Old 02-04-2010, 09:05   #1 (permalink)
rickliew's Avatar
Member: 522783
Thanks Meter: 62
6120 after repair sd security test failed problem solved...
reset npc
write this pm
restore imei
done!
it works for me
http://www.mediafire.com/?weny3twyzmi
The Following User Says Thank You to rickliew For This Useful Post:
Old 02-04-2010, 09:16   #2 (permalink)
Mang mel's Avatar
Member: 218941
Thanks Meter: 1,801
SX4-AUTH passed? clap your hands!
Old 02-04-2010, 09:19   #3 (permalink)
Member: 241705
Thanks Meter: 4,294,967,295
brother ur problem solved or no
if u sloved ur problem give US some coments
Br Ahmad
Old 02-04-2010, 09:24   #4 (permalink)
rickliew's Avatar
Member: 522783
Thanks Meter: 62
if you never try dont talk rubbish!
dare u try?
Old 02-04-2010, 09:27   #5 (permalink)
romeoluv56's Avatar
Member: 1170910
Thanks Meter: 76
Post a log brother for a proof
Old 02-04-2010, 09:47   #6 (permalink)
rickliew's Avatar
Member: 522783
Thanks Meter: 62
i have no log record,
just wanna share with you all.
try any different way u have nothing to lose,
your phone will not die...
Old 02-04-2010, 10:29   #7 (permalink)
Crazy Poster
Member: 1006476
Thanks Meter: 23
sorry bro its not work 4 me...
Old 02-04-2010, 10:42   #8 (permalink)
Member: 1217358
Sonork: 100.1605541
Thanks Meter: 156
my 3110c .........sorry bro its not work 4 me..
Old 02-04-2010, 10:50   #9 (permalink)
ashraf_bcs's Avatar
Member: 303373
Sonork: 100.1584377
Thanks Meter: 1,241
Without log itz not trustable.I think there is falt in sd keys.It needs to fixed bug.After sd repair if security test faild than phone not will be in normal mode.Shows all time contact service.without compliote solution this update is totaly useless.
The Following User Says Thank You to ashraf_bcs For This Useful Post:
Old 02-04-2010, 10:55   #10 (permalink)
Member: 1217358
Sonork: 100.1605541
Thanks Meter: 156
my 3110c after repair sd security test failed plz help
Old 02-12-2010, 15:51   #11 (permalink)
Member: 60039
Thanks Meter: 14
Phone Type: RM-243 (Nokia 6120)
SW Version: V 07.10 15-07-09 RM-243 (c) Nokia
Imei plain: 35697201050665-7
Product Code: 0548276
ApeCoreSw: 07.10
ApeVariant: rofs_version_inforofx_version_info
ApeTest: rm243_ENO_A_2009wk15v0.100
Language Pack:
- not available.
SIMLOCK seems to be valid
SECURITY_TEST passed
Imei net: 356972010506657
Version: SIMLOCK SERVER
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
yesssssssssssss
Old 04-08-2010, 09:25   #12 (permalink)
sagar_lse's Avatar
Member: 777523
Sonork: 100.1584558
Thanks Meter: 335
reset npc
write this pm
restore imei
done!
it works for me
Free File Hosting Made Simple - MediaFire
Invalid or Deleted File
The key you provided for file download was invalid. This is usually caused because the file is no longer stored on Mediafire. This occurs when the file is removed by the originating user or Mediafire. If you believe you have reached this page in error, please contact support.
Click here to view our help resources
Successfully Repaired 3110c Security Test failed after SD Repair romeoluv56 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 14 05-14-2012 12:37
security test failed problem solved nijascm MXKEY Nokia Flasher and Unlocker (by Alim Hape) 0 03-27-2010 11:12
After Repair SD SECURITY TEST failed 10000000% ok rahman MXKEY Nokia Flasher and Unlocker (by Alim Hape) 1 02-07-2010 21:03
n72 help after repair sd security test failed problem akt007 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 1 02-04-2010 10:20
plz help E66 after repair SD SECURITY FAIL AswanX Nokia Base Band 5 ( BB-5 ) 7 01-21-2010 09:04
Page generated in 0.24846 seconds with 9 queries
