05-27-2010, 11:07 | #1 (permalink) |
No Life Poster Join Date: Mar 2001 Location: ALBANIA(Tirana) Age: 51
Member: 3617 Status: Offline Thanks Meter: 579 | Noki 6680 sturt up failed contact retailer Library version: 1.0.0.8336(03-05-2010), 1.0.0.12955(03-05-2010) APE Data : SYSTEM ASIC ID: 17100701 [OMAP1710 ver: 1.1] ASIC MODE ID: 00 PUBLIC ID: 0E6DADBFFFBE11967CF91E5C8042E93C78009F49 ROOT KEY HASH: 2C05369F57CC3C4CF9E783E83D9B512B00000000 ROM ID: AB5E4ADB27A06946 RAP Data : SYSTEM ASIC ID: 000000010000022600010006000C192101002100 [RAP3G ver: PA 2.0] EM0 ID: 00000232 EM1 ID: 00000341 PUBLIC ID: 08200014C4A94F57C1978521B28E325EAD43F131 ASIC MODE ID: 00 ROOT KEY HASH: E9EFF4BFAA5393217CA6B17755FC3E14 ROM ID: F28A211FAC901AEE SecondaryBoot: rap3gv2_2nd.fg [BB5] version: 1.21.0 revision: 0.0 size: 0x3D00 Supported RAP Ids: 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200 FlashID0: 00EC 22FA - 0000 0011 [Samsung K8S6415ETA,64 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: 0F72BF9DE5D6711B3B1133EBCAB5914FA419C78D SecondaryBoot: helen3_2nd.fg [BB5] version: 1.35.0 revision: 0.0 size: 0x3500 Supported APE Ids: 17100700, 17100701, 17100702, 17100703, 17100704, 17100708 FlashID0: 00EC 0035 - 00A5 00BD [Samsung K5E5657ACK,256 Mbits] type: NAND,APE ExtBUSC: 0002 0000 0006 0000 0000 0000 0000 0000 Algorithm: h3_sam_nand_gbbm.fg [OMAP1610 GBBM-1.8.1 ALG] version: 1.33.0 revision: 0.0 size: 0xA908 Supported APE Ids: 17100700, 17100701, 17100702, 17100703, 17100704, 17100708 APE PAPUBKEYS HASH: 0F72BF9DE5D6711B3B1133EBCAB5914FA419C78D Original Imei: 35566100858596 Original Product code: 0526044 Bluetooth ID: 001262ABA2BB Phone Type: RM-36 (Nokia 6680) SW Version: V 04wk47_m_v14.2.1 09-11-06 RM-36 (c) Noki Imei plain: 35566100858596-0 Product Code: 0521889 Language Pack: - not available. SIMLOCK invalid! SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST failed! SECURITY_TEST passed Imei net: 355661008585960 Version: SIMLOCK SERVER VERSION 56 - Increased PMM size. Fix task Counter: 0/3, 0/10 CONFIG_DATA: FFFFFFFFFFFFFFFF PROFILE_BITS: FFFFFFFFFFFFFFFF BLOCK 1: 1=CORRUPTED OK Completed in 1 min 14.641 s How to repair |
05-27-2010, 11:23 | #3 (permalink) |
Member: 3617 Status: Offline Thanks Meter: 579 | SIMLOCK_DATA corrupted! SIMLOCK_DATA corrupted! Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8336(03-05-2010), 1.0.0.12955(03-05-2010) Product: V 04wk47_m_v14.2.1 09-11-06 RM-36 (c) Noki Using cached productData[08200014C4A94F57C1978521B28E325EAD43F131] ... Calculating SIMLOCK using security server ... Reading Simlock info ... SIMLOCK_DATA corrupted! SIMLOCK_DATA corrupted! |
05-27-2010, 12:01 | #4 (permalink) |
No Life Poster Join Date: Feb 2008 Location: ATI atheeq technical(srilanka)
Member: 709520 Status: Offline Thanks Meter: 275 | Tick init simlock and also tick make sim lock rpl and press update splock. IF SIMLOCK DATA CORRUPTED WITH NCK CODE CALCULATER NOT SUPPORTED AFTER IN PM SECTION CLICK SD AUTHOR AND WRITE MODIFIED PM(WITH OUT 308 FIELD) |
The Following User Says Thank You to irfan_gsm For This Useful Post: |
05-27-2010, 14:19 | #7 (permalink) |
