06-01-2009, 22:22 | #31 (permalink) |
No Life Poster Join Date: Sep 2006 Location: RETIRED ! Age: 47
Member: 348680 Status: Offline Thanks Meter: 1,273 | Free 5V to 9V Step-up DC - DC converter BR Ptt |
06-02-2009, 06:00 | #32 (permalink) | |
Freak Poster Join Date: Jul 2004 Location: 0xDEADBEEF Age: 42
Member: 71246 Status: Offline Thanks Meter: 40 | Quote:
Also here is log without External adapter: Code: HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2009, wk01 / wk06 Initializing security card... Card Serial Number: D20000XX Card Firmware Revision: 0109 Card is activated Box is activated Started box selftests procedure USB Voltage 4,97v PASSED MCU Voltage 3,29v PASSED Core Voltage 1,75v PASSED VBAT Voltage 0,01v PASSED VBAT Voltage 4,93v PASSED Box VPP disabled VPP Voltage 0,07v PASSED Internal Box VPP Enabled VPP Voltage 4,83v PASSED Box VPP disabled VPP Voltage 0,02v PASSED External Box VPP Enabled VPP Voltage 0,04v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Initializing FBUS... All initialized - Ready to work | |
06-05-2009, 14:42 | #33 (permalink) |
No Life Poster Join Date: Jan 2009 Location: England Age: 59
Member: 947561 Status: Offline Thanks Meter: 14,053 | I think if is in project to modify the PCB of cyclone is to consider this.. If is added this modify to obtain the 9V from a 5V external source we can use the same source to give power to the fone on the Vbatt. Using a power module like the NEO_49 one it will be powered by a stable 5V power supply solving all the APE problems.. This two modify together coul make of Cyclone the most reliable BOX adding stability in powering the mobile and speed in the flash operation just using only one external power supply 5V 1A. The only problem left open is the BSI value but this one can be easy solved using Good cable or the Cyclone Cable set when out.. no roblem of course for who is using a UFC. BR Alex |
The Following User Says Thank You to moulnisky For This Useful Post: |
06-05-2009, 23:11 | #34 (permalink) |
Member: 348680 Status: Offline Thanks Meter: 1,273 | Hi to all, i think, there is some alternatives an some things to consider: - Most of power supply issues are related to 5V provided by USB port are related to bad quality PC power supply, most motherboard take the power from 5VSB (stand-by power) for USB ports, and many other ICīs and if it is not good quality you can have troubles - The power delivered to the Phone is taken from USB port via LM1950T (U3 in Cyclone PCB) it is a switch 750mA continuous 1.4A peak. It`s like Neo_49 power module. Cyclone team, maybe can: - Provide the box with a cable like is used in some external 2.5" HDD cages: it have 2 USB A conectors, 1 with te 4 wires, the other only +5V and GND, and 1 USB B (box conector) it is to can use more power. - Provide the box with an 5V 2A switching power supply like the PSM11R-050 from PHIHONG TECHNOLOGY CO LTD (UL listed E127643) adding a switching step-up converter like MiH`09 but with SMD MC34063 in a daugtherboard (you can contiunes using actual PCB) to obtain the 9V for VPP and not take Power from USB, i think this is the best way to solve both troubles: VPP & Local mode- power suply to phone. But it increase the cost of the Box. BR Sorry my bad eng. Last edited by ptt; 06-05-2009 at 23:21. |
The Following User Says Thank You to ptt For This Useful Post: |
06-10-2009, 05:18 | #35 (permalink) |
No Life Poster Join Date: Jan 2006 Location: Pakistan
