Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Walton
Old 07-03-2013, 22:45   #1 (permalink)
Super Moderator
Parash's Avatar
Member: 1435864
Sonork: / Skype id: Parashsky
Thanks Meter: 1,755
Walton primo H1 Root and CWM recovery
Root Walton primo H1
Lets do this:
Download the Framaroot.apk from here . install it on your phone, Click Gandlaf to root. Reboot your Phone
Isn't it very simple !!!! to root your primo H1
Note: It may void your warranty, i will not responsible for your any kind of damage of your phone
BR.
The Following 3 Users Say Thank You to Parash For This Useful Post:
Old 07-03-2013, 22:47   #2 (permalink)
Super Moderator
Parash's Avatar
Member: 1435864
Thanks Meter: 1,755
CWM recovery for walton primo H1
# Install driver
Driver installation
1) Install AP part driver
Power off handset, press “Power key + Voice Up key” until the screen shows green, plug in usb cable, PC will remind you of installing new hardware. Unzip “ Driver”, select adb driver file, install AP driver.
Path: Right click on My computer>Manage>Device manager>Android(Yellow notification)>Update driver software>browse path> select adb folder >Continue anyway>finish
When you install AP driver successfully, you will find “Fastboot interface” in device manager.
2) Install BP part driver
(i) Power off handset, press “Power key + Voice down key” until the screen shows QPST mode, plug in 5Pin USB cable, Unzip “Driver”, select HK11-VB717-27_1.0.56 driver file, install BP driver.
Path: Right click on My computer>Manage>Device manager>Tiyanyu HS-USB Driver (Yellow notification)>Update driver software>browse path> HK11-VB717-27_1.0.56\Win32\x86\free >Continue anyway>finish.
(ii) When your BP driver is installed successfully, you will find Qualcomm HS-USB ports in device manager.
2nd step: download ” recovery.img “ and “Android AIO Flasher” file from here
4. Go to Fastboot mode in your phone by pressing Volume up + power key together ( Green Screen)
5. Connect your phone into PC via USB cable
3. Open “Android AIO Flasher”
5. Select recovery > Select file > Flash
Done!!! CWM recovery is successfully installed in your Walton Primo H1
BR.
The Following 4 Users Say Thank You to Parash For This Useful Post:
Old 11-14-2016, 10:52   #3 (permalink)
Member: 2524795
walton h1 recovery image
link not wark please re post 4seared link
Page generated in 0.24408 seconds with 8 queries
