05-19-2009, 22:29 | #1 (permalink) |
No Life Poster Join Date: Apr 2008 Location: Nowhere
Member: 739774 Status: Offline Thanks Meter: 89 | How to repair CONTACT SERVICE on 6500C with Cyclone Box? I have a 6500 Classic, which after unlock shows: Contact Service!! I didn't chek the version, phone version not supported for unlock. That's why I get Contact server, Is any way to repair this? Thanks |
05-19-2009, 23:32 | #4 (permalink) |
Member: 739774 Status: Offline Thanks Meter: 89 | bro, Phone is dead, can not also flash with highest version! I can get any Info. Nokia DCT4/WD2/BB5 Service Tool Initialization Started, Engine Revision: 1.0.0.7396 Handling device: [Cyclone Team], [Cyclone Bootloader] Handling device: [Cyclone Team], [Cyclone Box] Initializing box... Box Firmware: Cyclone Nokia Application v1.04, (May 12 2009 00:28:13, gcc-4.2.2, RTOS v5.2.0), Type: Signed Production Application, Flags: CONST-TX2-PIN ; VISTA-SUPPORT Box Serial Number: ******** HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2008, wk27 Initializing security card... Card Serial Number: ******* Card Firmware Revision: 0109 Card is activated Box is activated Started box selftests procedure USB Voltage 5,06v PASSED MCU Voltage 3,28v PASSED Core Voltage 1,78v PASSED VBAT Voltage 0,84v PASSED VBAT Voltage 4,07v PASSED Box VPP disabled VPP Voltage 0,04v PASSED Internal Box VPP Enabled VPP Voltage 4,92v PASSED Box VPP disabled VPP Voltage 0,00v PASSED External Box VPP Enabled VPP Voltage 0,04v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Initializing FBUS... All initialized - Ready to work Failed to read info -> Phone not detected Thanx |
05-20-2009, 09:32 | #11 (permalink) | |
No Life Poster Join Date: Nov 2008 Location: Mardan
Member: 897494 Status: Offline Sonork: 100.1581481 Thanks Meter: 1,102 | Quote:
05-21-2009, 19:35 | #13 (permalink) | |
Member: 739774 Status: Offline Thanks Meter: 89 | Quote:
Hi, bro... I get still this: Nokia DCT4/WD2/BB5 Service Tool Initialization Started, Engine Revision: 1.0.0.7396 Handling device: [Cyclone Team], [Cyclone Bootloader] Handling device: [Cyclone Team], [Cyclone Box] Initializing box... Box Firmware: Cyclone Nokia Application v1.04, (May 12 2009 00:28:13, gcc-4.2.2, RTOS v5.2.0), Type: Signed Production Application, Flags: CONST-TX2-PIN ; VISTA-SUPPORT Box Serial Number: ********** HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2008, wk27 Initializing security card... Card Serial Number: ******* Card Firmware Revision: 0109 Card is activated Box is activated Started box selftests procedure USB Voltage 5,09v PASSED MCU Voltage 3,28v PASSED Core Voltage 1,78v PASSED VBAT Voltage 0,01v PASSED VBAT Voltage 5,00v PASSED Box VPP disabled VPP Voltage 0,00v PASSED Internal Box VPP Enabled VPP Voltage 4,97v PASSED Box VPP disabled VPP Voltage 0,02v PASSED External Box VPP Enabled VPP Voltage 0,04v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Initializing FBUS... All initialized - Ready to work Failed to Process all Image files -> No images in queue to process, add some Failed to Process all Image files -> No images in queue to process, add some Booting RAP... Failed to Check BB5 Flashing Bus -> Failed to Boot / Prepare Phone Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101003000 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 14A00104D4D57C564097ACB90804B37910DD83FC CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_ROM_ID: 273F6D55DFAAF68F RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.30.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits FlashChip[0,CMT]: 0x00EC220C00008921, Samsung, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.1.40.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 4.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: D0D8948DEF333BF18141EF4C3D0FB1B002EB5D88 APE Subsystem Not Found Restarting MCU... | |
05-22-2009, 18:31 | #15 (permalink) | |
That was SL3, 6500C version 05.95!! This version is not supported for unlock! I had to chek it before unlock. After unlock, Unlock was Finish! but I got only Contact Service. I've also saved RPL from phone, before unlock! I have writed it on phone, Now phone is totally dead! I have tried to flash with version 05.95 with FBUS, dead USB... but still not helped!! Thanks | |
how to repair contact service on samsung E 300 | Unlockdiscount | Samsung Hardware Repair | 0 | 06-07-2006 15:41 |
How to repair Contact Service with DCT4 flasher??? | Drug_Store | Nokia Digital Core Technology 4 ( DCT-4 ) | 1 | 03-16-2003 07:12 |
how to repair contact service | aliwali | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 12-23-2001 17:56 |
