Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 03-04-2014, 14:56   #1 (permalink)
rohit.sharma73's Avatar
Member: 2097870
Sonork: FINDING....
Thanks Meter: 65
Atf 11.10 not working after update
ATF 11.10 AFTER INSTALL NOT WORKING PROBLEM I HAVE 3 TIME REMOVE AND UNISTAAL DRIVER AFTER UPDATE SOFTWARE AND RESTORE BOX BUT SAME STILL PROBLEM >>>>PLZZ SOLVE MY PROBLEM>>>>
Please update your Box Firmware
* Follow these Instructions
1. Disconnect any phones connected to ATF Box
2. Go to "Product Support Tab"
3. Go to "Box Tools" Section
4. Click "Update Firmware" button
* Make sure you put ATF Software in Windows
FireWall Exclusion List
* Make sure you put ATF Software in your
Virus Scanner Exclusion List
Box Successfully Initialized
VBATT Powering Down <<<<
VBATT Powering Up >>>>
SET VCCIO Level Done
SET BSI Load Done
Old 03-04-2014, 15:07   #2 (permalink)
srinibas's Avatar
Member: 492222
Sonork: 100.1594126
Thanks Meter: 10,377
Contact me on sonork
Br - srinibas
Old 03-04-2014, 15:08   #3 (permalink)
satwindershine's Avatar
Member: 1562820
Thanks Meter: 32
I have same problem
shine star electronics
Old 03-04-2014, 17:44   #4 (permalink)
..::Angel::..'s Avatar
Member: 643472
Sonork: 100.96901
Thanks Meter: 16,589
Originally Posted by satwindershine View Post
I have same problem
Make sure you put AdvanceBox.exe into your AV Exception List
Make sure you put AdvanceBox.exe into your Windows Firewall Exception List.
Old 03-16-2014, 09:30   #5 (permalink)
Member: 550428
Thanks Meter: 25
i also in the same problem, but after i press stop then can use like normal..
is there got other solution to solve it? my computer don have anti virus and i already add ATF to Exception List still not working normally..
thankyou
Old 03-27-2014, 15:36   #6 (permalink)
Crazy Poster
Member: 1631454
Thanks Meter: 9
Until Solved I Dont Buy It! ATF Nitro
Until Solved I Dont Buy It! ATF Nitro!! I really need it but If the Team dont make a solution soon then Ill have to make another selection.
BRs,
LDAR
The Following User Says Thank You to mctsofpr For This Useful Post:
Old 03-28-2014, 06:11   #7 (permalink)
Member: 13726
Atf 11.10 is not perfect.....so...guys
you have to uninstall any version first....then install v11.00.....then you update with version 11.10....
This will solve most of the problems....try it
Old 03-28-2014, 12:10   #8 (permalink)
Member: 742407
Thanks Meter: 12
Sir, i uninstall ATF and driver and install v11.10 by auto update. ATF exe run normally if i disconnect usb from box and connect box again and run ATF exe its not open. task manager show atf not responding. if i click End process its not ending from desktop. after restart pc same problem. i format pc and direct install v11.10 and update important files and add ATF exe to AV exception list but the problem same. i use MSE antivirus and xp sp-2. how can solve this problem?
Old 03-28-2014, 12:57   #9 (permalink)
Member: 13726
That happened to me also....that's why i said.......u uninstall any versions from pc then INSTALL V11.....THEN INSTALL V11.10 VERSION OVER IT.......follow the instructions..
Old 03-28-2014, 13:06   #10 (permalink)
mahzra azra's Avatar
Member: 1722956
Sonork: mybestfriend.adeel
Thanks Meter: 305
i am also facing this problem. i downloaded full installer and installed it but when i open atf there is nothing.
look it----
http://imageshack.com/a/img34/1863/dleg.png
Page generated in 0.18839 seconds with 8 queries