Member: 3617 Status: Offline Thanks Meter: 579 | SIMLOCK_DATA corrupted! SIMLOCK_DATA corrupted! Backup already exist. Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8336(03-05-2010), 1.0.0.12955(03-05-2010) Product: V 04wk47_m_v14.2.1 09-11-06 RM-36 (c) Noki SYSTEM ASIC ID: 000000010000022600010006000C192101002100 [RAP3G ver: PA 2.0] ROOT KEY HASH: E9EFF4BFAA5393217CA6B17755FC3E14 ROM ID: F28A211FAC901AEE Sending SecondaryBoot [rap3gv2_2nd.fg](0x3D00 bytes) ...OK Sending PreLoader(0x2E4 bytes) ...OK Sending ROM(0x3988 bytes) ...OK Sending CustomLoader(0x51E0 bytes) ...OK Sending SecurityBlock(0x1000 bytes) ...OK Calculating LOCK data ...OK Receiving Unlocked PM, please WAIT ... OK Unlocked PM saved to "C:\mobileEx\3.4\data\backup\355661008585960_UNLOC KED_308.1.PM" Writing Unlocked PM ... OK Completed in 25.953 s Restarting phone ... Reading Simlock info ... SIMLOCK_DATA corrupted! SIMLOCK_DATA corrupted! |
06-03-2010, 11:10 | #12 (permalink) |
Freak Poster Join Date: May 2010 Location: Pakistan Age: 47
Member: 1295798 Status: Offline Sonork: brista786 Thanks Meter: 97 | use this metohed i hope ur problem will be solved Phone logs when Scanned in Mx-key: Phone Type: RM-240 (Nokia 6500s-1) SW Version: V 10.00 06-03-09 RM-240 (c) Nokia Imei plain: 35765901674649-9 Language Pack: - not available. SIMLOCK invalid! SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. SIMLOCK_TEST failed! SECURITY_TEST passed SIMLOCK_DATA corrupted! PROCEDURE TO FOLLOW 1.Repair SD 2.SUPER SD Auth 3.PM Write 4.Repair SIMLOCK Step by Step: 1. Repair SD. Under IMEI & Security tab click IMEI Rebuild and click "Repair SD". Wait until mx-key finishes it's job.. Sample Log: Using device: J.A.F, FW ver: 01.B1 Library version: 1.0.0.11985, Date: 03-02-2010 Product: V 10.00 06-03-09 RM-240 (c) Nokia SYSTEM ASIC ID: 000000010000022600010006010C192101003000 [RAP3G ver: PA 3.0] ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 273F6D55DFAAF68F Sending SecondaryBoot ...OK Sending PreLoader ...OK Sending CustomLoader ...OK Calculating SUPERDONGLE using security server ... Connecting to server[main.mxkey.biz] ...OK, secure login ... Completed in 4.906 s RPL saved to "C:\mobileEx\3.3\data\backup\BB5_RM-240_357659016746499_SD.RPL" Updating SUPERDONGLE_KEY ...OK After repairing SUPERDONGLE_KEY, SECURITY_TEST has been damaged. see status: Phone Type: RM-240 (Nokia 6500s-1) SW Version: V 10.00 06-03-09 RM-240 (c) Nokia Imei plain: 35765901674649-9 Language Pack: - not available. SIMLOCK invalid! SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST failed! SECURITY_TEST failed! SIMLOCK_DATA corrupted! proceed to next steps to restore SECURITY_TEST. 2. SUPER SD Auth. Under PM tab click "SUPER SD Auth". Again wait for mx-key to finish.. Sample Log: Using device: J.A.F, FW ver: 01.B1 Library version: 1.0.0.11985, Date: 03-02-2010 Product: V 10.00 06-03-09 RM-240 (c) Nokia SYSTEM ASIC ID: 000000010000022600010006010C192101003000 [RAP3G ver: PA 3.0] ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 273F6D55DFAAF68F Sending SecondaryBoot ...OK Sending PreLoader ...OK Sending CustomLoader ...OK Restarting phone ... Connecting to server[main.mxkey.biz] ...OK, secure login ... Authenticating to SUPERDONGLE using security server ... SUPERDONGLE authorized ! After the unit has been authorized, you can now write pm fields 1 and 309.. For my case, i use a complete pm file but chose to skip simlock area. 3. Write good pm file. Still under PM tab..Locate "Load from file" then click it.. a folder will pop-up asking you to choose the pm file you would like to write.. pick the file then click "Open". Wait for mx-key to finish. Sample Log: Completed in 7.828 s Writing PM from Node ... Section: 1 - Key: 0, size 114 bytes written. - Key: 2, size 98 bytes written. - Key: 4, size 110 bytes written. - Key: 6, size 98 bytes written. - Key: 8, size 110 bytes