04-16-2010, 19:02 | #16 (permalink) |
Banned Join Date: Feb 2008
Member: 715429 Status: Offline Thanks Meter: 258 | 1661 UNlocking Ok. Phone Unlocked Code: Handling device: [Cyclone Team], [Cyclone Box] Initializing box... Box Firmware: Cyclone Nokia Application v01.35, (Apr 16 2010 18:05:39, gcc v4.3.2, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2010 wk13 Hardware Platform: Cyclone Classic Flasher Interface (c) 2008,2009 KarwosLabs Box Serial Number: residentGSM HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2008, wk32 Initializing security card... Card Serial Number: residentGSM Card Firmware Revision: 0109 Card is activated Box is activated Started box selftests procedure USB Voltage 4,89v PASSED MCU Voltage 3,27v PASSED Core Voltage 1,81v PASSED VBAT Voltage 0,01v PASSED VBAT Voltage 4,76v PASSED Box VPP disabled VPP Voltage 0,04v PASSED Internal Box VPP Enabled VPP Voltage 4,66v PASSED Box VPP disabled VPP Voltage 0,00v PASSED External Box VPP Enabled VPP Voltage 0,00v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Super DCT4 Activation: TRUE Initializing FBUS... All initialized - Ready to work 2 USB Voltage 4,89v PASSED MCU Voltage 3,27v PASSED Core Voltage 1,81v PASSED VBAT Voltage 0,01v PASSED VBAT Voltage 4,76v PASSED Box VPP disabled VPP Voltage 0,04v PASSED Internal Box VPP Enabled VPP Voltage 4,66v PASSED Box VPP disabled VPP Voltage 0,00v PASSED External Box VPP Enabled VPP Voltage 0,00v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Super DCT4 Activation: TRUE Initializing FBUS... All initialized - Ready to work Failed to Unlock DCT4 Plus -> Phone not detected Failed to read info -> Phone not detected Failed to read info -> Phone not detected Booting UPP... UPP ID: 2293 [HW_UNKNOWN] Flashbus Write baud set to 100Kbits u3_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.79.0, Algo: DCT4 2nd Boot Loading Failed -> No answer from 2nd Boot Loader (FF) Failed to Check DCT4 Flashing Bus -> Problem with sending 2nd Boot Loader Booting UPP... UPP ID: 2293 [HW_UNKNOWN] Flashbus Write baud set to 100Kbits u3_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.79.0, Algo: DCT4 PLL Factor: 3 FlashChip[0]: 0x002088C0 @ 0x01000000, ST, SectorSize: 64kB, Ext: 00007321 Signature: AD7EB61A23100340C605E40120A26514 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 4Kbits u3_st_i.fia, Type: Algorithm, Target: FlashChip[0] 0x002088C0 (64Mbits), Rev: 7.4.79.0, Algo: DCT4 ALGORITHM Nominal VPP Voltage: 9V, Detected: 0,00V Terminating flash session Boot operation took 6.656s Check Flashing Bus finished MCU Version V 03.70 MCU Date 04-14-09 Product RH-121 Manufacturer (c) Nokia XXXX 011884001214307 Mastercode 122744465 Proceeding with RSA Unlock... Asic 11 HW Signature CCCAC05CA0E38622 Simlock Server SIMLOCK SERVER Simlock Key 7321230140723740 Simlock Profile 800000000003000B Simlock Aux 000B0000 Simlock XXXX 00000118840012143000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 732123 Simlock [2,1] State: CLOSED Type: MCC-MNC Data: 74000F Simlock [3,1] State: CLOSED Type: MCC-MNC Data: 71606F Simlock [4,1] State: CLOSED Type: MCC-MNC Data: 73404F Simlock [5,1] State: CLOSED Type: MCC-MNC Data: 73002F Simlock [6,1] State: CLOSED Type: MCC-MNC Data: 72207F Simlock [7,1] State: CLOSED Type: MCC-MNC Data: 74807F Simlock [8,1] State: CLOSED Type: MCC-MNC Data: 70403F Simlock [9,1] State: CLOSED Type: MCC-MNC Data: 70604F Simlock [10,1] State: CLOSED Type: MCC-MNC Data: 71030F Simlock [11,1] State: CLOSED Type: MCC-MNC Data: 21407F Simlock [12,1] State: CLOSED Type: MCC-MNC Data: 21402F Simlock [13,1] State: CLOSED Type: MCC-MNC Data: 33403F Simlock [14,1] State: CLOSED Type: MCC-MNC Data: 71402F Asking card to sign HW Signature... Signed