Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 03-05-2012, 11:24   #1 (permalink)
X-Shadow's Avatar
Member: 871
Thanks Meter: 602
*** official statement about sd card slot problem ***
After making a LOT of tests with a LOT of Boxes for the past few days,
I have come to the conclusion that Boxes who cannot read SD Card are
most probably caused by BOX FIRMWARE PROBLEM.
Currently, I am making the new Firmware for all boxes to make it work
with ALL BOXES. The Firmware will be finished within 48-72 hours.
There are currently BETA Testers using this "TEST FIRMWARE" and so
far 2 of them already confirmed that this "TEST FIRMWARE" is working.
The problem however with the current "TEST FIRMWARE" is that the FBUS
Flashing is not stable because this "TEST FIRMWARE" is still in its early
BETA STAGE.
If You want to TEST the Firmware, you need to contact me in
Sonork 100.40000
Beta TESTING is OPEN to anyone,, but PLEASE KEEP IN MIND THAT FBUS
FLASHING IS DISABLED IN THE BETA FIRMWARE!!!
So it will be better to wait 72 hours for the STABLE FIRMWARE.
I Apologize for the inconvenience this SD Card Slot has caused, but rest
assured that I am doing everything I can to get this problem rectified.
B.R.
X-Shadow
The Following 28 Users Say Thank You to X-Shadow For This Useful Post:
Old 03-05-2012, 11:29   #2 (permalink)
srinibas's Avatar
Member: 492222
Sonork: 100.1594126
Thanks Meter: 10,377
Yes it works ( read SD card after flash new firmware to ATF modified box )
Thanks 2 ATF team
The Following 5 Users Say Thank You to srinibas For This Useful Post:
Old 03-05-2012, 11:37   #3 (permalink)
srinibas's Avatar
Member: 492222
Sonork: 100.1594126
How to Flash new firmware to your Modified ATF box ?
Remember :- This is not final release only for test purpose , Fbus flashing will not stable in this firmware .
Sonork 100.40000
Step
Disconnect all BOX n Dongle from your PC
Close ATF Program if it running
Connect ATF Box
Unzip the Firmware pack
Double click "
test_firmware.bat "
It will take 5 - 7 Min
You can back to your original firmware by ATF tool > Restore Box ( Select Modified PCB )
The Following User Says Thank You to srinibas For This Useful Post:
Old 03-05-2012, 11:40   #4 (permalink)
Member: 99815
Thanks Meter: 27
Before:
ERROR: Failed to Reset Micro SD Card...
With TEST firmware:
1 ATF Box Found...
ATF Software has already paired itself
with this ATF Box.
Card Reset Done!
Initializing Micro SD Card...
Card Initialized OK (V2.0 Compliant)
Waiting for IDLE State...
Card is now IDLE!
Reading Micro SD Card Information...
Manufacturer ID : 0x03
Application ID : SD
Product Name : SU08G
Product Revision : 8.0
Serial Number : 104C77C5
Manufacture Date: July 2011
Card CID: 035344535530384780104C77C500B709
Card CSD: 400E00325B5900003B377F800A4040AF
Card SCR: 0235800100000000
Card OCR: 00C0FF8000
SDHC / SDXC Card Detected...
Checking Lock Status...
Micro SD Card is NOT Password Protected!!!
Old 03-05-2012, 11:57   #5 (permalink)
..::Angel::..'s Avatar
Member: 643472
Sonork: 100.96901
Thanks Meter: 16,589
Box PCB v1.3_2010.
Before ATF Detection ERROR:
after TEST_MODIFIED Firmware:
Password Protected MMC card:
Card Reset Done!
Card is now IDLE!
Manufacturer ID   : 0x88
Application ID       :
Product Name       : SD
Product Revision  : 1.0
Serial Number       : 000035FD
Manufacture Date: October 2009
Card CID: 880302534420202010000035FD009A65
Card CSD: 007F00325B5A83B5FFFFCF80168000BF
Card SCR: FFFFFFFFFFFFFFFF
Card OCR: 0080FF8000
Maximum Speed: 25000000 Hertz
Micro SD Card is Password Protected!!!
NOT Password Protected MMC card:
Card Reset Done!
Card is now IDLE!
Manufacturer ID   : 0x12
Application ID       : 4V
Product Name       : SD
Serial Number       : 9470F9B9
Manufacture Date: December 2011
Card CID: 1234565344202020109470F9B900BC21
Card CSD: 006F00325F5A83C076DBDFFF8A80404B
Card SCR: 02A5000000000000
Card OCR: FF0080FF80
Old 03-05-2012, 14:12   #6 (permalink)
melmitador's Avatar
Member: 1544111
Sonork: 100.1611711
Thanks Meter: 80
what about ATF Lightning ?
we need this solution
Old 03-05-2012, 14:26   #7 (permalink)
Member: 823633
Thanks Meter: 1,705
Step
Connect ATF Box
Double click "
test_firmware.bat "
bro i am not got this file Unzip the Firmware pack
Old 03-05-2012, 15:10   #8 (permalink)
Dipendra Pathak's Avatar
Member: 747989
Sonork: 100.1593052
Thanks Meter: 8,623
For ATF Lighting and ATF Nitro, you must buy RJ45 Card Reader also known as MMC Unlocker.
Good Luck.
Old 03-05-2012, 15:26   #9 (permalink)
rabirabi's Avatar
Member: 1061924
Sonork: 100.1612111
Thanks Meter: 95
thats great move by ATF team. we are waiting for bug free ATF firmware,
Thanks
Old 03-05-2012, 17:00   #10 (permalink)
.::Gsm-Play::.'s Avatar
Member: 1615596
Sonork: 100.160704?
Thanks Meter: 760
Yes we are waiting................
Old 03-05-2012, 17:40   #11 (permalink)
Member: 1059767
Thanks Meter: 2
Good Luck.
You have schem this device? Maybe photo or link?
Old 03-05-2012, 19:52   #12 (permalink)
Member: 1615596
Sonork: 100.160704?
Thanks Meter: 760
Wink
Yes now working perfect..............................
Old 03-06-2012, 05:14   #13 (permalink)
Member: 735291
Sonork: 100.1613872
Thanks Meter: 4
my box normal pcb, working with "test normal pcb firmware"
and after check (resolder) this area:
The Following User Says Thank You to chrismon94 For This Useful Post:
Old 03-06-2012, 05:44   #14 (permalink)
srinibas's Avatar
Member: 492222
Sonork: 100.1594126
Contact me on Messenger
Old 03-06-2012, 07:00   #15 (permalink)
..:: Devil_king ::..'s Avatar
Member: 696623
Sonork: 100.1601050
Thanks Meter: 526
Thank's to atf team & srinibas for test firmware............
now my box mmc option is working well
The Following User Says Thank You to ..:: Devil_king ::.. For This Useful Post:
NOKIA TECHNICAL SERVICE BOOK AND NOKIA SERVICING SIM CARD FOR SALE TRADE FOR 7110 andrew bennett Main Sales Section 0 07-09-1999 10:41
Question about 51xx/61xx Comic Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 07-06-1999 23:47
Page generated in 0.21197 seconds with 10 queries
