11-26-2013, 07:50 | #1 (permalink) |
No Life Poster Join Date: Sep 2003 Location: WATCHING YOU
Member: 38562 Status: Offline Thanks Meter: 1,478 | Post here successfully unlocked lumia phones with ATF JTAG Code: Default language ID 0x0409 JTAG Interface Connected, S/N 0xA780076A Resetting and Exploring JTAG chain...1 Device(s) Device #1 ID 0x106210E1 IR4 Loading AFP (Please Wait)...OK AFP revision 4, compiled 11/26/2013 10:48:00 AM ========================================================== Phone Type : Lumia 610 RM-835 - Supported : Lumia 610 RM-849 - Supported : Lumia 610C RM-836 - Supported Unlock Type : Read PIN and PUK Unlock Codes Other Notes : Disconnect USB Cable before Reading Codes ========================================================== NOTES_DEV_0004 Disconnect USB Cable from Phone (If Connected) Re-Connect USB Cable to Phone... Connect USB Cable to Phone...OK USB Connected! Waiting for First Event...OK Disconnect USB Cable Now...OK Re-Connect USB Cable to Phone... Waiting for Device Connection 10 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Retrieving Unlock Codes... =================================== Service Provider Unlock Codes Found =================================== PIN: 58731509 PUK: 27793815 =================================== NOTES_END_0004 LEMOR Edit: Thread was cleaned with off-topic posts, DO NOT post any question in this thread only successfully unlocked lumia phones via JTAG. :-) Last edited by ..::Angel::..; 12-02-2013 at 10:57. |
The Following 17 Users Say Thank You to lemor For This Useful Post: |
11-26-2013, 17:10 | #2 (permalink) |
No Life Poster Join Date: Feb 2010 Location: FROM-PERÚ
Member: 1242979 Status: Offline Sonork: ☻9-9126-6305☻ Thanks Meter: 337 | Unlock Done nokia Lumia 505 Thx.. ATF-Team good work. ______________ Regards! MobileZone |
The Following User Says Thank You to mobile_zone1 For This Useful Post: |
11-30-2013, 16:10 | #4 (permalink) |
No Life Poster Join Date: Dec 2005 Location: Roof of the world
Member: 209722 Status: Offline Thanks Meter: 818 | Yeah I had a lumia 610 from tesco uk which one wont accepting codes read by from atf sofware. for details check log below ================================================== ======== Phone Type : Lumia 610 RM-835 - Supported : Lumia 610 RM-849 - Supported : Lumia 610C RM-836 - Supported : Lumia 510 RM-889 - