written OK! Time taken 389.500s
Terminating flash session
Box VPP disabled
Booting UPP...
rm298__57.20.image__pre_ee, Type: Flash Image, Algo: DCT4, DCT4 ALGORITHM
Box VPP disabled
PLL Factor: 3
Signature: AD7EB61B23100340C605E40120A20000
MSID-Crypted: 841F8D6E9B99628F9538675B79
MSID-Plain: D26EBAF10042D405AA000610
FAID-Crypted: 61B43B28F0F01AB3C1E1C4B7
Erasing NOR Region [0x02000000-0x02DBFFFF]
Erasing NOR Region [0x02DC0000-0x02F9FFFF]
Erase taken 45.922s
File Sector Size: 128kB, Flash Chip Sector Size: 128kB
CNT Convertion not needed
Writing 248 blocks...
All blocks written OK! Time taken 118.328s
Extracting Content Package...
CP Extract Failed -> CP Server not exists
WARNING: Failed to extract CP
Box VPP disabled
Booting UPP...
rm298__57.20.ppm_ee, Type: Flash Image, Algo: DCT4, DCT4 ALGORITHM
Box VPP disabled
PLL Factor: 3
MSID-Crypted: 84115C892B384CDF71879986FE
MSID-Plain: 3E4EBAE90042D405AA000000
FAID-Crypted: B24BD30212BBB2A509A41075
1 Region(s) to erase
Erasing NOR Region [0x01C40000-0x01FFFFFF]
Erase taken 11.516s
Writing 88 blocks...
All blocks written OK! Time taken 90.625s
Box VPP disabled
Processing post-flash tasks...
Setting Factory Defaults...
Factory defaults OK
Post-flash tasks finished...
Flash successfully finished!
MCU Version V 57.20
MCU Date 09-02-09
Product RM-298
Manufacturer (c) Nokia
IMEI 359342023987558
Mastercode 7213547366
IMEI Spare 3A95430232895705
IMEI SV 3395430232895745F8000000
PPM V 57.20, 09-02-09, RM-298, (c) Nokia, EE
CNT Content: _pre_ee, V 57.20, 09-02-09, RM-298, (c) Nokia
PSN KHV258189
Product Code 0582682
Module Code 0204258
Basic Product Code 0578420
PSD 0000000D00000000
LPSN 0
HW 2200
UEM 1328
UPP 12648
RFIC 0500
DSP ICPR62_08w36_UPP
LCD SUEZ
BT 2222-v101
Failed to read info -> Failed to read SP info
MCU Version V 57.20
MCU Date 09-02-09
Product RM-298
Warning: Failed to read SP Info, Assuming defaults
Asic 11
HW Signature 15A4A9A9E8F728E7
Simlock Server SIMLOCK SERVER
Simlock Key 5555555555555555
Simlock Profile 5555555555035555
Simlock Aux 000B5555
Simlock IMEI 00553593420239875500
Simlock Key Cnt 0
Simlock FBUS Cnt 0
Selecting unlock method...
Search in: C:\Program Files\Cyclone Box\UnlockData\
Searching for: RM-298_V 57.20.unlock_img
Asking card to sign HW Signature...
Signed OK (FFE56F0D0ED51FDE2EB72B453E8CF2610D313A96)
Writing patch file...
Booting UPP...
shadow, Type: Flash Image, Algo: DCT4, DCT4 ALGORITHM
Box VPP disabled
PLL Factor: 3
Nominal VPP Voltage: 9V, Detected: 0.02V
Using MSID-FAID Cache, Not wasting card
Erasing NOR Region [0x01080000-0x0109FFFF]
Erase taken 0.766s
Writing 10 blocks...
All blocks written OK! Time taken 8.922s
Box VPP disabled
Simlock Security - TAMPERED
Writing SP...
New SP Accepted OK!
Phone unlocked OK!
MCU Version V 57.20
MCU Date 09-02-09
Product RM-298
PSN KHV258189
Module Code 0204258
LPSN 0
HW 2200
UEM 1328
UPP 12648
RFIC 0500
LCD SUEZ
BT 2222-v101
Asic 11
Simlock Key 0010100000000000
Simlock Profile 000000000003000B
Simlock Key Cnt 0
Simlock FBUS Cnt 0
Simlock [1,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [1,2] State: OPENED Type: GID Data: FFFF
Simlock [1,3] State: OPENED Type: GID Data: FFFF
Simlock [1,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [1,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [2,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [2,2] State: OPENED Type: GID Data: FFFF
Simlock [2,3] State: OPENED Type: GID Data: FFFF
Simlock [2,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [2,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [3,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [3,2] State: OPENED Type: GID Data: FFFF
Simlock [3,3] State: OPENED Type: GID Data: FFFF
Simlock [3,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [3,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [4,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [4,2] State: OPENED Type: GID Data: FFFF
Simlock [4,3] State: OPENED Type: GID Data: FFFF
Simlock [4,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [4,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [5,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [5,2] State: OPENED Type: GID Data: FFFF
Simlock [5,3] State: OPENED Type: GID Data: FFFF
Simlock [5,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [5,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [6,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [6,2] State: OPENED Type: GID Data: FFFF
Simlock [6,3] State: OPENED Type: GID Data: FFFF
Simlock [6,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [6,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [7,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [7,2] State: OPENED Type: GID Data: FFFF
Simlock [7,3] State: OPENED Type: GID Data: FFFF
Simlock [7,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [7,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF | |
