04-28-2014, 09:29 | #61 (permalink) | |
No Life Poster Join Date: Nov 2006 Location: Germany
Member: 396421 Status: Offline Thanks Meter: 87 | Is this the pinout: Quote:
04-28-2014, 14:08 | #62 (permalink) |
Freak Poster Join Date: Apr 2008 Age: 53
Member: 750751 Status: Offline Thanks Meter: 9 | I buy new adapter and try with Samsung s3 emmc direct desolder from board, and i have scan result. Next day i try again with another two and same and always same error "ERROR: EMMC WAS NOT Detected! 0x01 Check your Test Point Soldering". What is wrong? BR |
04-29-2014, 12:01 | #64 (permalink) | |
Member: 750751 Status: Offline Thanks Meter: 9 | Quote:
BR | |
05-03-2014, 13:07 | #65 (permalink) | |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Quote:
Br allumts | |
The Following 3 Users Say Thank You to allumts For This Useful Post: |
05-03-2014, 17:14 | #67 (permalink) | |
No Life Poster Join Date: Jan 2010 Location: China
Member: 1222089 Status: Offline Sonork: 100.1583019 Thanks Meter: 2,688 | Quote:
use ATF 4 in 1 from Smartgsm .. its 100% Working Adaptor For ATF here Successfully Logs : http://forum.gsmhosting.com/vbb/f609...-jtag-1810167/ http://forum.gsmhosting.com/vbb/f609...epair-1785442/ Save your time ... | |
The Following User Says Thank You to Smart-gsm For This Useful Post: |
05-03-2014, 22:20 | #68 (permalink) |
Member: 396421 Status: Offline Thanks Meter: 87 | i have a emmc chip which is not on the pcb. for this i tried your adapter also and it is not working as well. br Gesendet von meinem GT-I9100 mit Tapatalk |
05-04-2014, 09:40 | #69 (permalink) | |
i've seen you have more problem whith this emmc chip, are sure that's good or is Bad emmc? BR allumts | |
05-04-2014, 22:09 | #70 (permalink) | |
Moderator Join Date: Oct 2009 Location: Poland Age: 42
Member: 1139057 Status: Offline Sonork: 100.109924 Thanks Meter: 4,428 | Quote:
Anyone in Poland got this adapter can you write about seller this ?? | |
05-05-2014, 12:42 | #73 (permalink) |
Freak Poster Join Date: Feb 2008
Member: 695166 Status: Offline Thanks Meter: 24 | please explain samsung exynos 4-live phone only PLEASE FOLLOW STEPS 1-2-3 in CORRECT ORDER!!! If Connection Fails, repeat Step 1-2-3... 1. Attach Phone Battery to the Phone 2. Connect USB Cable to Phone 3. Connect the Soldered TP Connections to ATF Box |