written. - Key: 13, size 98 bytes written. - Key: 16, size 98 bytes written. - Key: 18, size 98 bytes written. - Key: 20, size 98 bytes written. - Key: 22, size 16 bytes written. - Key: 23, size 4 bytes written. - Key: 24, size 84 bytes written. - Key: 25, size 4 bytes written. - Key: 26, size 110 bytes written. - Key: 28, size 98 bytes written. - Key: 29, size 10 bytes written. - Key: 31, size 98 bytes written. - Key: 33, size 36 bytes written. - Key: 34, size 80 bytes written. - Key: 40, size 16 bytes written. - Key: 41, size 182 bytes written. - Key: 42, size 4 bytes written. - Key: 43, size 36 bytes written. - Key: 44, size 182 bytes written. Section: 2 - Key: 0, size 448 bytes written. Section: 4 - Key: 1, size 48 bytes written. - Key: 3, size 10 bytes written. - Key: 4, size 8 bytes written. - Key: 5, size 8 bytes written. - Key: 6, size 8 bytes written. - Key: 9, size 5 bytes written. - Key: 18, size 80 bytes written. - Key: 19, size 4 bytes written. - Key: 28, size 2 bytes written. Section: 8 - Key: 1, size 12 bytes written. - Key: 7, size 8 bytes written. Section: 11 - Key: 0, size 4 bytes written. - Key: 1, size 4 bytes written. - Key: 2, size 4 bytes written. - Key: 3, size 4 bytes written. - Key: 4, size 1 bytes written. - Key: 5, size 6 bytes written. - Key: 6, size 2 bytes written. - Key: 7, size 1 bytes written. - Key: 8, size 1 bytes written. - Key: 9, size 1 bytes written. - Key: 10, size 1 bytes written. - Key: 11, size 1 bytes written. - Key: 12, size 1 bytes written. - Key: 13, size 1 bytes written. - Key: 14, size 2 bytes written. - Key: 15, size 2 bytes written. - Key: 16, size 2 bytes written. - Key: 17, size 2 bytes written. - Key: 18, size 16 bytes written. - Key: 19, size 32 bytes written. - Key: 20, size 32 bytes written. - Key: 21, size 2 bytes written. - Key: 22, size 2 bytes written. - Key: 23, size 2 bytes written. - Key: 24, size 2 bytes written. - Key: 25, size 2 bytes written. - Key: 26, size 2 bytes written. - Key: 27, size 2 bytes written. - Key: 28, size 2 bytes written. - Key: 29, size 2 bytes written. - Key: 30, size 2 bytes written. - Key: 31, size 2 bytes written. - Key: 32, size 2 bytes written. - Key: 33, size 2 bytes written. - Key: 34, size 2 bytes written. - Key: 35, size 2 bytes written. - Key: 36, size 2 bytes written. - Key: 37, size 2 bytes written. - Key: 38, size 2 bytes written. - Key: 39, size 2 bytes written. - Key: 40, size 2 bytes written. - Key: 41, size 2 bytes written. - Key: 42, size 2 bytes written. - Key: 43, size 2 bytes written. - Key: 44, size 2 bytes written. - Key: 45, size 2 bytes written. - Key: 46, size 2 bytes written. - Key: 47, size 2 bytes written. - Key: 48, size 2 bytes written. - Key: 49, size 2 bytes written. - Key: 50, size 2 bytes written. - Key: 51, size 2 bytes written. - Key: 52, size 2 bytes written. - Key: 53, size 2 bytes written. - Key: 54, size 2 bytes written. - Key: 55, size 2 bytes written. - Key: 56, size 2 bytes written. - Key: 57, size 2 bytes written. - Key: 58, size 2 bytes written. - Key: 59, size 2 bytes written. - Key: 60, size 2 bytes written. - Key: 61, size 2 bytes written. - Key: 62, size 2 bytes written. - Key: 63, size 2 bytes written. - Key: 64, size 2 bytes written. - Key: 65, size 4 bytes written. - Key: 66, size 1 bytes written. - Key: 67, size 4 bytes written. - Key: 68, size 4 bytes written. - Key: 69, size 4 bytes written. - Key: 70, size 4 bytes written. - Key: 71, size 16 bytes written. - Key: 72, size 4 bytes written. - Key: 