06-19-2009, 07:16 | #151 (permalink) |
No Life Poster Join Date: Dec 2008 Location: iCloud ID Removed Service
Member: 917576 Status: Offline Sonork: QQ:366688456 Thanks Meter: 533 | 6670 Flash ok Code: Nokia DCT4/WD2/BB5 Service Tool Initialization Started, Engine Revision: 1.0.0.7396 Handling device: [Cyclone Team], [Cyclone Box] Initializing box... Box Firmware: Cyclone Nokia Application v1.04, (May 12 2009 00:28:13, gcc-4.2.2, RTOS v5.2.0), Type: Signed Production Application, Flags: CONST-TX2-PIN ; VISTA-SUPPORT Box Serial Number: C0000A19 HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2008, wk27 Initializing security card... Card Serial Number: D0000548 Card Firmware Revision: 0109 Card is activated Box is activated Started box selftests procedure USB Voltage 4.95v PASSED MCU Voltage 3.28v PASSED Core Voltage 1.79v PASSED VBAT Voltage 1.27v PASSED VBAT Voltage 4.83v PASSED Box VPP disabled VPP Voltage 0.09v PASSED Internal Box VPP Enabled VPP Voltage 4.77v PASSED Box VPP disabled VPP Voltage 0.04v PASSED External Box VPP Enabled VPP Voltage 0.02v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Initializing FBUS... All initialized - Ready to work Processing pre-flash tasks... Pre-flash tasks finished Booting UPP... UPP ID: 1081 [HW_UPP_WD2_v3_1] RH51_67PE706420.C2, Type: Flash Image, Algo: WD2 BT2, WD2 ALGORITHM Flashbus Write baud set to 100Kbits w3_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.76.0, Algo: WD2 BT2 Box VPP disabled Internal Phone VPP Selected PLL Factor: 4 FlashChip[0]: 0x00ECDDFE @ 0x00000000, Samsung, SectorSize: 64kB, Ext: 00000121 FlashChip[1]: 0x00ECEEFE @ 0x02000000, Samsung, SectorSize: 64kB, Ext: 00000121 FlashChip[2]: 0x00EC2250 @ 0x04000000, Samsung, SectorSize: 64kB, Ext: 00000121 Signature: C60000EA750100EA780100EA7B0100EA Flashbus Write baud set to 333Kbits Flashbus Read baud set to 51Kbits w3_amd.fia, Type: Algorithm, Target: FlashChip[0] 0x00ECDDFE (128Mbits), Rev: 7.4.76.0, Algo: WD2 ALGORITHM Nominal VPP Voltage: 9V, Detected: 0.02V MSID-Crypted: 844F59D7468942415E531770EA MSID-Plain: 3E4EBAF700D4F450A8000000 FAID-Crypted: 3D50F9F56BDBE466779954BC Flashbus Write baud set to 1.80Mbits 4 Region(s) to erase Erasing NOR Region [0x00000000-0x0000FFFF] Erasing NOR Region [0x00010000-0x00FFFFFF] Erasing NOR Region [0x02000000-0x029FFFFF] Erasing NOR Region [0x02FC0000-0x02FEFFFF] Erase taken 180.313s Writing 3322 blocks... All blocks written OK! Time taken 231.281s Terminating flash session Box VPP disabled Booting UPP... UPP ID: 1081 [HW_UPP_WD2_v3_1] RH67PE706420.31, Type: Flash Image, Algo: WD2 BT2, WD2 ALGORITHM Flashbus Write baud set to 100Kbits w3_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.76.0, Algo: WD2 BT2 Box VPP disabled Internal Phone VPP Selected PLL Factor: 4 FlashChip[0]: 0x00ECDDFE @ 0x00000000, Samsung, SectorSize: 64kB, Ext: 00000121 FlashChip[1]: 0x00ECEEFE @ 0x02000000, Samsung, SectorSize: 64kB, Ext: 00000121 FlashChip[2]: 0x00EC2250 @ 0x04000000, Samsung, SectorSize: 64kB, Ext: 00000121 Signature: C60000EA750100EA780100EA7B0100EA Flashbus Write baud set to 333Kbits Flashbus Read baud set to 51Kbits w3_amd.fia, Type: Algorithm, Target: FlashChip[0] 0x00ECDDFE (128Mbits), Rev: 7.4.76.0, Algo: WD2 ALGORITHM Nominal VPP Voltage: 9V, Detected: 0.04V MSID-Crypted: 844F59D7468942415E531770EA Using MSID-FAID Cache, Not wasting card FAID-Crypted: 3D50F9F56BDBE466779954BC Flashbus Write baud set to 1.80Mbits 2 Region(s) to erase Erasing NOR Region [0x00000000-0x0000FFFF] Erasing NOR Region [0x02B00000-0x02DBFFFF] Erase taken 19.234s Writing 358 blocks... All blocks written OK! Time taken 24.578s Terminating flash session Box VPP disabled Processing post-flash tasks... Setting Factory Defaults... Factory defaults OK Last edited by ptt; 01-17-2010 at 03:25. Reason: add code tag |
06-19-2009, 10:30 | #153 (permalink) |
No Life Poster Join Date: Nov 2008 Location: RVIII
Member: 890926 Status: Offline Thanks Meter: 2,053 | N73 Unlocked Code: Nokia DCT4/WD2/BB5 Service Tool Initialization Started, Engine Revision: 1.0.0.7396 Handling device: [Cyclone Team], [Cyclone Bootloader] Handling device: [Cyclone Team], [Cyclone Box] Initializing box... Box Firmware: Cyclone Nokia Application v1.04, (May 12 2009 00:28:13, gcc-4.2.2, RTOS v5.2.0), Type: Signed Production Application, Flags: CONST-TX2-PIN ; VISTA-SUPPORT Box Serial Number: C0123456 HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2008, wk32 Initializing security card... Card Serial Number: D1123456 Card Firmware Revision: 0109 Card is activated Box is activated Started box selftests procedure USB Voltage 4.89v PASSED MCU Voltage 3.28v PASSED Core Voltage 1.82v PASSED VBAT Voltage 0.01v PASSED VBAT Voltage 4.72v PASSED Box VPP disabled VPP Voltage 0.00v PASSED Internal Box VPP Enabled VPP Voltage 4.66v PASSED Box VPP disabled VPP Voltage 0.04v PASSED External Box VPP Enabled VPP Voltage 0.00v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Initializing FBUS... All initialized - Ready to work MCU Version V 05wk47v34.1 MCU Date 05-10-06 Product RM-133 Manufacturer (c) Nokia. IMEI 351851018909896 Mastercode 245461510 IMEI Spare 3A15580181098909 IMEI SV 3315580181098909F0000000 PSN CNF497098 Product Code 0539684 Module Code 0202855 Basic Product Code 0527006 PSD 0000002200000000 RETU 15 TAHVO 21 AHNE 30 HW 6000 RFIC 17191719 DSP scarfe_05wk46v39 Simlock Server SIMLOCK SERVER VERSION 63 Simlock Key 5150200000000000 Simlock Profile 0000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock[1,1] State: CLOSED Type: MCC-MNC Data: 51502F Simlock[2,1] State: CLOSED Type: MCC-MNC Data: 51502F Booting RAP... APE_SYSTEM_ASIC_ID: 17100708 APE_ASIC_MODE_ID: 00 APE_PUBLIC_ID: 2BCA0C9A4271CF7DF25D368831C4E9255412873A APE_ROOT_KEY_HASH: 49A97E826B93BA20B7ED0B082475C00500000000 APE_ROM_ID: 1DFD66132C872FD4 CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101003000 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B21 CMT_PUBLIC_ID: 0CE0000D73BF0054A594269B2077246C374EADC7 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_ROM_ID: 273F6D55DFAAF68F RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.30.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits FlashChip[0,CMT]: 0x00EC22E800006921, Samsung, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.1.40.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 4.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 5E8D0D504A0902E261268C14FCD8A2C9093523BC helen3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.35.0, Algo: BB5 FlashChip[0,APE]: 0x00EC00A100800015, Samsung, NAND FlashContent[0,APE]: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF, NAND h3_sam_nand_format.fg, Type: Algorithm, Rev: 0.1.16.255, Algo: OMAP1610 FORMAT ALG Box VPP disabled Internal APE Phone VPP Enabled Failed to Read All Certificates -> Failed to Boot / Prepare Phone BB5 Unlock Started... MCU Version V 05wk47v34.1 MCU Date 05-10-06 Product RM-133 Manufacturer (c) Nokia. IMEI 351851018909896 Mastercode 245461510 Simlock Server SIMLOCK SERVER VERSION 63 Simlock Key 5150200000000000 Simlock Profile 0000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock[1,1] State: CLOSED Type: MCC-MNC Data: 51502F Simlock[2,1] State: CLOSED Type: MCC-MNC Data: 51502F Reading Security Block... Security block OK! Determining PA Simlock... Booting RAP... APE_SYSTEM_ASIC_ID: 17100708 APE_ASIC_MODE_ID: 00 APE_PUBLIC_ID: 2BCA0C9A4271CF7DF25D368831C4E9255412873A APE_ROOT_KEY_HASH: 49A97E826B93BA20B7ED0B082475C00500000000 APE_ROM_ID: 1DFD66132C872FD4 CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101003000 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B21 CMT_PUBLIC_ID: 0CE0000D73BF0054A594269B2077246C374EADC7 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_ROM_ID: 273F6D55DFAAF68F RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.30.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits FlashChip[0,CMT]: 0x00EC22E800006921, Samsung, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.1.40.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 4.