OK (B1A7F0E6117F2B3F263344ED801F43E62DA7D04A) Calculating SP... Writing SP... New SP Accepted OK! Phone unlocked OK! 3 Handling device: [Cyclone Team], [Cyclone Box] Initializing box... Box Firmware: Cyclone Nokia Application v01.35, (Apr 16 2010 18:05:39, gcc v4.3.2, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2010 wk13 Hardware Platform: Cyclone Classic Flasher Interface (c) 2008,2009 KarwosLabs Box Serial Number: residentGSM HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2008, wk32 Initializing security card... Card Serial Number: residentGSM Card Firmware Revision: 0109 Card is activated Box is activated Started box selftests procedure USB Voltage 4,89v PASSED MCU Voltage 3,27v PASSED Core Voltage 1,81v PASSED VBAT Voltage 0,01v PASSED VBAT Voltage 4,76v PASSED Box VPP disabled VPP Voltage 0,04v PASSED Internal Box VPP Enabled VPP Voltage 4,66v PASSED Box VPP disabled VPP Voltage 0,00v PASSED External Box VPP Enabled VPP Voltage 0,00v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Super DCT4 Activation: TRUE Initializing FBUS... All initialized - Ready to work Failed to Unlock DCT4 Plus -> Phone not detected Failed to read info -> Phone not detected Failed to read info -> Phone not detected Booting UPP... UPP ID: 2293 [HW_UNKNOWN] Flashbus Write baud set to 100Kbits u3_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.79.0, Algo: DCT4 2nd Boot Loading Failed -> No answer from 2nd Boot Loader (FF) Failed to Check DCT4 Flashing Bus -> Problem with sending 2nd Boot Loader Booting UPP... UPP ID: 2293 [HW_UNKNOWN] Flashbus Write baud set to 100Kbits u3_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.79.0, Algo: DCT4 PLL Factor: 3 FlashChip[0]: 0x002088C0 @ 0x01000000, ST, SectorSize: 64kB, Ext: 00007321 Signature: AD7EB61A23100340C605E40120A26514 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 4Kbits u3_st_i.fia, Type: Algorithm, Target: FlashChip[0] 0x002088C0 (64Mbits), Rev: 7.4.79.0, Algo: DCT4 ALGORITHM Nominal VPP Voltage: 9V, Detected: 0,00V Terminating flash session Boot operation took 6.656s Check Flashing Bus finished MCU Version V 03.70 MCU Date 04-14-09 Product RH-121 Manufacturer (c) Nokia XXXX 011884001214307 Mastercode 122744465 Proceeding with RSA Unlock... Asic 11 HW Signature CCCAC05CA0E38622 Simlock Server SIMLOCK SERVER Simlock Key 7321230140723740 Simlock Profile 800000000003000B Simlock Aux 000B0000 Simlock XXXX 00000118840012143000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 732123 Simlock [2,1] State: CLOSED Type: MCC-MNC Data: 74000F Simlock [3,1] State: CLOSED Type: MCC-MNC Data: 71606F Simlock [4,1] State: CLOSED Type: MCC-MNC Data: 73404F Simlock [5,1] State: CLOSED Type: MCC-MNC Data: 73002F Simlock [6,1] State: CLOSED Type: MCC-MNC Data: 72207F Simlock [7,1] State: CLOSED Type: MCC-MNC Data: 74807F Simlock [8,1] State: CLOSED Type: MCC-MNC Data: 70403F Simlock [9,1] State: CLOSED Type: MCC-MNC Data: 70604F Simlock [10,1] State: CLOSED Type: MCC-MNC Data: 71030F Simlock [11,1] State: CLOSED Type: MCC-MNC Data: 21407F Simlock [12,1] State: CLOSED Type: MCC-MNC Data: 21402F Simlock [13,1] State: CLOSED Type: MCC-MNC Data: 33403F Simlock [14,1] State: CLOSED Type: MCC-MNC Data: 71402F Asking card to sign HW Signature... Signed OK (B1A7F0E6117F2B3F263344ED801F43E62DA7D04A) Calculating SP... Writing SP... New SP Accepted OK! Phone unlocked OK! MCU Version V 03.70 MCU Date 04-14-09 Product RH-121 Manufacturer (c) Nokia XXXX 011884001214307 Mastercode 122744465 XXXX Spare 0A11880410123400 XXXX SV 0311880410123420F5000000 PPM V 03.70, 04-14-09, RH-121, (c) Nokia, UB PSN RDF812823 Product Code 0586970 Module Code 0204020 Basic Product Code 0586754 PSD 0000001800000000 HW 2000 UEM 1328 UPP 8851 RFIC 0700 DSP ICPR81_ 09w10_UPP LCD SDI:BOHAIv92, NT39121 ADSP Sw p+V 03.70\n04-14-09\nRH-121\n(c) NMP\nub_lta Asic 11 HW Signature CCCAC05CA0E38622 Simlock Server SIMLOCK SERVER Simlock Key 0010100000000000 Simlock Profile 800000000003000B Simlock Aux 000B0000 Simlock XXXX 00000118840012143000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [1,2] State: OPENED Type: GID Data: FFFF Simlock [1,3] State: OPENED Type: GID Data: FFFF Simlock [1,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [1,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [2,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [2,2] State: OPENED Type: GID Data: FFFF Simlock [2,3] State: OPENED Type: GID Data: FFFF Simlock [2,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [2,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [3,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [3,2] State: OPENED Type: GID Data: FFFF Simlock [3,3] State: OPENED Type: GID Data: FFFF Simlock [3,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [3,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [4,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [4,2] State: OPENED Type: GID Data: FFFF Simlock [4,3] State: OPENED Type: GID Data: FFFF Simlock [4,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [4,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [5,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [5,2] State: OPENED Type: GID Data: FFFF Simlock [5,3] State: OPENED Type: GID Data: FFFF Simlock [5,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [5,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [6,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [6,2] State: OPENED Type: GID Data: FFFF Simlock [6,3] State: OPENED Type: GID Data: FFFF Simlock [6,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [6,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [7,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [7,2] State: OPENED Type: GID Data: FFFF Simlock [7,3] State: OPENED Type: GID Data: FFFF Simlock [7,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [7,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF residentGSM... THE BEST TOOL BOX Last edited by ptt; 04-16-2010 at 22:11. Reason: add code tag |
04-16-2010, 19:03 | #17 (permalink) |
Super Moderator Join Date: Jul 2008 Location: Villa del rosario/Nsd Colombia
Member: 813309 Status: Offline Thanks Meter: 1,912 | Is Good Update But MCU Version V 03.70 MCU Date 14-04-09 Product RH-122 Manufacturer (c) Nokia IMEI 01188300132xxxx Mastercode 7246665071 Proceeding with RSA Unlock... Warning: Failed to read SP Info, Assuming defaults Warning: Failed to read SP Info, Assuming defaults Warning: Failed to read SP Info, Assuming defaults Failed to Unlock DCT4 Plus -> Initial SP corrupted or Baseband5 phone detected Please Add Repair Contact Service |
04-16-2010, 19:07 | #20 (permalink) | |
No Life Poster Join Date: Jul 2006 Location: DAVIE FLORIDA
Member: 309299 Status: Offline Thanks Meter: 259 | Quote:
http://forum.gsmhosting.com/vbb/5722377-post13.html | |
04-16-2010, 19:08 | #21 (permalink) | |
No Life Poster Join Date: Jan 2009 Location: England Age: 59
Member: 947561 Status: Offline Thanks Meter: 14,053 | Quote:
The Following 6 Users Say Thank You to moulnisky For This Useful Post: |
04-16-2010, 19:11 | #25 (permalink) |
Member: 309299 Status: Offline Thanks Meter: 259 | you dont answer my question can i unlock with this new update those phones like 2760 rm391 from t mobile version 6.82 and 6.83 that wasent support before |
04-16-2010, 19:18 | #29 (permalink) |
No Life Poster Join Date: Aug 2009 Location: USA
