03-07-2012, 12:53 | #47 (permalink) |
No Life Poster Join Date: Dec 2011 Location: I WAS BANED!
Member: 1699214 Status: Offline Thanks Meter: 70 | Advance-Box Secure AES-128 Channel Open Port Success... Error return code 6 Error return code Elapsed time = 00:00:00 after testing sucess read mmc cant restore box |
03-07-2012, 13:08 | #48 (permalink) | |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Quote:
Modification is needed when FBUS flash do not work = Green Led off. If box is working fine with PCB_1.2_2009 - so, no need any modification. We call it Modified PCB because it can be, where the new PCB can't. That do not mean, you will modify it, even if its working fine ;-) BR | |
The Following User Says Thank You to ..::Angel::.. For This Useful Post: |
03-07-2012, 14:37 | #49 (permalink) |
No Life Poster Join Date: May 2008
Member: 770503 Status: Offline Thanks Meter: 1,215 | its Awesome After 2 years later 16gb tf unlocked/repair done with test firmware Thanks to Sir X-Shadow Code: 1 ATF Box Found... ATF Software has already paired itself with this ATF Box. Card Reset Done! Initializing Micro SD Card... Card Initialized OK (V2.0 Compliant) Waiting for IDLE State... Card is now IDLE! Reading Micro SD Card Information... Manufacturer ID : 0x03 Application ID : SD Product Name : SU16G Product Revision : 8.0 Serial Number : 705040D9 Manufacture Date: September 2008 Card CID: 035344535531364780705040D900890B Card CSD: 400E00325B59000076B27F800A404013 Card SCR: FFFFFFFFFFFFFFFF Card OCR: 00C0FF8000 Maximum Speed: 25000000 Hertz SDHC / SDXC Card Detected... Checking Lock Status... Micro SD Card is Password Protected!!! Card Reset Done! Initializing Micro SD Card... Card Initialized OK (V2.0 Compliant) Waiting for IDLE State... Card is now IDLE! Reading Micro SD Card Information... Manufacturer ID : 0x03 Application ID : SD Product Name : SU16G Product Revision : 8.0 Serial Number : 705040D9 Manufacture Date: September 2008 Card CID: 035344535531364780705040D900890B Card CSD: 400E00325B59000076B27F800A404013 Card SCR: FFFFFFFFFFFFFFFF Card OCR: 00C0FF8000 Maximum Speed: 25000000 Hertz SDHC / SDXC Card Detected... Checking Lock Status... Micro SD Card is Password Protected!!! Preparing Force Erase... Removing Password... Full Factory Erasing... Rechecking Lock Status... Micro SD Card Password Removed!!! ALL USER DATA HAS BEEN ERASED Process Done... |
03-08-2012, 04:08 | #51 (permalink) |
Product Manager Join Date: Apr 2008 Location: Whitehole throught Blackhole!
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,623 | Then you have no idea. Even dead project JAF has this function and works perfectly. This is not device like ATF BOX. It is simply card reader works with RJ45. I have this tool that's why I am writing for your kind information. |
03-08-2012, 07:13 | #52 (permalink) |
No Life Poster Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 52
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | ATF Lighting & Nitro user wait a little to get the solution about SD Card reading. Thanks Br - srinibas |
03-08-2012, 13:13 | #55 (permalink) |
Member: 770503 Status: Offline Thanks Meter: 1,215 | 1GB TF Repaired. Code: 1 ATF Box Found... ATF Software has already paired itself with this ATF Box. Card Reset Done! Initializing Micro SD Card... Card Initialized OK (V2.0 Compliant) Waiting for IDLE State... Card is now IDLE! Reading Micro SD Card Information... Manufacturer ID : 0x1B Application ID : SM Product Name : 00000 Product Revision : 1.0 Serial Number : 1E61A0F5 Manufacture Date: September 2010 Card CID: 1B534D3030303030101E61A0F500A919 Card CSD: 007FFF325B5983B9F6DBDFFF1240008F Card SCR: FFFFFFFFFFFFFFFF Card OCR: 0080FF8000 Maximum Speed: 25000000 Hertz Checking Lock Status... Micro SD Card is Password Protected!!! Card Reset Done! Initializing Micro SD Card... Card Initialized OK (V2.0 Compliant) Waiting for IDLE State... Card is now IDLE! Reading Micro SD Card Information... Manufacturer ID : 0x1B Application ID : SM Product Name : 00000 Product Revision : 1.0 Serial Number : 1E61A0F5 Manufacture Date: September 2010 Card CID: 1B534D3030303030101E61A0F500A919 Card CSD: 007FFF325B5983B9F6DBDFFF1240008F Card SCR: FFFFFFFFFFFFFFFF Card OCR: 0080FF8000 Maximum Speed: 25000000 Hertz Checking Lock Status... Micro SD Card is Password Protected!!! Preparing Force Erase... Removing Password... Full Factory Erasing... Rechecking Lock Status... Micro SD Card Password Removed!!! ALL USER DATA HAS BEEN ERASED Process Done... |
03-13-2012, 17:08 | #60 (permalink) |
No Life Poster Join Date: May 2011 Location: ***DUBAI*** Age: 38
Member: 1579234 Status: Offline Sonork: Not user Thanks Meter: 342 | 1 ATF Box Found... ATF Software has already paired itself with this ATF Box. ERROR: Failed to Reset Micro SD Card... ERROR: Failed to Reset Micro SD Card... ERROR: Failed to Reset Micro SD Card... ERROR: Failed to Reset Micro SD Card... ERROR: Failed to Reset Micro SD Card... ERROR: Failed to Reset Micro SD Card... ERROR: Failed to Reset Micro SD Card... |
NOKIA TECHNICAL SERVICE BOOK AND NOKIA SERVICING SIM CARD FOR SALE TRADE FOR 7110 | andrew bennett | Main Sales Section | 0 | 07-09-1999 10:41 |
Question about 51xx/61xx | Comic | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-06-1999 23:47 |
