Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cyclonebox
Old 02-04-2012, 00:17   #1 (permalink)
moulnisky's Avatar
Member: 947561
Thanks Meter: 14,053
oclhashcat-lite 0.09 RELEASED! Radeon HD7xxx Tahiti GPU Supported >>> DETAILS INSIDE
Tonight atom finalized oclhashcat-lite v0.09
The breaking news:
New AMD 7xxx GPU platforms support
Major EULA changes has been set for the latest oclhashcat-lite version use (domestic and commercial users)
GPU Load Stability Issues are now completely resolved
Many interface tune-ups and fixes
THE MOST IMPORTANT: there is no change in commands so if you were able to use 0.8 version everything remains the same. Simple.
Please check changelog of the software package for full details.
FEEL THE RAW POWER!!!
The most advanced SL3 hash-cracking software on EARTH!
All users to use oclhashcat-lite v0.09 must download ATi 12.1 Complete Driver pack with SDK 2.6 runtime built in to it. You will find driver packets for your specific hardware application here:
ATI Radeon
NOTE: new drivers will still be backwards compatible with earlier version of oclhashcat-lite 0.08
official oclhashcat-lite support forum:
hashcat Forum
info and FAQ's:
oclhashcat_lite [hashcat wiki]
and
cracking_sl3 [hashcat wiki]
following links to be constantly updated with fresh and usefull info!
New v0.09 version download link will be available from official site here:
oclHashcat-lite - advanced password recovery
the comprehensive changelog v0.08 -> v0.09
* changes v0.08 -> v0.09:
type: feature
file: kernels
cred: added -m 2811 = IPB 2.0, MyBB1.2
type: feature
file: kernels
cred: added -m 3000 = LM
type: driver
file: kernels
desc: added support for AMD APP SDK 2.6
type: driver
file: kernels
desc: added support for NVidia CUDA 4.1
type: feature
file: kernels
desc: added support for AMD GPU's "Devastator" and "Scrapper"
type: feature
file: kernels
desc: added support for AMD GPU's "Capeverde", "Pitcairn" and "Tahiti"
type: feature
file: host programs
desc: backported --outfile-format from oclHashcat-plus v0.07
type: feature
file: host programs
desc: backported --seperator-char feature from hashcat v0.38
cred: thorsheim
type: feature
file: host programs
desc: add support for passwords smaller length 4
type: bug
file: host programs
desc: fixed issue with unaligned --pw-skip, did not auto-shutdown when 100% keyspace reached
cred: MrUltimate
type: bug
file: host programs
desc: fixed issue when using --pw-skip-plain in combination with --hex-charset
type: change
file: host programs
desc: changed hash parser for Joomla hashes to allow salt-length of 16 - 32
cred: sono
type: change
file: host programs
desc: changed default setting for CPU affinity: Linux unlocked, Windows unlocked
type: change
file: host programs
desc: ETA is now calculated regarding to configured value of --pw-skip and --pw-limit
cred: MrUltimate
type: change
file: host programs
desc: changed restore-timer default value to 60 due to GPU utilization issue
cred: MrUltimate, d-unknown, khempanhom
type: change
file: host programs
desc: EULA. Removed sections 2, 6, 8 and 9. Relaxed sections 3 and 7.
cred: hdmoore
type: change
file: kernels
desc: renamed -m 1    to -m 10
desc: renamed -m 3    to -m 2600
desc: renamed -m 5    to -m 2611
desc: renamed -m 15   to -m 2711
desc: renamed -m 101  to -m 110
desc: renamed -m 600  to -m 101
desc: renamed -m 700  to -m 111
desc: renamed -m 1300 to -m 131
desc: renamed -m 2000 to -m 112
desc: renamed -m 2300 to -m 132
type: change
file: rules
desc: redesigned usage screen
cred: Helpscreen redesign
THANKS and ALL THE HONNOR GOES to atom!
Best Regards
The Following 16 Users Say Thank You to moulnisky For This Useful Post:
Old 02-04-2012, 00:55   #2 (permalink)
jeanbrume's Avatar
Member: 273511
Thanks Meter: 84
hi
good work!
any one specefie what hash have Radeon HD7xxx Tahiti GPU ?
how speedy are for lbf ?
br
Old 02-04-2012, 01:03   #3 (permalink)
moulnisky's Avatar
Member: 947561
Originally Posted by jeanbrume View Post
hi
good work!
br
the 7970 give 2846.9M at stadard clock
3 7970 are quicker then a double 6990 whatever the 6990 is a double gpu card
Alex
The Following User Says Thank You to moulnisky For This Useful Post:
Old 02-04-2012, 01:57   #4 (permalink)
Member: 512970
Sonork: 100.1584185
Thanks Meter: 134
That nedding the gpu 7xxx dual
2048 mhz per prossesss
7xxx dual gpu = 4096 mhz
6990 gpu = 4096 mhz
to up a system 20 gpu whit 10 coputers = ~ 80 000 mhz
Br MPOGSM
Old 02-04-2012, 02:07   #5 (permalink)
ryumahon's Avatar
Member: 4021
Thanks Meter: 782
is it possible to combine 5 series or 6 series with this 7xxx cards? thanks!