Member: 1096162 Status: Offline Thanks Meter: 411 | Contact service hi ... check please 1661 contact service UNLOCK done... Code: MCU Version V 03.70 MCU Date 14-04-09 Product RH-122 Manufacturer (c) Nokia IMEI 011886001477842 Mastercode 4016735661 IMEI Spare 0A11880610748704 IMEI SV 0311880610748724F5000000 PPM V 03.70, 14-04-09, RH-122, (c) Nokia, AE PSD 0000000D00000000 UEM 1328 UPP 8851 RFIC 0700 DSP ICPR81_09w10_UPP LCD WIN:BOHAIv91, NT39121 ADSP Sw p'V 03.70\n14-04-09\nRH-122\n(c) NMP\nae Failed to read info -> Failed to read SP info MCU Version V 03.70 MCU Date 14-04-09 Product RH-122 Manufacturer (c) Nokia IMEI 011886001477842 Mastercode 4016735661 Proceeding with RSA Unlock... Warning: Failed to read SP Info, Assuming defaults Asic 11 HW Signature 7DE916F132B3D84E Simlock Server SIMLOCK SERVER Simlock Key 0000000000000000 Simlock Profile 0000000000030000 Simlock Aux 000B0000 Simlock IMEI 00000118860014778400 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Asking card to sign HW Signature... Signed OK (442151941408709ACD3517CC6A4488AF71B0885D) Calculating SP... Writing SP... New SP Accepted OK! Phone unlocked OK! MCU Version V 03.70 MCU Date 14-04-09 Product RH-122 Manufacturer (c) Nokia IMEI 011886001477842 Mastercode 4016735661 IMEI Spare 0A11880610748704 IMEI SV 0311880610748724F5000000 PPM V 03.70, 14-04-09, RH-122, (c) Nokia, AE PSD 0000000D00000000 UEM 1328 UPP 8851 RFIC 0700 DSP ICPR81_09w10_UPP LCD WIN:BOHAIv91, NT39121 ADSP Sw p'V 03.70\n14-04-09\nRH-122\n(c) NMP\nae Asic 11 HW Signature 7DE916F132B3D84E Simlock Server SIMLOCK SERVER Simlock Key 0010100000000000 Simlock Profile 800000000003000B Simlock Aux 000B0000 Simlock IMEI 00000118860014778400 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [1,2] State: OPENED Type: GID Data: FFFF Simlock [1,3] State: OPENED Type: GID Data: FFFF Simlock [1,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [1,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [2,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [2,2] State: OPENED Type: GID Data: FFFF Simlock [2,3] State: OPENED Type: GID Data: FFFF Simlock [2,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [2,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [3,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [3,2] State: OPENED Type: GID Data: FFFF Simlock [3,3] State: OPENED Type: GID Data: FFFF Simlock [3,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [3,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [4,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [4,2] State: OPENED Type: GID Data: FFFF Simlock [4,3] State: OPENED Type: GID Data: FFFF Simlock [4,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [4,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [5,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [5,2] State: OPENED Type: GID Data: FFFF Simlock [5,3] State: OPENED Type: GID Data: FFFF Simlock [5,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [5,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [6,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [6,2] State: OPENED Type: GID Data: FFFF Simlock [6,3] State: OPENED Type: GID Data: FFFF Simlock [6,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [6,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [7,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [7,2] State: OPENED Type: GID Data: FFFF Simlock [7,3] State: OPENED Type: GID Data: FFFF Simlock [7,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [7,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF besta regards |
$50 Reward for unlocking my 6150!!! | TheDon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 03-23-2015 14:21 |
Phone Stuff for FREE & KEy-GEn For Logo Editor ! | BoNtEk - ThA WtC MeMbA | Nokia Multimedia | 8 | 10-31-2012 20:17 |