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 5E8D0D504A0902E261268C14FCD8A2C9093523BC APE Boot skipped on user request Restarting MCU... Determined PA Simlock: PA_SL Checking for Rootkey Hash support... Restarting MCU... Booting RAP... APE_SYSTEM_ASIC_ID: 17100708 APE_ASIC_MODE_ID: 00 APE_PUBLIC_ID: 2BCA0C9A4271CF7DF25D368831C4E9255412873A APE_ROOT_KEY_HASH: 49A97E826B93BA20B7ED0B082475C00500000000 APE_ROM_ID: 1DFD66132C872FD4 CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101003000 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B21 CMT_PUBLIC_ID: 0CE0000D73BF0054A594269B2077246C374EADC7 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_ROM_ID: 273F6D55DFAAF68F RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.30.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Exploiting - running preloader... Preloader running OK, Running Custom Loader... Custom loader running OK! Working... Received Security Block OK ! Writing Security Block... SP Accepted, doing reset to update block... MCU Version V 05wk47v34.1 MCU Date 05-10-06 Product RM-133 Manufacturer (c) Nokia. IMEI 351851018909896 Mastercode 245461510 Simlock Server SIMLOCK SERVER VERSION 63 Simlock Key 2440700000000000 Simlock Profile 8000000000000006 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock[1,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock[1,2] State: OPENED Type: GID Data: FFFF Simlock[1,3] State: OPENED Type: GID Data: FFFF Simlock[1,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock[1,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock[2,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock[2,2] State: OPENED Type: GID Data: FFFF Simlock[2,3] State: OPENED Type: GID Data: FFFF Simlock[2,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock[2,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock[3,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock[3,2] State: OPENED Type: GID Data: FFFF Simlock[3,3] State: OPENED Type: GID Data: FFFF Simlock[3,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock[3,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock[4,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock[4,2] State: OPENED Type: GID Data: FFFF Simlock[4,3] State: OPENED Type: GID Data: FFFF Simlock[4,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock[4,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock[5,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock[5,2] State: OPENED Type: GID Data: FFFF Simlock[5,3] State: OPENED Type: GID Data: FFFF Simlock[5,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock[5,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock[6,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock[6,2] State: OPENED Type: GID Data: FFFF Simlock[6,3] State: OPENED Type: GID Data: FFFF Simlock[6,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock[6,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock[7,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock[7,2] State: OPENED Type: GID Data: FFFF Simlock[7,3] State: OPENED Type: GID Data: FFFF Simlock[7,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock[7,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Unlock finished! Last edited by ptt; 01-17-2010 at 03:26. Reason: add code tag |
06-20-2009, 05:11 | #154 (permalink) |
No Life Poster Join Date: Sep 2007 Location: Gsm_World
Member: 583353 Status: Offline Thanks Meter: 259 | E71 FROM UK UNLOCKED... LOGS: Code: Nokia DCT4/WD2/BB5 Service Tool Initialization Started, Engine Revision: 1.0.0.7396 Handling device: [Cyclone Team], [Cyclone Bootloader] Handling device: [Cyclone Team], [Cyclone Box] Initializing box... Box Firmware: Cyclone Nokia Application v1.04, (May 12 2009 00:28:13, gcc-4.2.2, RTOS v5.2.0), Type: Signed Production Application, Flags: CONST-TX2-PIN ; VISTA-SUPPORT Box Serial Number: nelsky HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2008, wk27 Initializing security card... Card Serial Number: nelsky Card Firmware Revision: 0109 Card is activated Box is activated Started box selftests procedure USB Voltage 5.17v PASSED MCU Voltage 3.27v PASSED Core Voltage 1.80v PASSED VBAT Voltage 0.01v PASSED VBAT Voltage 5.06v PASSED Box VPP disabled VPP Voltage 0.02v PASSED Internal Box VPP Enabled VPP Voltage 4.92v PASSED Box VPP disabled VPP Voltage 0.02v PASSED External Box VPP Enabled VPP Voltage 0.02v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Initializing FBUS... All initialized - Ready to work MCU Version V 100.71.821.4 MCU Date 06-06-08 Product RM-346 Manufacturer (c) Nokia IMEI 352924020nelsky Mastercode 1434422333 IMEI Spare 3A25290402986201 IMEI SV 3325290402986201F1000000 PPM 100.07.76j 100.07.76100.07.76_v241.02kRM346ENO7411718214.029n256o256¥0(100.07.76, 08-06-2008, RM-346, (c)Nokia , PSN SIK066618 Product Code 0569999 Basic Product Code 0552256 PSD 0000000000000000 LPSN 0 WLAN MAC 0021FE55319D APE SW 100.07.76 APE Variant 100.07.76100.07.76_v241.02 APE Test RM346ENO7411718214.029 APE HW 256 APE ADSP 256 RETU 15 TAHVO 22 AHNE 11 HW 0910i, 100.07.76j 100.07.76100.07.76_v241.02kRM346ENO7411718214.029n256o256¥0(100.07.76, 08-06-2008, RM-346, (c)Nokia , PCI i, 100.07.76j 100.07.76100.07.76_v241.02kRM346ENO7411718214.029n256o256¥0(100.07.76, 08-06-2008, RM-346, (c)Nokia , UEM 100.07.76j 100.07.76100.07.76_v241.02kRM346ENO7411718214.029n256o256¥0(100.07.76, 08-06-2008, RM-346, (c)Nokia , UPP 100.07.76j 100.07.76100.07.76_v241.02kRM346ENO7411718214.029n256o256¥0(100.07.76, 08-06-2008, RM-346, (c)Nokia , RFIC 17141715i, 100.07.76j 100.07.76100.07.76_v241.02kRM346ENO7411718214.029n256o256 DSP L07w15PB_08w20i, 100.07.76j 100.07.76100.07.76_v241.02kRM346ENO7411718214.029n256o256 LCD 100.07.76j 100.07.76100.07.76_v241.02kRM346ENO7411718214.029n256o256 BT 100.07.76j 100.07.76100.07.76_v241.02kRM346ENO7411718214.029n256o256 ADSP Sw 100.07.76j 100.07.76100.07.76_v241.02kRM346ENO7411718214.029n256o256¥0(100.07.76, 08-06-2008, RM-346, (c)Nokia , ADSP DevID 100.07.76j 100.07.76100.07.76_v241.02kRM346ENO7411718214.029n256o256¥0(100.07.76, 08-06-2008, RM-346, (c)Nokia , ADSP RevID 100.07.76j 100.07.76100.07.76_v241.02kRM346ENO7411718214.029n256o256¥0(100.07.76, 08-06-2008, RM-346, (c)Nokia , AEM 100.07.76j 100.07.76100.07.76_v241.02kRM346ENO7411718214.029n256o256¥0(100.07.76, 08-06-2008, RM-346, (c)Nokia , Flip MCUSW 100.07.76j 100.07.76100.07.76_v241.02kRM346ENO7411718214.029n256o256 Simlock Server SIMLOCK SERVER Simlock Key 2342000000000000 Simlock Profile 8000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock[1,1] State: CLOSED Type: MCC-MNC Data: 23420F Simlock[2,1] State: CLOSED Type: MCC-MNC Data: 23595F BB5 Unlock Started... MCU Version V 100.71.821.4 MCU Date 06-06-08 Product RM-346 Manufacturer (c) Nokia IMEI 3529240208nelsky Mastercode 1434422333 Simlock Server SIMLOCK SERVER Simlock Key 2342000000000000 Simlock Profile 8000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock[1,1] State: CLOSED Type: MCC-MNC Data: 23420F Simlock[2,1] State: CLOSED Type: MCC-MNC Data: 23595F Reading Security Block... Security block OK! Determining PA Simlock... Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101031103 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 05000118199A0158172F8DA87CFC8577422D805F CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE CMT_ROM_ID: 4B9B75103E691FF8 RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.37.1, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits FlashChip[0,CMT]: 0x00EC004000800121, Samsung, ONENAND FlashContent[0,CMT]: 00000000000000000000000000000000, ONENAND FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAPIDOv11_algo.fg, Type: Algorithm, Rev: 0.1.35.0, Algo: XSR 1.5 Flashbus Write baud set to 4.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 52570A2086C79E6965175815B5388535CDD5C6F7 APE Boot skipped on user request Restarting MCU... Determined PA Simlock: PA_SL2 Checking for Rootkey Hash support... Restarting MCU... Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101031103 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 05000118199A0158172F8DA87CFC8577422D805F CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE CMT_ROM_ID: 4B9B75103E691FF8 RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.30.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Exploiting - running preloader... Preloader running OK, Running Custom Loader... Custom loader running OK! Working... Received Security Block OK ! Bypassing SX4... Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101031103 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 05000118199A0158172F8DA87CFC8577422D805F CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE CMT_ROM_ID: 4B9B75103E691FF8 RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.37.1, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits FlashChip[0,CMT]: 0x00EC004000800121, Samsung, ONENAND FlashContent[0,CMT]: 00000000000000000000000000000000, ONENAND FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAPIDOv11_algo.fg, Type: Algorithm, Rev: 0.1.35.0, Algo: XSR 1.5 Flashbus Write baud set to 4.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 52570A2086C79E6965175815B5388535CDD5C6F7 APE Boot skipped on user request CMT NPC Ok CMT NPC Erased Restarting MCU... Writing Security Block... Writing Simlock Key... SP Accepted, doing reset to update block... Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101031103 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 05000118199A0158172F8DA87CFC8577422D805F CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE CMT_ROM_ID: 4B9B75103E691FF8 RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.37.1, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits FlashChip[0,CMT]: 0x00EC004000800121, Samsung, ONENAND FlashContent[0,CMT]: 00000000000000000000000000000000, ONENAND FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAPIDOv11_algo.fg, Type: Algorithm, Rev: 0.1.35.0, Algo: XSR 1.5 Flashbus Write baud set to 4.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 52570A2086C79E6965175815B5388535CDD5C6F7 APE Boot skipped on user request Restoring NPC... Restarting MCU... SX4 Bypass Finished MCU Version V 100.71.821.4 MCU Date 06-06-08 Product RM-346 Manufacturer (c) Nokia IMEI 3529240208nelsky Mastercode 1434422333 Simlock Server SIMLOCK SERVER Simlock Key 0010100000000000 Simlock Profile 8000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock[1,1] State: OPENED Type: MCC-MNC Data: 00101F Unlock finished! Last edited by ptt; 01-17-2010 at 03:26. Reason: add code tag |
06-20-2009, 07:48 | #155 (permalink) |
Freak Poster Join Date: Jan 2004 Location: Romania Age: 56
Member: 50585 Status: Offline Thanks Meter: 63 | 6120c-1 unlock OK Code: BB5 Unlock Started... MCU Version V 03.83 MCU Date 18-06-07 Product RM-243 Manufacturer (c) Nokia IMEI 359849014391756 Mastercode 234465466 Simlock Server SIMLOCK SERVER Simlock Key 2140100000000000 Simlock Profile 8000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock[1,1] State: CLOSED Type: MCC-MNC Data: 21401F Reading Security Block... Security block OK! Determining PA Simlock... Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101021103 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 08000112BA590052CEA91DB89968FAE6EB395685 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE CMT_ROM_ID: A8C1D6713E691FF8 RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.37.1, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits FlashChip[0,CMT]: 0x00EC003000400221, Samsung, ONENAND FlashContent[0,CMT]: 00000000000000000000000000000000, ONENAND FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAPIDOv11_algo.fg, Type: Algorithm, Rev: 0.1.35.0, Algo: XSR 1.5 Flashbus Write baud set to 4.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 0FE1BA92D924A658E4800780FA6F4868100AC947 APE Boot skipped on user request Restarting MCU... Determined PA Simlock: PA_SL2 Checking for Rootkey Hash support... Restarting MCU... Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101021103 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 08000112BA590052CEA91DB89968FAE6EB395685 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE CMT_ROM_ID: A8C1D6713E691FF8 RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.30.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Exploiting - running preloader... Preloader running OK, Running Custom Loader... Custom loader running OK! Working... Received Security Block OK ! Bypassing SX4... Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101021103 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 08000112BA590052CEA91DB89968FAE6EB395685 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE CMT_ROM_ID: A8C1D6713E691FF8 RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.37.1, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits FlashChip[0,CMT]: 0x00EC003000400221, Samsung, ONENAND FlashContent[0,CMT]: 00000000000000000000000000000000, ONENAND FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAPIDOv11_algo.fg, Type: Algorithm, Rev: 0.1.35.0, Algo: XSR 1.5 Flashbus Write baud set to 4.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 0FE1BA92D924A658E4800780FA6F4868100AC947 APE Boot skipped on user request CMT NPC Ok CMT NPC Erased Restarting MCU... Writing Security Block... Writing Simlock Key... SP Accepted, doing reset to update block... Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101021103 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 08000112BA590052CEA91DB89968FAE6EB395685 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE CMT_ROM_ID: A8C1D6713E691FF8 RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.37.1, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits FlashChip[0,CMT]: 0x00EC003000400221, Samsung, ONENAND FlashContent[0,CMT]: 00000000000000000000000000000000, ONENAND FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAPIDOv11_algo.fg, Type: Algorithm, Rev: 0.1.35.0, Algo: XSR 1.5 Flashbus Write baud set to 4.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 0FE1BA92D924A658E4800780FA6F4868100AC947 APE Boot skipped on user request Restoring NPC... Restarting MCU... SX4 Bypass Finished MCU Version V 03.83 MCU Date 18-06-07 Product RM-243 Manufacturer (c) Nokia IMEI 359849014391756 Mastercode 234465466 Simlock Server SIMLOCK SERVER Simlock Key 0010100000000000 Simlock Profile 8000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock[1,1] State: OPENED Type: MCC-MNC Data: 00101F Unlock finished! Last edited by ptt; 01-17-2010 at 03:27. Reason: add code tag |
06-20-2009, 09:25 | #156 (permalink) |
No Life Poster Join Date: Jan 2006 Location: Pakistan
Member: 226457 Status: Offline Sonork: No more used Thanks Meter: 14,934 | 2630 Unlocking Successfully Code: Booting UPP... UPP ID: 3162 [HW_UNKNOWN] Flashbus Write baud set to 100Kbits u3_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.77.0, Algo: DCT4 PLL Factor: 3 FlashChip[0]: 0x0020881C @ 0x01000000, ST, SectorSize: 128kB, Ext: 00009221 Signature: AD7EB61A1BBE0BE27D586BE4DBEE6514 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 4Kbits u3_intel.fia, Type: Algorithm, Target: FlashChip[0] 0x0020881C (256Mbits), Rev: 7.4.77.0, Algo: DCT4 ALGORITHM Nominal VPP Voltage: 9V, Detected: 0.02V Terminating flash session Boot operation took 5.593s Check Flashing Bus finished MCU Version V 05.20 MCU Date 06-12-07 Product RM-298 Manufacturer (c) Nokia IMEI 3520460200----- Mastercode 2522255120 Asic 11 HW Signature F51831A946E34951 Simlock Server SIMLOCK SERVER Simlock Key 0010100000000000 Simlock Profile 800000000001000B Simlock Aux 000B5555 Simlock IMEI 00553520460200==== Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock[1,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock[1,2] State: OPENED Type: GID Data: FFFF Simlock[1,3] State: OPENED Type: GID Data: FFFF Simlock[1,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock[1,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock[2,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock[2,2] State: OPENED Type: GID Data: FFFF Simlock[2,3] State: OPENED Type: GID Data: FFFF Simlock[2,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock[2,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock[3,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock[3,2] State: OPENED Type: GID Data: FFFF Simlock[3,3] State: OPENED Type: GID Data: FFFF Simlock[3,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock[3,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock[4,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock[4,2] State: OPENED Type: GID Data: FFFF Simlock[4,3] State: OPENED Type: GID Data: FFFF Simlock[4,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock[4,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock[5,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock[5,2] State: OPENED Type: GID Data: FFFF Simlock[5,3] State: OPENED Type: GID Data: FFFF Simlock[5,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock[5,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock[6,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock[6,2] State: OPENED Type: GID Data: FFFF Simlock[6,3] State: OPENED Type: GID Data: FFFF Simlock[6,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock[6,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock[7,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock[7,2] State: OPENED Type: GID Data: FFFF Simlock[7,3] State: OPENED Type: GID Data: FFFF Simlock[7,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock[7,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Selecting unlock method... Search in: C:\Program Files\Cyclone Box\UnlockData\ Searching for: RM-298_V 05.20.unlock_img Asking card to sign HW Signature... Signed OK (6AC31DC2DD5D3EC7FBCDBE18078944AEC35D2273) Writing patch file... Booting UPP... UPP ID: 3162 [HW_UNKNOWN] shadow, Type: Flash Image, Algo: DCT4, DCT4 ALGORITHM Flashbus Write baud set to 100Kbits u3_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.77.0, Algo: DCT4 Box VPP disabled Internal Phone VPP Selected PLL Factor: 3 FlashChip[0]: 0x0020881C @ 0x01000000, ST, SectorSize: 128kB, Ext: 00009221 FlashChip[1]: 0x0020881C @ 0x02000000, ST, SectorSize: 128kB, Ext: 00009221 Signature: AD7EB61A1BBE0BE27D586BE4DBEE6514 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 51Kbits u3_intel.fia, Type: Algorithm, Target: FlashChip[0] 0x0020881C (256Mbits), Rev: 7.4.77.0, Algo: DCT4 ALGORITHM Nominal VPP Voltage: 9V, Detected: 0.04V MSID-Crypted: 84D2FD57AC162E80DFF627F7DE MSID-Plain: 2C40BAE9008B4713A8000000 FAID-Crypted: 43960A219BB8346BC91CC68A Flashbus Write baud set to 6.50Mbits 2 Region(s) to erase Erasing NOR Region [0x01000000-0x0101FFFF] Erasing NOR Region [0x01080000-0x0109FFFF] Erase taken 1.140s Writing 10 blocks... All blocks written OK! Time taken 9.688s Terminating flash session Box VPP disabled Writing SP... New SP Accepted OK! Phone unlocked OK! Last edited by ptt; 01-17-2010 at 03:27. Reason: add code tag |
06-20-2009, 11:14 | #157 (permalink) |
Member: 50585 Status: Offline Thanks Meter: 63 | E50 repair OK Simlock Key FFFFFFFFFFFFFFFF Simlock Profile FFFFFFFFFFFFFFFF Code: Backing up simlock... MCU Version V 4.41.41 MCU Date 28-06-07 Product RM-170 Manufacturer (c) Nokia. IMEI 353672018031525 Mastercode 3415615317 Simlock backup OK, saved to RM-170_353672018031525_6202009_10857 PM.SLBackup.PM BB5 Unlock Started... MCU Version V 4.41.41 MCU Date 28-06-07 Product RM-170 Manufacturer (c) Nokia. IMEI 353672018031525 Mastercode 3415615317 Simlock Server SIMLOCK SERVER VERSION 63 Simlock Key FFFFFFFFFFFFFFFF Simlock Profile FFFFFFFFFFFFFFFF Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock[1,1] State: CLOSED Type: MCC-MNC Data: 00101F Reading Security Block... Security block OK! Determining PA Simlock... Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101001101 CMT_EM_ASIC_ID: 00000232 CMT_EM_ASIC_ID: 00000353 CMT_PUBLIC_ID: 12400106EDF067505E68E0BE74DA557455579411 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_ROM_ID: 191EC665DFAAF68F RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.30.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits FlashChip[0,CMT]: 0x00EC220800008D21, Samsung, NOR FlashChip[0,CMT]: 0x00EC003000000121, Samsung, ONENAND Requested Algorithm: BB5 ALGORITHM (CMT) FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.1.40.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 4.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 378E6A71B6975E4F03868F793B3BCC7502219779 APE Boot skipped on user request Restarting MCU... Determined PA Simlock: PA_SL Checking for Rootkey Hash support... Restarting MCU... Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101001101 CMT_EM_ASIC_ID: 00000232 CMT_EM_ASIC_ID: 00000353 CMT_PUBLIC_ID: 12400106EDF067505E68E0BE74DA557455579411 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_ROM_ID: 191EC665DFAAF68F RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.30.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Exploiting - running preloader... Preloader running OK, Running Custom Loader... Custom loader running OK! Working... Received Security Block OK ! Writing Security Block... SP Accepted, doing reset to update block... MCU Version V 4.41.41 MCU Date 28-06-07 Product RM-170 Manufacturer (c) Nokia. IMEI 353672018031525 Mastercode 3415615317 Simlock Server SIMLOCK SERVER VERSION 63 Simlock Key 2440700000000000 Simlock Profile 8000000000000006 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock[1,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock[1,2] State: OPENED Type: GID Data: FFFF Simlock[1,3] State: OPENED Type: GID Data: FFFF Simlock[1,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock[1,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock[2,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock[2,2] State: OPENED Type: GID Data: FFFF Simlock[2,3] State: OPENED Type: GID Data: FFFF Simlock[2,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock[2,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock[3,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock[3,2] State: OPENED Type: GID Data: FFFF Simlock[3,3] State: OPENED Type: GID Data: FFFF Simlock[3,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock[3,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock[4,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock[4,2] State: OPENED Type: GID Data: FFFF Simlock[4,3] State: OPENED Type: GID Data: FFFF Simlock[4,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock[4,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock[5,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock[5,2] State: OPENED Type: GID Data: FFFF Simlock[5,3] State: OPENED Type: GID Data: FFFF Simlock[5,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock[5,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock[6,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock[6,2] State: OPENED Type: GID Data: FFFF Simlock[6,3] State: OPENED Type: GID Data: FFFF Simlock[6,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock[6,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock[7,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock[7,2] State: OPENED Type: GID Data: FFFF Simlock[7,3] State: OPENED Type: GID Data: FFFF Simlock[7,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock[7,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Unlock finished! Last edited by ptt; 01-17-2010 at 03:28. Reason: add code tag |
06-20-2009, 13:33 | #158 (permalink) |
Member: 917576 Status: Offline Sonork: QQ:366688456 Thanks Meter: 533 | 5300 USB Flsah 5300 (die phone) USB Flashing successfully finished! Code: Processing pre flash tasks... Pre flash tasks finished, continuing... Selecting USB Flashing Method... [BB5 ADL Server]: Found 1 active devices [Nokia BB5 ADL Loader USB Generic]: Opening Connection [Nokia BB5 ADL Loader USB Generic]: Port opened OK! Phone already spawned ADL Services ROOTKEY Hash for CMT: BAF3A9C3DBFA8454937DB77F2B8852B1 PAPUBKEYS Hash for CMT: 7C1A1F5C3DB717937F54455937AF9DA76AA2EE13 Product Code: 0542769C IMEI: 352734010968939 Processing rm146__07.00.mcusw (CMT)... rm146__07.00.mcusw, Type: Flash Image, Algo: BB5, BB5 ALGORITHM Started flash erase EraseArea[0,CMT]: 0x00000000-0x000006BF, NOR EraseArea[0,CMT]: 0x000006C0-0x0001FFFF, NOR EraseArea[0,CMT]: 0x00020000-0x0007FFFF, NOR EraseArea[0,CMT]: 0x00080000-0x000DFFFF, NOR EraseArea[0,CMT]: 0x00100000-0x001FFFFF, NOR EraseArea[0,CMT]: 0x00200000-0x0031FFFF, NOR EraseArea[0,CMT]: 0x00320000-0x0105FFFF, NOR EraseArea[0,CMT]: 0x01060000-0x01067FFF, NOR EraseArea[0,CMT]: 0x01068000-0x0107FFFF, NOR Erase taken 100.562s Writing all blocks... Writing CMT NOLO Certificate... Writing CMT KEYS Certificate... Writing CMT PRIMAPP Certificate... Writing CMT PASUBTOC Certificate... Writing CMT PAPUBKEYS Certificate... Writing CMT UPDAPP Certificate... Writing CMT DSP0 Certificate... Writing CMT MCUSW Certificate... Writing CMT PMM_CONF Certificate... Writing CMT SBIF_CONF