Member: 226457 Status: Offline Sonork: No more used Thanks Meter: 14,934 | I am using Smart clip Charger 9v- 500mA VPP Voltage 12.83v FAILED - IGNORED - Probably power supply is not connected Card Serial Number:--------- Card Firmware Revision: 0109 Card is activated Box is activated Started box selftests procedure USB Voltage 5.03v PASSED MCU Voltage 3.29v PASSED Core Voltage 1.82v PASSED VBAT Voltage 0.01v PASSED VBAT Voltage 4.97v PASSED Box VPP disabled VPP Voltage 0.00v PASSED Internal Box VPP Enabled VPP Voltage 5.01v PASSED Box VPP disabled VPP Voltage 0.04v PASSED External Box VPP Enabled VPP Voltage 12.83v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Initializing FBUS... All initialized - Ready to work |
06-10-2009, 05:42 | #36 (permalink) | |
No Life Poster Join Date: May 2006 Location: MOBILE SOFTZONE BHUBANESWAR IN
Member: 271478 Status: Offline Sonork: 1590868 Thanks Meter: 1,070 | Quote:
06-23-2009, 14:03 | #38 (permalink) |
Freak Poster Join Date: Aug 2006 Location: in ***'s hand
Member: 326924 Status: Offline Thanks Meter: 31 | Nokia DCT4/WD2/BB5 Service Tool Initialization Started, Engine Revision: 1.0.0.7828 Handling device: [Cyclone Team], [Cyclone Bootloader] Handling device: [Cyclone Team], [Cyclone Box] Initializing box... Box Firmware: Cyclone Nokia Application v1.05, (Jun 22 2009 12:23:29, gcc-4.2.2, RTOS v5.2.0), Type: Signed Production Application, Flags: CONST-TX2-PIN ; VISTA-SUPPORT ; BB5-NCK-CALC Box Serial Number: C00003E6 HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2008, wk32 Initializing security card... Card Serial Number: D100038B Card Firmware Revision: 0109 Card is activated Box is activated Started box selftests procedure USB Voltage 5.02v PASSED MCU Voltage 3.29v PASSED Core Voltage 1.82v PASSED VBAT Voltage 0.01v PASSED VBAT Voltage 4.92v PASSED Box VPP disabled VPP Voltage 0.02v PASSED Internal Box VPP Enabled Box Selftests Failed -> VPP Supply Voltage test failed, 0.04v is out of valid range Initializing FBUS... All initialized - Ready to work box failed seltest diagnostic...i measure with avometer it's about 9,5v dc adaptor that i use...what's wrong?i hv jumper R53..please help me.. |
06-23-2009, 22:11 | #39 (permalink) | |
No Life Poster Join Date: Feb 2005 Location: Poland Age: 34
Member: 117496 Status: Offline Sonork: 100.83919 Thanks Meter: 22,689 | Quote:
06-24-2009, 12:47 | #40 (permalink) |
Freak Poster Join Date: Dec 2002 Location: slovakia Age: 48
Member: 18876 Status: Offline Thanks Meter: 27 | I just tested a flashing speed with and without Vpp connected. IT SEEMS MY HW REVISION OF CYCLONE DOES'N HAVE VPP PIN (pin 9) CONNECTED !!! Only to capacitor C60 (0,1uF) and from it nowhere !!! For proper work is need to connect a small wire as is on picture (yellow colour). (just look bellow on pics) |
06-24-2009, 16:28 | #41 (permalink) | |
but you need find "R53" field and make cross on it (or put 0R) resistor | |
MXKey, PolarBox2, Infinity Box, Z3X, Cyclone Box And Many More Inside This Box | shahzaadbutt | Main Sales Section | 0 | 03-27-2010 07:33 |
MXKey, Infinity Box, Z3X, Cyclone Box And Many More Inside This Box | shahzaadbutt | Main Sales Section | 0 | 02-24-2010 10:51 |
Bomb!!Bomb!!Wifi box ,Cyclone box and Mx key dongle all is in good price | lotusgsm.com | Main Sales Section | 0 | 01-19-2010 10:04 |
Hi siroya nadeem gondal cyclone box and new product supporter | AY29!4LYF | Cyclonebox | 0 | 07-15-2009 17:47 |
How is cyclone box and who is behind this project? | Mr.3. | Off Topic Zone | 0 | 03-19-2009 04:37 |
