ASUS ASUS Devices |
10-31-2014, 11:26 | #1 (permalink) |
Product Manager Join Date: Dec 2009 Location: CEO.of.ROMDevelopers Age: 32
Member: 1174508 Status: Offline Sonork: 100.1593820 Thanks Meter: 11,979 | ASUS-FAQ (Update Manual/Informatione/Flash/Wipe ETC) HI , let's we keeps all kind ASUS information on this thread , I seen on forum some user face problems . So i want to inform them tips about asus . Unfortunately, We have no ASUS section on this forum . I already request for the section . Hopefully as soon as will be add ASUS section in this forum . Then we will move to ASUS section . Until become ASUS section we use Android Section Lets me start using Question and answer Q: Where to download ASUS firmware ? A: You can download from ASUS official side , Here is it Example : I need ASUS T00G , Check Here Q: How to know the device model? A: Path: Settings->About-> Model number Q:How to know the device software version? A:Path: Settings->About-> software information->Build number Q: What is ASUS SKU ? A: Simply we can call its language pack of software version Q: Can i use any SKU ? A: No , Software update cannot transfer the software SKU and downgrade the software version and Wrong SKU may cause update failure, please update the same SKU version only ! Example: WW->WW, CN->CN, TW->TW, CHT->CHT. Q: How to know my phone SKU ? A: Go to [Settings] -> [About tablet] -> Build number Example : WW_epad-9.X.X.X._2012xxxx, where “WW” means SKU. Q: Can I Update Low Version To Direct Latest Version ? A: Yes you can but if you try direct update , You can get error on update , Cases some version require another update Example - Your phone have 1.12 You need update 2.XX , This case you need update V1.18 Update 1st then you can update 2XX Q: How to know my phone require another update 1st then i can update to latest ? A: Before download Firmware read 1st You you will see like below " Note: Please make sure update software version V1.18.40.12 first before update to software version V2.19.40.18 This case you must update 1st V1.18 then you can update V2.19 If anything missing just thread report , Mod can be add your Information Don't Copy to other forum or side , If you want copy must write who originally posted Also Write Copy From GSMHOSTING __________________ Use the Forum according to Rules...! Each section has Rules to follow Cordially, AzimBahar/ParvezAhmed Last edited by Nizda Mobile; 03-01-2017 at 18:17. Reason: Update Links |
The Following 18 Users Say Thank You to aZimBahar For This Useful Post: |
10-31-2014, 11:34 | #2 (permalink) |
Member: 1174508 Status: Offline Sonork: 100.1593820 Thanks Meter: 11,979 | How To Update ASUS Phone Q: How To Update ASUS Phone ? A: You can update With SD/Internal mmc Card also have another way but i cant share until test You can Download Manual From Support Side or fellow me ! How To Update With SD Card/Internal mmc Extract Your Firmware Copy Your zip file - XX-ASUS_T00X-XX-X.XX.XX.XX-user.zip To Phone Disconnect Usb cable From Phone You Will Get A Notification Or Down the System Notification bar Select System Update File Detect.... Click OK Click Again OK Phone Will Be Booted On Update... Wait For Finish , Whenever Finish Its Will Be Reboot Enjoy ! __________________ Use the Forum according to Rules...! Each section has Rules to follow Cordially, AzimBahar/ParvezAhmed Last edited by aZimBahar; 09-26-2015 at 04:46. |
The Following 8 Users Say Thank You to aZimBahar For This Useful Post: |
11-12-2014, 12:06 | #4 (permalink) |
Member: 1174508 Status: Offline Sonork: 100.1593820 Thanks Meter: 11,979 | Tutorial }- How to Unbrick Zenfone 5 and Zenfone 6 |
The Following 6 Users Say Thank You to aZimBahar For This Useful Post: |
12-01-2014, 07:36 | #5 (permalink) |
Member: 1174508 Status: Offline Sonork: 100.1593820 Thanks Meter: 11,979 | How To Identify ASUS SKU From hang Phone ? How To Identify ASUS SKU From hang Phone :
Br AzimBahar/ParvezAhmed.NET |
The Following 4 Users Say Thank You to aZimBahar For This Useful Post: |
12-01-2014, 08:25 | #6 (permalink) |
Member: 1174508 Status: Offline Sonork: 100.1593820 Thanks Meter: 11,979 | How To Update ASUS With CMD / ADB Mode ? How To Update ASUS With CMD / ADB Mode ?