73, size 2 bytes written. - Key: 74, size 13 bytes written. Section: 31 - Key: 4, size 16 bytes written. Section: 42 - Key: 0, size 2 bytes written. - Key: 1, size 12 bytes written. - Key: 2, size 36 bytes written. - Key: 3, size 36 bytes written. - Key: 4, size 36 bytes written. - Key: 5, size 36 bytes written. - Key: 6, size 36 bytes written. - Key: 7, size 40 bytes written. - Key: 8, size 40 bytes written. - Key: 9, size 40 bytes written. - Key: 10, size 40 bytes written. - Key: 11, size 40 bytes written. - Key: 12, size 40 bytes written. - Key: 13, size 40 bytes written. - Key: 14, size 40 bytes written. Section: 50 - Key: 0, size 2 bytes written. Section: 54 - Key: 0, size 2 bytes written. Section: 66 - Key: 0, size 2050 bytes written. - Key: 1, size 240 bytes written. - Key: 2, size 240 bytes written. - Key: 3, size 1 bytes written. - Key: 4, size 1 bytes written. - Key: 5, size 240 bytes written. - Key: 6, size 4 bytes written. - Key: 7, size 4 bytes written. - Key: 8, size 4 bytes written. - Key: 9, size 4 bytes written. - Key: 10, size 240 bytes written. - Key: 11, size 240 bytes written. - Key: 12, size 1 bytes written. - Key: 16, size 4 bytes written. - Key: 18, size 4 bytes written. - Key: 20, size 4 bytes written. - Key: 22, size 4 bytes written. - Key: 24, size 4 bytes written. - Key: 26, size 4 bytes written. - Key: 28, size 4 bytes written. - Key: 30, size 4 bytes written. - Key: 32, size 4 bytes written. - Key: 34, size 4 bytes written. - Key: 57, size 8 bytes written. - Key: 58, size 8 bytes written. - Key: 59, size 8 bytes written. - Key: 60, size 8 bytes written. - Key: 61, size 8 bytes written. - Key: 75, size 8 bytes written. - Key: 76, size 8 bytes written. - Key: 78, size 6144 bytes written. - Key: 79, size 300 bytes written. - Key: 80, size 60 bytes written. - Key: 91, size 3 bytes written. - Key: 92, size 3 bytes written. - Key: 93, size 3 bytes written. - Key: 94, size 3 bytes written. - Key: 95, size 3 bytes written. - Key: 96, size 3 bytes written. - Key: 98, size 4 bytes written. - Key: 99, size 4 bytes written. - Key: 100, size 4 bytes written. - Key: 101, size 4 bytes written. - Key: 102, size 4 bytes written. - Key: 103, size 6 bytes written. - Key: 105, size 4 bytes written. - Key: 106, size 4 bytes written. - Key: 107, size 4 bytes written. - Key: 116, size 120 bytes written. - Key: 118, size 30 bytes written. - Key: 119, size 1 bytes written. - Key: 120, size 8 bytes written. Section: 88 - Key: 0, size 36 bytes written. Section: 96 - Key: 0, size 24 bytes written. Section: 107 - Key: 0, size 21 bytes written. - Key: 1, size 89 bytes written. - Key: 2, size 69 bytes written. - Key: 3, size 70 bytes written. - Key: 26, size 12 bytes written. - 120 skipped Section: 122 - Key: 0, size 2 bytes written. Section: 193 - Key: 2, size 8 bytes written. - Key: 3, size 32 bytes written. - Key: 4, size 32 bytes written. - Key: 9, size 64 bytes written. Section: 208 - Key: 1, size 4 bytes written. Section: 218 - Key: 0, size 2 bytes written. Section: 238 - Key: 1, size 1 bytes written. Section: 309 - Key: 0, size 4 bytes written. - Key: 1, size 2 bytes written. - Key: 2, size 12 bytes written. - Key: 4, size 12 bytes written. - Key: 5, size 12 bytes written. - Key: 7, size 12 bytes written. - Key: 8, size 12 bytes written. - Key: 17, size 12 bytes written. Section: 322 - Key: 0, size 1 bytes written. Section: 334 - Key: 0, size 1 bytes written. Section: 339 - Key: 0, size 511 bytes written. - Key: 1, size 511 bytes