03-23-2009, 11:40 | #1 (permalink) |
No Life Poster Join Date: Feb 2005 Location: Poland Age: 34
Member: 117496 Status: Offline Sonork: 100.83919 Thanks Meter: 22,689 | *** Cyclone Box and VPP thing *** It's common used for older NOR phones (in latest NAND/ONENAND, they are fast enough without VPP). Before flashing phone with VPP make sure your cable have VPP connected to PIN 8 (or pin 9 on 10pin layout or pin 3 with adapter). Now there is 2 boosting options: 1. Box can either supply own, internal generated VPP signal, but only 5v. So you need attach VPP Pump, then 9V will appear on output, and flashing will be boosted. 2. Box can supply native VPP signal. But correct DC power supply needs be applied. 10v should be enough (input diode resulting in voltage drop - about 0,6V + power IC also dropping some, so keep note that), programming not taking a much current so 100-500mA will be very fine (of course more will not do any damage). You can check output voltage by running box selftest, so you can ensure you will kill or not kill your flash chip. As long as power supply manufacturers sometime likes to make some jokes |
The Following 53 Users Say Thank You to karwos For This Useful Post: |
04-05-2009, 21:05 | #3 (permalink) |
Member: 117496 Status: Offline Sonork: 100.83919 Thanks Meter: 22,689 | Would be anybody interested in PCB modification ? I can post such info, but then, remember that box will loose VPP funcionality ( can be restored later - no cuts , just restore one 0 Ohm resistor ), and TX2 signal needs be delivered on Service Pin 10. |
04-09-2009, 04:49 | #4 (permalink) |
Freak Poster Join Date: Apr 2006 Age: 39
Member: 266974 Status: Offline Thanks Meter: 43 | sorry sir please help 4 this Card Firmware Revision: 0109 Card is activated Box is activated Started box selftests procedure USB Voltage 4.98v PASSED MCU Voltage 3.25v PASSED Core Voltage 1.81v PASSED VBAT Voltage 1.31v PASSED VBAT Voltage 4.87v PASSED Box VPP disabled VPP Voltage 0.00v PASSED Internal Box VPP Enabled VPP Voltage 4.81v PASSED Box VPP disabled VPP Voltage 0.04v PASSED External Box VPP Enabled VPP Voltage 0.04v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Initializing FBUS... All initialized - Ready to work Processing pre-flash tasks... Pre-flash tasks finished Booting UPP... UPP ID: 3040 [HW_UNKNOWN] rm291__04.61.mcusw, Type: Flash Image, Algo: DCT4, DCT4 ALGORITHM Flashbus Write baud set to 100Kbits u3_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.77.0, Algo: DCT4 Box VPP disabled Internal Phone VPP Selected PLL Factor: 3 FlashChip[0]: 0x00208804 @ 0x01000000, ST, SectorSize: 128kB, Ext: 00007321 Signature: AD7EB61A1BBE0BE27D586BE4DBEE6514 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 51Kbits u3_intel.fia, Type: Algorithm, Target: FlashChip[0] 0x00208804 (128Mbits), Rev: 7.4.77.0, Algo: DCT4 ALGORITHM Nominal VPP Voltage: 9V, Detected: 0.00V MSID-Crypted: 8411D09FE03EFDBDACD0C5F9B2 Using MSID-FAID Cache, Not wasting card FAID-Crypted: 2AEA41225CE524B605171EC3 Flashbus Write baud set to 6.50Mbits 3 Region(s) to erase Erasing NOR Region [0x01000000-0x0101FFFF] Flash Erase Failed -> Failed at 0x01000000:0x00020000 Box VPP disabled Processing Flash Image Failed -> Erase Failed, Region: 0 Failed to Flash -> Problem with processing MCU Image file |
04-10-2009, 10:06 | #6 (permalink) | |
Freak Poster Join Date: Oct 2007 Location: sssssssssss.....t
Member: 619475 Status: Offline Thanks Meter: 63 | yes ..I got it this happen sometime .. may be depend on usb A to B is low quality or fbus too but never obstacle before, where with another box everthing is ok it,s strange..yea... Quote:
