08-24-2009, 16:39 | #121 (permalink) |
Junior Member Join Date: Jan 2009 Location: Fujian, China
Member: 942099 Status: Offline Thanks Meter: 1 | VBAT Supply Voltage test failed MCU Voltage 3,28v PASSED Core Voltage 1,80v PASSED VBAT Voltage 0,01v PASSED Box Selftests Failed -> VBAT Supply Voltage test failed, 0,03v is out of valid range How to solve the ah? Help! |
08-24-2009, 22:31 | #122 (permalink) |
No Life Poster Join Date: Sep 2006 Location: RETIRED ! Age: 47
Member: 348680 Status: Offline Thanks Meter: 1,273 | Hi, conect an F-bus cable or Unifbus, and check with a multimeter if you have voltaje at battery terminals, if dont, contact your reseller for exchange the box... BR |
08-26-2009, 19:50 | #123 (permalink) |
Junior Member Join Date: Jul 2006
Member: 307433 Status: Offline Thanks Meter: 0 | how can I install on another computer cyclone how do I cyclone installed on another computer? I'm trying and I say this: Nokia Service Tool Initialization Started DCT4/WD2/BB5, Engine Revision: 1.0.0.7880 Open Box Error -> Security Problem # 5 Initialization has failed -> No connection was established, or box mode is not in needed |
08-26-2009, 20:02 | #124 (permalink) | |
No Life Poster Join Date: Feb 2005 Location: Poland Age: 34
Member: 117496 Status: Offline Sonork: 100.83919 Thanks Meter: 22,689 | Quote:
1- UNINSTALL CYCLONE (from add/remove programs) 2- DELETE C:\PROGRAM FILES\CYCLONE BOX FOLDER 3- INSTALL INSTALLER (CHECK ON 1ST POST OF THIS TOPIC) 4- APPLY BULK UPDATE That's all | |
09-02-2009, 15:27 | #125 (permalink) |
Freak Poster Join Date: Apr 2009 Location: Intan HP
Member: 1002567 Status: Offline Sonork: abc Thanks Meter: 33 | Hi sir i buy cclone box to day. How to repair imei ?????? wd2 (6600) i already use my credit. And i got nothing. Box said "failed with bootloader" Whats mean? Thanks. Urgent... |
09-02-2009, 15:44 | #126 (permalink) |
Major Poster Join Date: Aug 2009 Location: Russia.Zernograd
Member: 1096376 Status: Offline Thanks Meter: 23 | What mean the given messages? 1. Ticket received, Veryfing it... Authenthication error -> Socket Error # 11004 2. Cyclone Server Send Command Error -> Code: 500, Box is not registered, support is not allowed then Authenthication error -> Failed to obtain Authenthication Data |
09-02-2009, 21:00 | #127 (permalink) | |
Member: 1096376 Status: Offline Thanks Meter: 23 | Quote:
Forgive for my English | |
09-04-2009, 08:02 | #128 (permalink) |
Junior Member Join Date: Jun 2009 Age: 41
Member: 1047515 Status: Offline Thanks Meter: 5 | dear Mr cyclone box , my cyclone box met problem , cause i can not uploading the image ,so i write what it say : Nokia DCT4/WD2/885 service Tool Initialization started. Engine Revision:1 .0.07396 Handling device.{cyclone team},{cyclone boothloader} Initialization has failed -> No connection was established.or box is not in needed mode . these are words when i use cyclone ,it shows to me . what is the problem of this cyclone ? is it the quality problem ? cause i am new user ,so i dont know how to deal with it . hope you can teach me how to solve this problem cause it really make me crazy . thank you very much! best wishes Osmart |
09-04-2009, 08:07 | #129 (permalink) |
Member: 1047515 Status: Offline Thanks Meter: 5 | i brought 5 pcs cyclone box in one time ,the other 4 very goods ,only this one met such problem, is it the quality problem of this cyclone box ? what should i do so that i can solve it ? thank you very much ! |
09-04-2009, 08:15 | #130 (permalink) |
No Life Poster Join Date: Jan 2009 Location: England Age: 59
Member: 947561 Status: Offline Thanks Meter: 14,053 | Try to update again the firmware of your box from box maintance; if you can't, PM the serial number of your box to Siroya so he can put it in needed mode on the server to update again the firmware. BR Alex |
09-04-2009, 17:12 | #132 (permalink) |
Member: 947561 Status: Offline Thanks Meter: 14,053 | If was a problem of board you couldn't neither see the box in bootloader mode... in your issue is only the firmware to update again from box maintance. Just have alook at the sticky thread http://forum.gsmhosting.com/vbb/showthread.php?t=797559 BR Alex |
MANUAL: FIRST StEPS WITH CYCLONE BOX | Hell-GSM | Cyclonebox | 18 | 08-12-2012 17:51 |
Cyclone box not instaled | CHERIFA | Cyclonebox | 15 | 07-02-2009 21:33 |
6263 Tmobile U.S.A need to flash please help! Team Cyclone box is my first time flash | mymiela0419 | Cyclonebox | 3 | 05-21-2009 11:28 |
Welcome cyclone box india + world first vodafone india strom unlock ready | chiragp | Main Sales Section | 0 | 03-31-2009 07:13 |