Old 02-04-2012, 13:27   #6 (permalink)
taleb_amine8's Avatar
Member: 223552
Thanks Meter: 63
when i run oclhashcat 0.09 i get this error
E:\NOKIA\HACHS SL3\oclHashcat-lite-0.09\oclHashcat-lite-0.09>oclHashcat-lite32 B
C59967FDB7D6064295AF536AFDDA919608FAA74:0035593304 20053700 -1 000102030405060708
09 -m 1900 ?1?1?1?1?1?1?1?1?1?1?1?1?1?1?1 -n 160 --outfile-format=1 --outfile=35
5933042005374.cod
oclHashcat-lite v0.9 by atom starting...
GPU-Loops: 1024
GPU-Accel: 160
Password lengths range: 15 - 15
Platform: AMD compatible platform found
Watchdog: Temperature limit set to 90c
Device #1: Barts, 1024MB, 0Mhz, 14MCU
ERROR: clBuildProgram() -11
E:\NOKIA\HACHS SL3\oclHashcat-lite-0.09\oclHashcat-lite-0.09>pause
Appuyez sur une touche pour continuer...
Old 02-04-2012, 13:33   #7 (permalink)
Moderator
Member: 1139057
Sonork: 100.109924
Thanks Meter: 4,428
5933042005374.cod
GPU-Loops: 1024
GPU-Accel: 160
WHy not read FIRST POST FULLY ?
Oclhashcat-lite v0.9 need drivers v12.1 or higher.
In your computer you use OLD DRIVERS. All is in 1ST POST.
Old 02-04-2012, 13:36   #8 (permalink)
Moderator
Member: 1139057
Sonork: 100.109924
Thanks Meter: 4,428
hi
good work!
br
1 card HD7970 on stock clock got 2800Mhash/s, on 1Ghz got 3150Mhash/s and on 1125Mhz got 3300Mhash/s and even on last core speed card work very stabile and temperature only 65-70 degree !! !!
Power consumption on 1125Mhz is 230W.
On 2 cards I get on 1Ghz 6300Mhash/s and on 1125Mhz got 6600Mhash/s.
Old 02-04-2012, 13:59   #9 (permalink)
hugmax's Avatar
Member: 1038811
Sonork: 100.1585462
Thanks Meter: 974
the main feature here is power consumption.
hd6990 is very power hungry and the same to hd5970 at 393W and 3985Mhash
2 x hd5870 = 444W 4180Mhash
2 x hd7970 = 370W 6800Mhash
you do the math.
The Following 2 Users Say Thank You to hugmax For This Useful Post:
Old 02-04-2012, 14:17   #10 (permalink)
moulnisky's Avatar
Member: 947561
waiting for the 7990 to make a quad giving 24 gigahash/sec
Alex
The Following 4 Users Say Thank You to moulnisky For This Useful Post:
Old 02-05-2012, 15:18   #11 (permalink)
Member: 49594
Thanks Meter: 39
if i get a machine like this will it be able to do well please advise me on this NCIX.com - NCIX PC - Introducing the Vesta R2 NCIX PC
super boy24
Old 02-05-2012, 15:34   #12 (permalink)
Chevka's Avatar
Member: 82106
Thanks Meter: 1,208
already test with my machine used HD6990 and found NO faster speed than v0.08,
is anyone test face the same too like me?
will test now for my other machine used 5970 and 5870 soon....
Old 02-05-2012, 22:20   #13 (permalink)
Member: 1488173
Thanks Meter: 194
Looks like the speed is the same, the most important change here is the support added for ati 79xx card series.
Remember, the ati 6990 give you around 4000 Mhash/s and probably the 7990 will give you around 6500 Mhash/s . this is very important if you have bruteforce server and want to upgrade.
Regards !!
Old 02-05-2012, 22:26   #14 (permalink)
Member: 1488173
Thanks Meter: 194
Unhappy you are wrong
you do the math.
You will never get that speed with 2 cards 5870, maybe you are talking about 5970.
if this is true, so the ati 6970 have the same speed than ati 5870, because i have 6970 overclocked and give me 2,080 Mhash/s speed with oclhashcat v0.8 .
Regars !!
Old 02-06-2012, 03:29   #15 (permalink)
nelson_sanchez1's Avatar
Member: 1621431
Sonork: 100.1626009
Thanks Meter: 16
Regars !!
not mistaken the ati 5870 does what it says, I have three pc with ati 5870
I neeeeed NCDS 2.0!!!! plzz!!!! ratzfatz Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 02-27-2022 22:12
winlock 1.0 Aldrin Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 01-25-2000 04:49
download Datasuite 3.0 zfrank Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 10-31-1999 01:35
2 FREE NOKIA SP SIM CARDS TO RELEASE FOR INFORMATION WE NEED SP UNLOCKER 2000 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 09-25-1999 03:34
Page generated in 0.24699 seconds with 10 queries