written. Section: 341 - Key: 0, size 1 bytes written. - Key: 3, size 4 bytes written. - Key: 4, size 4296 bytes written. Section: 354 - Key: 0, size 3 bytes written. Section: 356 - Key: 0, size 2 bytes written. - Key: 1, size 8 bytes written. Section: 362 - Key: 0, size 1 bytes written. - Key: 1, size 120 bytes written. Completed in 9.594 s after pm write, check the status of the unit.. Phone Type: RM-240 (Nokia 6500s-1) SW Version: V 10.00 06-03-09 RM-240 (c) Nokia Imei plain: 35765901674649-9 Product Code: 0543754 Language Pack: - not available. SIMLOCK invalid! SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST failed! SECURITY_TEST passed SIMLOCK_DATA corrupted! SECURITY_TEST has been restored.. Proceed to next step to repair SIMLOCK. 4.Repair SIMLOCK. Under "IMEI & SECURITY" click Simlock locate and click "Repair SIMLOCK" in Options menu. Also click "Make SIMLOCK RPL" then then click "Update SpLock". Wait for mx-key to finish. Sample Log: Library version: 1.0.0.11985, Date: 03-02-2010 Product: V 10.00 06-03-09 RM-240 (c) Nokia SYSTEM ASIC ID: 000000010000022600010006010C192101003000 [RAP3G ver: PA 3.0] ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 273F6D55DFAAF68F Sending SecondaryBoot ...OK Sending PreLoader ...OK Sending CustomLoader ...OK Calculating SIMLOCK using security server ... Connecting to server[main.mxkey.biz] ...OK, secure login ... Completed in 4.672 s RPL saved to "C:\mobileEx\3.3\data\backup\BB5_RM-240_357659016746499_SIM.RPL" Updating SIMLOCK...OK Reading Simlock info ... Imei net: 357659016746499 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF After all procedure's are done, scan the unit again to check it's status.. Phone Type: RM-240 (Nokia 6500s-1) SW Version: V 10.00 06-03-09 RM-240 (c) Nokia Imei plain: 35765901674649-9 Product Code: 0543754 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 357659016746499 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF Unit successfully repaired.. thanks to Mx-key team.. |
06-03-2010, 11:50 | #13 (permalink) |
Member: 3617 Status: Offline Thanks Meter: 579 | thx brother but my phone is old BB5 its mean is 6680 not 6500S I follow all this steps but still contact Servise also i make full erase and still now no solution |
06-03-2010, 12:01 | #15 (permalink) |
Member: 3617 Status: Offline Thanks Meter: 579 | My phone is SL corrupted is not FFFFFFFFFFFFFFFFFFFFF Searching for JAF box ... Searching for UFS box ... UFS box detected Box firmware version: 208 Try synchronization with phone Phone detected Read phone informations Type: RM-36 Version: V 04wk47_m_v14.2.1 09-11-06 RM-36 (c) Noki IMEI: 355661008585960 SP LOCK status: Config Key: 0000000000000000 Provider Key: 0000000000000000 Counters: 0/3, 0/10 Phone is Unlocked Read Phone Info OK Try Boot phone in flash mode ASIC ID: 000000010000022600010006000C192101002100 HASH: E9EFF4BFAA5393217CA6B17755FC3E14 ROM ID: F28A211FAC901AEE Phone connection check OK |
"help contact service" | neb | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 16 | 09-10-2011 07:40 |
contact service due to unlocking | rothmanns | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 09-11-2000 21:42 |
help! contact service 5.28 5110! | koloksky | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 06-23-2000 15:43 |
Nokia 5110 v. 5.24 Unlock Failed! | Cybertooth | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 02-28-2000 15:35 |
Mti init failed | dogbreak | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-22-1999 01:28 |