Certificate... Programming Status OK! All blocks written OK! Time taken 118.875s Processing rm146__07.00.ppm_s (CMT)... rm146__07.00.ppm_s, Type: Flash Image, Algo: BB5, BB5 ALGORITHM Started flash erase EraseArea[0,CMT]: 0x01080000-0x015FFFFF, NOR Erase taken 37.609s Writing all blocks... Programming Status OK! All blocks written OK! Time taken 43.500s Processing rm146__07.00.image_r (CMT)... rm146__07.00.image_r, Type: Flash Image, Algo: BB5, BB5 ALGORITHM Started flash erase EraseArea[0,CMT]: 0x01600000-0x01FDFFFF, NOR Erase taken 1.219s Writing all blocks... Programming Status OK! All blocks written OK! Time taken 23.968s Restarting CMT... All images processed OK! Processing post flash tasks... Setting Factory Defaults... [BB5 NMWCD]: Found 0 active devices [BB5 NMWCD]: Not Found! [BB5 NMWCD]: Found 0 active devices [BB5 NMWCD]: Not Found! [BB5 NMWCD]: Found 0 active devices [BB5 NMWCD]: Not Found! [BB5 NMWCD]: Found 0 active devices [BB5 NMWCD]: Not Found! [BB5 NMWCD]: Found 0 active devices [BB5 NMWCD]: Not Found! Factory defaults OK Reading info... [BB5 NMWCD]: Found 0 active devices [BB5 NMWCD]: Not Found! Failed to read info -> Phone not detected Read info thread finished, continuing... Post flash tasks finished! Flashing successfully finished! Last edited by ptt; 01-17-2010 at 03:29. Reason: add code tag |
06-20-2009, 15:24 | #159 (permalink) |
Freak Poster Join Date: Jun 2009 Location: one -two - tree viva algeria
Member: 1051957 Status: Offline Thanks Meter: 25 | N95 RM-159 unlock success Code: BB5 Unlock Started.. MCU Version V 06wk41v59.1 MCU Date 02-06-08 Product RM-159 Manufacturer (c) Nokia IMEI 356843022459336 Mastercode 2370572041 Simlock Server SIMLOCK SERVER Simlock Key 2082000000000000 Simlock Profile 0000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock[1,1] State: CLOSED Type: MCC-MNC Data: 20820F Simlock[2,1] State: CLOSED Type: MCC-MNC Data: 20820F Reading Security Block... Security block OK! Determining PA Simlock... Booting RAP... APE_SYSTEM_ASIC_ID: 24200705 APE_ASIC_MODE_ID: 00 APE_PUBLIC_ID: 566FD058BDFB33DF293984D2A6D28CF3470B6718 APE_ROOT_KEY_HASH: BA8710A7E1CD5A2909B9A875DB27AA2400000000 CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101031103 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 2080001283B901585197AD2035EF266D822A33BF CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE CMT_ROM_ID: 4B9B75103E691FF8 RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.37.1, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits FlashChip[0,CMT]: 0x0001003500006921, AMD, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAPIDOv11_algo.fg, Type: Algorithm, Rev: 0.1.35.0, Algo: XSR 1.5 Flashbus Write baud set to 4.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 25129A39D9A3B031CA0124E1E90F5A17ED3EFC89 APE Boot skipped on user request Restarting MCU... Determined PA Simlock: PA_SL Checking for Rootkey Hash support... Restarting MCU... Booting RAP... APE_SYSTEM_ASIC_ID: 24200705 APE_ASIC_MODE_ID: 00 APE_PUBLIC_ID: 566FD058BDFB33DF293984D2A6D28CF3470B6718 APE_ROOT_KEY_HASH: BA8710A7E1CD5A2909B9A875DB27AA2400000000 CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101031103 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 2080001283B901585197AD2035EF266D822A33BF CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE CMT_ROM_ID: 4B9B75103E691FF8 RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.30.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Exploiting - running preloader... Preloader running OK, Running Custom Loader... Custom loader running OK! Working... Received Security Block OK ! Writing Security Block... SP Accepted, doing reset to update block... MCU Version V 06wk41v59.1 MCU Date 02-06-08 Product RM-159 Manufacturer (c) Nokia IMEI 356843022459336 Mastercode 2370572041 Simlock Server SIMLOCK SERVER Simlock Key 2440700000000000 Simlock Profile 8000000000000006 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock[1,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock[1,2] State: OPENED Type: GID Data: FFFF Simlock[1,3] State: OPENED Type: GID Data: FFFF Simlock[1,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock[1,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock[2,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock[2,2] State: OPENED Type: GID Data: FFFF Simlock[2,3] State: OPENED Type: GID Data: FFFF Simlock[2,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock[2,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock[3,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock[3,2] State: OPENED Type: GID Data: FFFF Simlock[3,3] State: OPENED Type: GID Data: FFFF Simlock[3,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock[3,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock[4,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock[4,2] State: OPENED Type: GID Data: FFFF Simlock[4,3] State: OPENED Type: GID Data: FFFF Simlock[4,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock[4,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock[5,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock[5,2] State: OPENED Type: GID Data: FFFF Simlock[5,3] State: OPENED Type: GID Data: FFFF Simlock[5,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock[5,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock[6,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock[6,2] State: OPENED Type: GID Data: FFFF Simlock[6,3] State: OPENED Type: GID Data: FFFF Simlock[6,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock[6,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock[7,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock[7,2] State: OPENED Type: GID Data: FFFF Simlock[7,3] State: OPENED Type: GID Data: FFFF Simlock[7,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock[7,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Unlock finished! Last edited by ptt; 01-17-2010 at 03:30. Reason: add code tag |
06-20-2009, 15:56 | #160 (permalink) |
Junior Member Join Date: Jan 2008
Member: 693406 Status: Offline Thanks Meter: 0 | NOKIA 5700 Code: Nokia DCT4/WD2/BB5 Service Tool Initialization Started, Engine Revision: 1.0.0.7396 Handling device: [Cyclone Team], [Cyclone Bootloader] Handling device: [Cyclone Team], [Cyclone Box] Initializing box... Box Firmware: Cyclone Nokia Application v1.04, (May 12 2009 00:28:13, gcc-4.2.2, RTOS v5.2.0), Type: Signed Production Application, Flags: CONST-TX2-PIN ; VISTA-SUPPORT Box Serial Number: C00005BD HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2008, wk27 Initializing security card... Card Serial Number: D00001A6 Card Firmware Revision: 0109 Card is activated Box is activated Started box selftests procedure USB Voltage 4,94v PASSED MCU Voltage 3,28v PASSED Core Voltage 1,81v PASSED VBAT Voltage 0,01v PASSED VBAT Voltage 4,81v PASSED Box VPP disabled VPP Voltage 0,02v PASSED Internal Box VPP Enabled VPP Voltage 4,70v PASSED Box VPP disabled VPP Voltage 0,02v PASSED External Box VPP Enabled VPP Voltage 0,04v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Initializing FBUS... All initialized - Ready to work MCU Version V 03.83.1 MCU Date 25-06-07 Product RM-302 Manufacturer (c) Nokia IMEI 353966014055466 Mastercode 2742757262 IMEI Spare 3A35690641504506 IMEI SV 3335690641504516F1000000 PPM 03.83.1j(#rofs_version_inforofx_version_infok rm302_ENO_x_2007wk24v0.010n256o256 PSN CLE373739 Product Code 0554875 Basic Product Code 0544062 PSD 0000000000000000 LPSN 0 APE SW 03.83.1 APE Variant rofs_version_inforofx_version_info APE Test rm302_ENO_x_2007wk24v0.010 APE HW 256 APE ADSP 256 RETU 15 TAHVO 22 AHNE 11 HW 0206i03.83.1j(#rofs_version_inforofx_version_infok rm302_ENO_x_2007wk24v0.010n256o256 PCI i03.83.1j(#rofs_version_inforofx_version_infok rm302_ENO_x_2007wk24v0.010n256o256 UEM 03.83.1j(#rofs_version_inforofx_version_infok rm302_ENO_x_2007wk24v0.010n256o256 UPP 03.83.1j(#rofs_version_inforofx_version_infok rm302_ENO_x_2007wk24v0.010n256o256 RFIC 17141715 DSP pb06w41v34.3_rm230 LCD 03.83.1j(#rofs_version_inforofx_version_infok rm302_ENO_x_2007wk24v0.010n256o256 BT 03.83.1j(#rofs_version_inforofx_version_infok rm302_ENO_x_2007wk24v0.010n256o256 ADSP Sw 03.83.1j(#rofs_version_inforofx_version_infok rm302_ENO_x_2007wk24v0.010n256o256 ADSP DevID 03.83.1j(#rofs_version_inforofx_version_infok rm302_ENO_x_2007wk24v0.010n256o256 ADSP RevID 03.83.1j(#rofs_version_inforofx_version_infok rm302_ENO_x_2007wk24v0.010n256o256 AEM 03.83.1j(#rofs_version_inforofx_version_infok rm302_ENO_x_2007wk24v0.010n256o256 Flip MCUSW 03.83.1j(#rofs_version_inforofx_version_infok rm302_ENO_x_2007wk24v0.010n256o256 Simlock Server SIMLOCK SERVER Simlock Key 7321030000000000 Simlock Profile 8000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock[1,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 732103 Simlock[2,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 732111 Booting RAP... Failed to Read All Certificates -> Failed to Boot / Prepare Phone Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101021105 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 1C30011671720058F298A6D139F1B689DA14E84B CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: F2D76DFAFD66C7F195F278417DF05888 CMT_ROM_ID: A8C1D6713E691FF8 RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.37.1, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits FlashChip[0,CMT]: 0x00EC003000400121, Samsung, ONENAND FlashContent[0,CMT]: 00000000000000000000000000000000, ONENAND FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAPIDOv11_algo.fg, Type: Algorithm, Rev: 0.1.35.0, Algo: XSR 1.5 Flashbus Write baud set to 4.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 3D66090E94F3701646DA91CCD35BBAC22E5CBF73 APE Subsystem Not Found Failed to Read All Certificates -> Failed to read CMT NPC Booting RAP... Failed to Read All Certificates -> Failed to Boot / Prepare Phone Booting RAP... Failed to Read All Certificates -> Failed to Boot / Prepare Phone Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101021105 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 1C30011671720058F298A6D139F1B689DA14E84B CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: F2D76DFAFD66C7F195F278417DF05888 CMT_ROM_ID: A8C1D6713E691FF8 RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.37.1, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits FlashChip[0,CMT]: 0x00EC003000400121, Samsung, ONENAND FlashContent[0,CMT]: 00000000000000000000000000000000, ONENAND FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAPIDOv11_algo.fg, Type: Algorithm, Rev: 0.1.35.0, Algo: XSR 1.5 Flashbus Write baud set to 4.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 3D66090E94F3701646DA91CCD35BBAC22E5CBF73 APE Subsystem Not Found CMT NPC Ok CMT HWC Ok CMT CCC Ok CMT R&D Ok CMT VARIANT Not Found CMT PAPUBKEYS Ok CMT KEYS Ok Restarting MCU... Read all certificates finished RPL Creation started... Processing CMT Part... Storing Product Code... Storing PSN... Storing HWID... Simlock Store not supported, not a PA_SL2 Phone WMDRM Store not supported Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101021105 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 1C30011671720058F298A6D139F1B689DA14E84B CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: F2D76DFAFD66C7F195F278417DF05888 CMT_ROM_ID: A8C1D6713E691FF8 RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.37.1, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits FlashChip[0,CMT]: 0x00EC003000400121, Samsung, ONENAND FlashContent[0,CMT]: 00000000000000000000000000000000, ONENAND FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAPIDOv11_algo.fg, Type: Algorithm, Rev: 0.1.35.0, Algo: XSR 1.5 Flashbus Write baud set to 4.0Mbits Failed to Create RPL from phone -> Failed to Boot / Prepare Phone RPL Creation started... Processing CMT Part... Failed to Create RPL from phone -> Phone not detected RPL Creation started... Processing CMT Part... Failed to Create RPL from phone -> Phone not detected MCU Version V 03.83.1 MCU Date 25-06-07 Product RM-302 Manufacturer (c) Nokia IMEI 353966014055466 Mastercode 2742757262 IMEI Spare 3A35690641504506 IMEI SV 3335690641504516F1000000 PSN CLE373739 Product Code 0554875 Basic Product Code 0544062 PSD 0000000000000000 LPSN 0 APE Test rm302_ENO_x_2007wk24v0.010 APE HW 256 APE ADSP 256 RETU 15 TAHVO 22 AHNE 11 HW 0206i03.83.1j(#rofs_version_inforofx_version_infok rm302_ENO_x_2007wk24v0.010n256o256 PCI i03.83.1j(#rofs_version_inforofx_version_infok rm302_ENO_x_2007wk24v0.010n256o256 UEM 03.83.1j(#rofs_version_inforofx_version_infok rm302_ENO_x_2007wk24v0.010n256o256 UPP 03.83.1j(#rofs_version_inforofx_version_infok rm302_ENO_x_2007wk24v0.010n256o256 RFIC 17141715 DSP pb06w41v34.3_rm230 LCD 03.83.1j(#rofs_version_inforofx_version_infok rm302_ENO_x_2007wk24v0.010n256o256 BT 03.83.1j(#rofs_version_inforofx_version_infok rm302_ENO_x_2007wk24v0.010n256o256 ADSP Sw 03.83.1j(#rofs_version_inforofx_version_infok rm302_ENO_x_2007wk24v0.010n256o256 ADSP DevID 03.83.1j(#rofs_version_inforofx_version_infok rm302_ENO_x_2007wk24v0.010n256o256 ADSP RevID 03.83.1j(#rofs_version_inforofx_version_infok rm302_ENO_x_2007wk24v0.010n256o256 AEM 03.83.1j(#rofs_version_inforofx_version_infok rm302_ENO_x_2007wk24v0.010n256o256 Flip MCUSW 03.83.1j(#rofs_version_inforofx_version_infok rm302_ENO_x_2007wk24v0.010n256o256 Simlock Server SIMLOCK SERVER Simlock Key 7321030000000000 Simlock Profile 8000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock[1,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 732103 Simlock[2,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 732111 RPL Creation started... Processing CMT Part... Storing Product Code... Storing PSN... Storing HWID... Simlock Store not supported, not a PA_SL2 Phone WMDRM Store not supported Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101021105 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 1C30011671720058F298A6D139F1B689DA14E84B CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: F2D76DFAFD66C7F195F278417DF05888 CMT_ROM_ID: A8C1D6713E691FF8 RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.37.1, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits FlashChip[0,CMT]: 0x00EC003000400121, Samsung, ONENAND FlashContent[0,CMT]: 00000000000000000000000000000000, ONENAND FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAPIDOv11_algo.fg, Type: Algorithm, Rev: 0.1.35.0, Algo: XSR 1.5 Flashbus Write baud set to 4.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 3D66090E94F3701646DA91CCD35BBAC22E5CBF73 APE Subsystem Not Found Storing NPC... Storing CCC... Storing HWC... CMT VARIANT Not Found Restarting MCU... RPL Saved OK BB5 Unlock Started... MCU Version V 03.83.1 MCU Date 25-06-07 Product RM-302 Manufacturer (c) Nokia IMEI 353966014055466 Mastercode 2742757262 Simlock Server SIMLOCK SERVER Simlock Key 7321030000000000 Simlock Profile 8000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock[1,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 732103 Simlock[2,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 732111 Reading Security Block... Security block OK! Determining PA Simlock... Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101021105 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 1C30011671720058F298A6D139F1B689DA14E84B CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: F2D76DFAFD66C7F195F278417DF05888 CMT_ROM_ID: A8C1D6713E691FF8 RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.37.1, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits FlashChip[0,CMT]: 0x00EC003000400121, Samsung, ONENAND FlashContent[0,CMT]: 00000000000000000000000000000000, ONENAND FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAPIDOv11_algo.fg, Type: Algorithm, Rev: 0.1.35.0, Algo: XSR 1.5 Flashbus Write baud set to 4.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 3D66090E94F3701646DA91CCD35BBAC22E5CBF73 APE Boot skipped on user request Restarting MCU... Determined PA Simlock: PA_SL Checking for Rootkey Hash support... Restarting MCU... Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101021105 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 1C30011671720058F298A6D139F1B689DA14E84B CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: F2D76DFAFD66C7F195F278417DF05888 CMT_ROM_ID: A8C1D6713E691FF8 RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.30.