Note - If Update fails , Read #1 : http://forum.gsmhosting.com/vbb/f606...ation-1874625/ Details ! Br AzimBahar/ParvezAhmed.NET Last edited by aZimBahar; 12-01-2014 at 08:30. |
The Following 17 Users Say Thank You to aZimBahar For This Useful Post: |
02-01-2015, 03:41 | #8 (permalink) |
Member: 1174508 Status: Offline Sonork: 100.1593820 Thanks Meter: 11,979 | Simply Unbrick Asus : [B]Warning ... Simply Unbrick Asus : Before try Unbrick Zenfone 5 and Zenfone 6 This Case , If your phone like this Brick http://forum.gsmhosting.com/vbb/redi...0c94680569245e Its avileable to Entry recovery Mode , Just Off your phone and entry recovery mode , Then try Hardreset And Check , If its still Brick Then Install firmware to Recovery mode ! I have done Unbrick Zenfone 5 and Zenfone 6 both via recovery mode ! So Attension before doing Unbrick Zenfone 5 and Zenfone 6 Tested on many ASUS ! Br AzimBahar/ParvezAhmed.NET Last edited by THE CLASH; 03-30-2015 at 11:56. |
The Following 7 Users Say Thank You to aZimBahar For This Useful Post: |
02-04-2015, 05:42 | #9 (permalink) |
Member: 1174508 Status: Offline Sonork: 100.1593820 Thanks Meter: 11,979 | Zenfone 4 (A400CG) Bootloop Solution Share By AzimBahar Zenfone 4 (A400CG) Bootloop Solution : How To Do :
Br Azimbahar/ParvezAhmed.NET Last edited by ...:::::NP™:::::...; 03-29-2018 at 17:03. |
02-19-2015, 11:26 | #10 (permalink) |
Member: 1174508 Status: Offline Sonork: 100.1593820 Thanks Meter: 11,979 | How To Update ASUS ASUS Fonepad 7 (K012) How To Update ASUS ASUS Fonepad 7 (K012):
Enjoy My method Br AzimBahar/ParvezAhmed.NET Last edited by aZimBahar; 12-09-2015 at 14:06. |
03-05-2015, 22:08 | #12 (permalink) | |
No Life Poster Join Date: Jul 2007 Location: Dhaka, Bangladesh.
Member: 552244 Status: Offline Sonork: 100.1578827 Thanks Meter: 180 | Quote:
The Following 2 Users Say Thank You to .::MD_AKTER::. For This Useful Post: |
04-21-2015, 06:36 | #14 (permalink) |
Member: 1174508 Status: Offline Sonork: 100.1593820 Thanks Meter: 11,979 | Complete log writing boot,fastboot,recovery .IMG for Unbrick Asus Code: Microsoft Windows [Version 6.1.7601] Copyright (c) 2009 Microsoft Corporation. All rights reserved. C:\Users\azimbahar>cd \ C:\>fastboot flash recovery recovery.img target reported max download size of 1329861973 bytes sending 'recovery' (12185 KB)... OKAY [ 1.823s] writing 'recovery'... (bootloader) secure device (bootloader) signed image OKAY [ 2.049s] finished. total time: 3.878s C:\>fastboot flash fastboot fastboot.img target reported max download size of 1329861973 bytes sending 'fastboot' (12440 KB)... OKAY [ 1.808s] writing 'fastboot'... (bootloader) secure device (bootloader) signed image OKAY [ 2.088s] finished. total time: 3.901s C:\>fastboot flash boot boot.img target reported max download size of 1329861973 bytes sending 'boot' (9210 KB)... OKAY [ 1.453s] writing 'boot'... (bootloader) secure device (bootloader) signed image OKAY [ 1.759s] finished. total time: 3.218s Br AzimBahar/ParvezAhmed Last edited by aZimBahar; 04-21-2015 at 06:43. |
The Following 11 Users Say Thank You to aZimBahar For This Useful Post: |
