Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 02-28-2013, 23:05   #1 (permalink)
kabul's Avatar
Member: 433097
Sonork: 100.1661890
Thanks Meter: 8,074
ATF please update your box firmware problem fix <<< SOLVED >>>
Change USB cable and re-install drivers;
Disable Anti Virus during this , better put in exclusion list
uninstall and reinstall ATF setup but same problem plz help me ATF
Please update your Box Firmware
* Follow these Instructions
1. Disconnect any phones connected to ATF Box
2. Go to "Product Support Tab"
3. Go to "Box Tools" Section
4. Click "Update Firmware" button
* Make sure you put ATF Software in Windows
FireWall Exclusion List
* Make sure you put ATF Software in your
Virus Scanner Exclusion List
Box Successfully Initialized
Old 03-01-2013, 00:57   #2 (permalink)
el-polaco's Avatar
Member: 1057178
Sonork: Kfe~Labs Co.-
Thanks Meter: 568
100% ftdi drivers Problem!
br
Polaco
Old 03-01-2013, 08:17   #3 (permalink)
3STAR MOBILE's Avatar
Member: 1374790
Thanks Meter: 219
same prablem my box
VBATT Powering Down <<<<
VBATT Powering Up >>>>
SET VCCIO Level Done
SET BSI Load Done
please help team
Old 03-01-2013, 10:45   #4 (permalink)
sumatera's Avatar
Member: 756701
Sonork: 100.1592286
Thanks Meter: 91
Same problem, after update new version
and
now my box cannot use
how to slove?
Old 03-01-2013, 10:55   #5 (permalink)
srinibas's Avatar
Member: 492222
Sonork: 100.1594126
Thanks Meter: 10,377
@ sumatera
RESTORE BOX firmware & post result
Br - srinibas
The Following User Says Thank You to srinibas For This Useful Post:
Old 03-01-2013, 11:13   #6 (permalink)
sumatera's Avatar
Member: 756701
Sonork: 100.1592286
Thanks Meter: 91
i did restore box
this log
Initializing Target Device...
Reading Security...
Performing Data Authentication.................................... .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................
Programming UROW...
Programming Array............................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. ........
Verifying Array............................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. .................................................. ..........r
Programming Rlock...
Programming SILSIG...
Advance-Box Secure AES-128 Channel
Open Port Success...
Exit code = 0...
Status: Firmware Update was a Success!
Elapsed time = 00:03:22
but same problem.
And i did too:
1. un install & erase folder atf, antivirus and firewall off
2. install again new version
3. restore box again
still same
please help me
The Following User Says Thank You to sumatera For This Useful Post:
Old 03-01-2013, 11:17   #7 (permalink)
..::Angel::..'s Avatar
Member: 643472
Sonork: 100.96901
Thanks Meter: 16,589
Hi,
Try to update box firmware on other PC.
Old 03-01-2013, 11:38   #8 (permalink)
Member: 1511344
Originally Posted by sumatera View Post
i did restore box
this log
but same problem.
And i did too:
1. Un install & erase folder atf, antivirus and firewall off
2. Install again new version
3. Restore box again
still same
please help me
having the same problem like yours now :((
..::Angel::.. --- i will try to update my box on a newly formatted pc now.
I'll post the result later
Old 03-01-2013, 11:54   #9 (permalink)
Member: 1394859
Thanks Meter: 3
yes bro problem still not update firmware please fix Mr.Thomas this bugs
Old 03-01-2013, 11:57   #10 (permalink)
kabul's Avatar
Member: 433097
Sonork: 100.1661890
Thanks Meter: 8,074
Originally Posted by ..::Angel::.. View Post
Hi,
other PC same problem plz help me
Old 03-01-2013, 12:07   #11 (permalink)
Member: 145399
Thanks Meter: 26
yes i have same problem on two pc. pls.solve.
Old 03-01-2013, 13:12   #12 (permalink)
sumatera's Avatar
Member: 756701
Sonork: 100.1592286
Thanks Meter: 91
Try with other pc result same, try with difference os (win 8) result same.
Please fix this issue.
Old 03-01-2013, 13:36   #13 (permalink)
kabul's Avatar
Member: 433097
Sonork: 100.1661890
Thanks Meter: 8,074
plz urgent help solve this problem ATF themes plz
Old 03-01-2013, 15:43   #14 (permalink)
Member: 1374790
Thanks Meter: 219
sir please help urgent
Old 03-01-2013, 21:39   #15 (permalink)
FU_Too's Avatar
Member: 55766
Thanks Meter: 333
I have similar problem although message says check firmware I tried retore and also tried update but says firmware up to date.
under Nokia Tab shows below list
ATF Box is not in USB 2.0 Mode
* Go to "Product Support" tab and click the
* "Restore Box" Button to fix the Box Firmware
** If Problem is Not Solved...
1. Make Sure you are NOT using USB HUBS
2. Make Sure your USB port is USB 2.0
3. Make Sure you are using the latest Drivers
*** If Problem is STILL Not Solved
1. Use a THICKER USB Cable
2. Connect ATF Directly to the Root USB Port
3. Uninstall Drivers, Reboot PC, Reinstall
**** If you are still Stuck...
1. Search your entire PC for "ftdibus.sys
2. Delete all "ftdibus.sys" files you find
3. Reboot PC...
4. Disconnect ATF Box and all Boxes from PC
5. Run C:\AdvanceBox Turbo Flasher\Driver\Remove_ATF_Drivers\Remove_ATF_Drive rs.bat
6. ReInstall ATF Software
7. Connect ATF Box Only to your USB Port
8. Install the Correct Drivers
INIT : FAILED , CHECK YOUR BOX FIRMWARE
The Following User Says Thank You to FU_Too For This Useful Post:
Page generated in 0.29633 seconds with 9 queries