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Exploiting - running preloader... Preloader running OK, Running Custom Loader... Custom loader running OK! Working... Received Security Block OK ! Writing Security Block... SP Accepted, doing reset to update block... MCU Version V 03.83.1 MCU Date 25-06-07 Product RM-302 Manufacturer (c) Nokia IMEI 353966014055466 Mastercode 2742757262 Simlock Server SIMLOCK SERVER Simlock Key 2440700000000000 Simlock Profile 8000000000000006 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock[1,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock[1,2] State: OPENED Type: GID Data: FFFF Simlock[1,3] State: OPENED Type: GID Data: FFFF Simlock[1,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock[1,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock[2,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock[2,2] State: OPENED Type: GID Data: FFFF Simlock[2,3] State: OPENED Type: GID Data: FFFF Simlock[2,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock[2,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock[3,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock[3,2] State: OPENED Type: GID Data: FFFF Simlock[3,3] State: OPENED Type: GID Data: FFFF Simlock[3,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock[3,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock[4,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock[4,2] State: OPENED Type: GID Data: FFFF Simlock[4,3] State: OPENED Type: GID Data: FFFF Simlock[4,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock[4,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock[5,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock[5,2] State: OPENED Type: GID Data: FFFF Simlock[5,3] State: OPENED Type: GID Data: FFFF Simlock[5,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock[5,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock[6,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock[6,2] State: OPENED Type: GID Data: FFFF Simlock[6,3] State: OPENED Type: GID Data: FFFF Simlock[6,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock[6,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock[7,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock[7,2] State: OPENED Type: GID Data: FFFF Simlock[7,3] State: OPENED Type: GID Data: FFFF Simlock[7,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock[7,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Unlock finished! Last edited by ptt; 01-17-2010 at 03:32. Reason: add code tag |
06-20-2009, 18:59 | #162 (permalink) |
Member: 1051957 Status: Offline Thanks Meter: 25 | other 5200 locked orange france Code: MCU Version V 05.51 MCU Date 05-09-07 Product RM-174 Manufacturer (c) Nokia. IMEI 354565010210072 Mastercode 655324054 IMEI Spare 3A45650501120007 IMEI SV 3345650501120017F3000000 PPM V 05.51, 05-09-07, RM-174, (c) Nokia. , C CNT Content: ora_fr, V 05.51, 05-09-07, RM-174, (c) Nokia. , , PSN DAG417129 Product Code 0542762 Module Code 0203053 Basic Product Code 0530542 PSD 0000000000000000 RETU 32 TAHVO 53 AHNE 11 HW 2001 RFIC 17211721 DSP 06w14pb_07w32 BT 06cc-P9.1 Simlock Server SIMLOCK SERVER VERSION 63 Simlock Key 2080100000000000 Simlock Profile 8000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock[1,1] State: CLOSED Type: MCC-MNC Data: 20801F and unlock processe BB5 Unlock Started... MCU Version V 05.51 MCU Date 05-09-07 Product RM-174 Manufacturer (c) Nokia. IMEI 354565010210072 Mastercode 655324054 Simlock Server SIMLOCK SERVER VERSION 63 Simlock Key 2080100000000000 Simlock Profile 8000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock[1,1] State: CLOSED Type: MCC-MNC Data: 20801F Reading Security Block... Security block OK! Determining PA Simlock... Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101001101 CMT_EM_ASIC_ID: 00000232 CMT_EM_ASIC_ID: 00000353 CMT_PUBLIC_ID: 0A700009BC4300581586DA9A9FB41C272ACA7269 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_ROM_ID: 191EC665DFAAF68F RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.30.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits FlashChip[0,CMT]: 0x00EC22FE00006921, Samsung, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.1.40.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 4.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: D6D07E588DC4E06DEE7012A3C0ECC4E35D3CE263 APE Boot skipped on user request Restarting MCU... Determined PA Simlock: PA_SL Checking for Rootkey Hash support... Restarting MCU... Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101001101 CMT_EM_ASIC_ID: 00000232 CMT_EM_ASIC_ID: 00000353 CMT_PUBLIC_ID: 0A700009BC4300581586DA9A9FB41C272ACA7269 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_ROM_ID: 191EC665DFAAF68F RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.30.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Exploiting - running preloader... Preloader running OK, Running Custom Loader... Custom loader running OK! Working... Received Security Block OK ! Writing Security Block... SP Accepted, doing reset to update block... MCU Version V 05.51 MCU Date 05-09-07 Product RM-174 Manufacturer (c) Nokia. IMEI 354565010210072 Mastercode 655324054 Simlock Server SIMLOCK SERVER VERSION 63 Simlock Key 2440700000000000 Simlock Profile 8000000000000006 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock[1,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock[1,2] State: OPENED Type: GID Data: FFFF Simlock[1,3] State: OPENED Type: GID Data: FFFF Simlock[1,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock[1,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock[2,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock[2,2] State: OPENED Type: GID Data: FFFF Simlock[2,3] State: OPENED Type: GID Data: FFFF Simlock[2,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock[2,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock[3,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock[3,2] State: OPENED Type: GID Data: FFFF Simlock[3,3] State: OPENED Type: GID Data: FFFF Simlock[3,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock[3,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock[4,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock[4,2] State: OPENED Type: GID Data: FFFF Simlock[4,3] State: OPENED Type: GID Data: FFFF Simlock[4,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock[4,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock[5,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock[5,2] State: OPENED Type: GID Data: FFFF Simlock[5,3] State: OPENED Type: GID Data: FFFF Simlock[5,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock[5,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock[6,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock[6,2] State: OPENED Type: GID Data: FFFF Simlock[6,3] State: OPENED Type: GID Data: FFFF Simlock[6,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock[6,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock[7,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock[7,2] State: OPENED Type: GID Data: FFFF Simlock[7,3] State: OPENED Type: GID Data: FFFF Simlock[7,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock[7,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Unlock finished! Last edited by ptt; 01-17-2010 at 03:32. Reason: add code tag |
06-20-2009, 19:41 | #163 (permalink) |