04-14-2009, 23:31 | #13 (permalink) |
Freak Poster Join Date: Nov 2007 Location: egypt Age: 37
Member: 625817 Status: Offline Sonork: 1592120 Thanks Meter: 32 | can i ask one question what about tx2??? when i try use service pin 10 my box say that Partitioning OK Started group flash erase EraseArea[0,CMT]: 0x00040000-0x00082FFF, ONENAND EraseArea[0,CMT]: 0x00083400-0x0087FFFF, ONENAND EraseArea[0,CMT]: 0x00B80000-0x05F7FFFF, ONENAND Erase Partition (CMT) Erase Partition (CMT) Waiting 320s for erasure finish... Erase taken 1.110s Writing all blocks... Writing CMT ADA Certificate... Block Write Failed -> Failed to write CMT cert data (3), Programming Status Error Processing Flash Image Failed -> Failed to write all blocks Failed to Process all Image files -> Failed to process RM223_21.0.010_prd.C00 |
04-18-2009, 02:16 | #14 (permalink) | |
Member: 117496 Status: Offline Sonork: 100.83919 Thanks Meter: 22,689 | Quote:
The Following User Says Thank You to karwos For This Useful Post: |
05-20-2009, 09:31 | #15 (permalink) |
Freak Poster Join Date: Feb 2003 Location: 梧州市
Member: 23253 Status: Offline Thanks Meter: 28 | Started box selftests procedure USB Voltage 4.99v PASSED MCU Voltage 3.28v PASSED Core Voltage 1.76v PASSED VBAT Voltage 0.83v PASSED VBAT Voltage 4.68v PASSED Box VPP disabled VPP Voltage 0.04v PASSED Internal Box VPP Enabled VPP Voltage 4.92v PASSED Box VPP disabled VPP Voltage 0.02v PASSED External Box VPP Enabled VPP Voltage 0.04v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Initializing FBUS... All initialized - Ready to work MCU Version V 05wk07v48.2 MCU Date 04-10-07 Product RM-180 Manufacturer (c) Nokia. IMEI 353089020918245 Mastercode 1031445342 IMEI Spare 3A35800902192804 IMEI SV 3335800902192804F9000000 PPM V 5.0819.4.0.1, 07-05-08, RM-180, (C)Nokiaj4.V 5.0819.4.0.1-APAC1, 07-05-08, RM-180, (c)Nokian256o16054 PSN CIJ206164 Product Code 0531463 Basic Product Code 0530940 PSD 0000001700000000 APE SW V 5.0819.4.0.1, 07-05-08, RM-180, (C)Nokia APE Variant V 5.0819.4.0.1-APAC1, 07-05-08, RM-180, (c)Nokia APE HW 256 APE ADSP 16054 RETU 32 TAHVO 53 AHNE 22 HW 5001i,(V 5.0819.4.0.1, 07-05-08, RM-180, (C)Nokiaj4.V 5.0819.4.0.1-APAC1, 07-05-08, RM-180, (c)Nokian256o16054 PCI i,(V 5.0819.4.0.1, 07-05-08, RM-180, (C)Nokiaj4.V 5.0819.4.0.1-APAC1, 07-05-08, RM-180, (c)Nokian256o16054 UEM V 5.0819.4.0.1, 07-05-08, RM-180, (C)Nokiaj4.V 5.0819.4.0.1-APAC1, 07-05-08, RM-180, (c)Nokian256o16054 UPP V 5.0819.4.0.1, 07-05-08, RM-180, (C)Nokiaj4.V 5.0819.4.0.1-APAC1, 07-05-08, RM-180, (c)Nokian256o16054 RFIC 150a160f DSP rolf_espresso_05wk07v29p1 LCD V 5.0819.4.0.1, 07-05-08, RM-180, (C)Nokiaj4.V 5.0819.4.0.1-APAC1, 07-05-08, RM-180, (c)Nokian256o16054 BT V 5.0819.4.0.1, 07-05-08, RM-180, (C)Nokiaj4.V 5.0819.4.0.1-APAC1, 07-05-08, RM-180, (c)Nokian256o16054 Failed to read info -> Failed to read extended info |
MXKey, PolarBox2, Infinity Box, Z3X, Cyclone Box And Many More Inside This Box | shahzaadbutt | Main Sales Section | 0 | 03-27-2010 07:33 |
MXKey, Infinity Box, Z3X, Cyclone Box And Many More Inside This Box | shahzaadbutt | Main Sales Section | 0 | 02-24-2010 10:51 |
Bomb!!Bomb!!Wifi box ,Cyclone box and Mx key dongle all is in good price | lotusgsm.com | Main Sales Section | 0 | 01-19-2010 10:04 |
Hi siroya nadeem gondal cyclone box and new product supporter | AY29!4LYF | Cyclonebox | 0 | 07-15-2009 17:47 |
How is cyclone box and who is behind this project? | Mr.3. | Off Topic Zone | 0 | 03-19-2009 04:37 |