Member: 1051957 Status: Offline Thanks Meter: 25 | other 2610 orange locked Code: MCU Version V 06.73 MCU Date 08-05-08 Product RH-86 Manufacturer (c) Nokia. IMEI 356863020536067 Mastercode 3236551254 IMEI Spare 3A65680302350606 IMEI SV 3365680302350656F8000000 PPM V 06.73, 08-05-08, RH-86_87, (c) Nokia. , AE CNT Content: ora_fr_v2, V 06.73, 08-05-08, RH-86_87, (c) Nokia. , PSN FB3842758 Product Code 0553516 Module Code 0202930 Basic Product Code 0530409 PSD 0000000D00000000 HW 8002 UEM 1328 UPP 12352 RFIC 0500 DSP P05w45.v49 LCD ELBE Asic 11 HW Signature 85879F295C635E6E Simlock Server SIMLOCK SERVER VERSION 63 Simlock Key 2080100000000000 Simlock Profile 800000000001000B Simlock Aux 000B5555 Simlock IMEI 00553568630205360600 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock[1,1] State: CLOSED Type: MCC-MNC Data: 20801F unlock process MCU Version V 06.73 MCU Date 08-05-08 Product RH-86 Manufacturer (c) Nokia. IMEI 356863020536067 Mastercode 3236551254 Asic 11 HW Signature 85879F295C635E6E Simlock Server SIMLOCK SERVER VERSION 63 Simlock Key 2080100000000000 Simlock Profile 800000000001000B Simlock Aux 000B5555 Simlock IMEI 00553568630205360600 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock[1,1] State: CLOSED Type: MCC-MNC Data: 20801F Selecting unlock method... Search in: C:\Program Files\Cyclone Box\UnlockData\ Searching for: RH-86_V 06.73.unlock_img Asking card to sign HW Signature... Signed OK (FC7B1E57F0CFA0558DF5F5EF1857622DCC049B67) Writing patch file... Booting UPP... UPP ID: 3040 [HW_UNKNOWN] shadow, Type: Flash Image, Algo: DCT4, DCT4 ALGORITHM Flashbus Write baud set to 100Kbits u3_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.77.0, Algo: DCT4 Box VPP disabled Internal Phone VPP Selected PLL Factor: 3 FlashChip[0]: 0x00012C7E @ 0x01000000, AMD, SectorSize: 128kB, Ext: 00357021 Signature: AD7EB61A1BBE0BE27D586BE4DBEE6514 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 51Kbits u3_amd.fia, Type: Algorithm, Target: FlashChip[0] 0x00012C7E (128Mbits), Rev: 7.4.77.0, Algo: DCT4 ALGORITHM Nominal VPP Voltage: 9V, Detected: 0,00V MSID-Crypted: 843914E510862FB0A2AC658F26 MSID-Plain: 8F3CBAE90005A35FA9000000 FAID-Crypted: A23BBA2861A7F93D3B12AC64 Flashbus Write baud set to 6.50Mbits 1 Region(s) to erase Erasing NOR Region [0x010A0000-0x010BFFFF] Erase taken 0.750s Writing 8 blocks... All blocks written OK! Time taken 1.859s Terminating flash session Box VPP disabled Writing SP... New SP Accepted OK! Writing restore file... Booting UPP... UPP ID: 3040 [HW_UNKNOWN] shadow, Type: Flash Image, Algo: DCT4, DCT4 ALGORITHM Flashbus Write baud set to 100Kbits u3_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.77.0, Algo: DCT4 Box VPP disabled Internal Phone VPP Selected PLL Factor: 3 FlashChip[0]: 0x00012C7E @ 0x01000000, AMD, SectorSize: 128kB, Ext: 00357021 Signature: AD7EB61A1BBE0BE27D586BE4DBEE6514 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 51Kbits u3_amd.fia, Type: Algorithm, Target: FlashChip[0] 0x00012C7E (128Mbits), Rev: 7.4.77.0, Algo: DCT4 ALGORITHM Nominal VPP Voltage: 9V, Detected: 0,04V MSID-Crypted: 843914E510862FB0A2AC658F26 Using MSID-FAID Cache, Not wasting card FAID-Crypted: A23BBA2861A7F93D3B12AC64 Flashbus Write baud set to 6.50Mbits 1 Region(s) to erase Erasing NOR Region [0x010A0000-0x010BFFFF] Erase taken 0.765s Writing 8 blocks... All blocks written OK! Time taken 1.859s Terminating flash session Box VPP disabled Phone unlocked OK! Last edited by ptt; 01-17-2010 at 03:33. Reason: add code tag |
06-21-2009, 17:56 | #164 (permalink) |
Member: 1051957 Status: Offline Thanks Meter: 25 | other E65 sfr france locked .... Code: MCU Version V 2.0615.30 MCU Date 13-09-07 Product RM-208 Manufacturer (c) Nokia. IMEI 356961018594898 Mastercode 1523655762 IMEI Spare 3A65690181958409 IMEI SV 3365690181958429F5000000 PSN SCN570348 Product Code 0561957 Basic Product Code 0560030 PSD 0000000000000000 WLAN MAC 001EA4ABF6BB RETU 15 TAHVO 22 AHNE 30 HW 0810 RFIC 17141715 DSP A06w14PB_07w32 Simlock Server SIMLOCK SERVER VERSION 63 Simlock Key 2081000000000000 Simlock Profile 0100000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock[1,1] State: CLOSED Type: MCC-MNC Data: 20810F Simlock[2,1] State: CLOSED Type: MCC-MNC Data: 20810F Simlock[3,1] State: CLOSED Type: MCC-MNC Data: 64710F Simlock[4,1] State: CLOSED Type: MCC-MNC Data: 64710F unlock process BB5 Unlock Started... MCU Version V 2.0615.30 MCU Date 13-09-07 Product RM-208 Manufacturer (c) Nokia. IMEI 356961018594898 Mastercode 1523655762 Simlock Server SIMLOCK SERVER VERSION 63 Simlock Key 2081000000000000 Simlock Profile 0100000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock[1,1] State: CLOSED Type: MCC-MNC Data: 20810F Simlock[2,1] State: CLOSED Type: MCC-MNC Data: 20810F Simlock[3,1] State: CLOSED Type: MCC-MNC Data: 64710F Simlock[4,1] State: CLOSED Type: MCC-MNC Data: 64710F Reading Security Block... Security block OK! Determining PA Simlock... Booting RAP... APE_SYSTEM_ASIC_ID: 17100708 APE_ASIC_MODE_ID: 00 APE_PUBLIC_ID: 959D042720BDAC1A3C3A56C9FD117DA079165A6D APE_ROOT_KEY_HASH: 49A97E826B93BA20B7ED0B082475C00500000000 APE_ROM_ID: 1DFD66132C872FD4 CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101003000 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 1A800115557502544DF500ED4FEFF1C54232F4E1 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_ROM_ID: 273F6D55DFAAF68F RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.30.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits FlashChip[0,CMT]: 0x00EC22E800006921, Samsung, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.1.40.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 4.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 0266638E9C2164FC6B5194ED596A6A251C699896 APE Boot skipped on user request Restarting MCU... Determined PA Simlock: PA_SL Checking for Rootkey Hash support... Restarting MCU... Booting RAP... APE_SYSTEM_ASIC_ID: 17100708 APE_ASIC_MODE_ID: 00 APE_PUBLIC_ID: 959D042720BDAC1A3C3A56C9FD117DA079165A6D APE_ROOT_KEY_HASH: 49A97E826B93BA20B7ED0B082475C00500000000 APE_ROM_ID: 1DFD66132C872FD4 CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101003000 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 1A800115557502544DF500ED4FEFF1C54232F4E1 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_ROM_ID: 273F6D55DFAAF68F RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.30.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Exploiting - running preloader... Preloader running OK, Running Custom Loader... Custom loader running OK! Working... Received Security Block OK ! Writing Security Block... SP Accepted, doing reset to update block... MCU Version V 2.0615.30 MCU Date 13-09-07 Product RM-208 Manufacturer (c) Nokia. IMEI 356961018594898 Mastercode 1523655762 Simlock Server SIMLOCK SERVER VERSION 63 Simlock Key 2440700000000000 Simlock Profile 8000000000000006 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock[1,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock[1,2] State: OPENED Type: GID Data: FFFF Simlock[1,3] State: OPENED Type: GID Data: FFFF Simlock[1,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock[1,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock[2,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock[2,2] State: OPENED Type: GID Data: FFFF Simlock[2,3] State: OPENED Type: GID Data: FFFF Simlock[2,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock[2,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock[3,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock[3,2] State: OPENED Type: GID Data: FFFF Simlock[3,3] State: OPENED Type: GID Data: FFFF Simlock[3,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock[3,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock[4,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock[4,2] State: OPENED Type: GID Data: FFFF Simlock[4,3] State: OPENED Type: GID Data: FFFF Simlock[4,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock[4,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock[5,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock[5,2] State: OPENED Type: GID Data: FFFF Simlock[5,3] State: OPENED Type: GID Data: FFFF Simlock[5,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock[5,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock[6,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock[6,2] State: OPENED Type: GID Data: FFFF Simlock[6,3] State: OPENED Type: GID Data: FFFF Simlock[6,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock[6,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock[7,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock[7,2] State: OPENED Type: GID Data: FFFF Simlock[7,3] State: OPENED Type: GID Data: FFFF Simlock[7,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock[7,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Unlock finished! Last edited by ptt; 01-17-2010 at 03:33. Reason: add code tag |
POST HERE all Successfull Report with Micro-Box, HTC cable, etc.. | hitibiti | Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) | 2837 | 07-05-2020 10:10 |
Put in this thread all successfull story of Dct4 Imei???? with Mxkey | mobilecitycbk | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 06-17-2009 21:28 |
Put in this thread all successfull UNLOCK AND NOT with Cyclone-box | FullFLASHgSMPH | Cyclonebox | 2 | 04-13-2009 14:00 |
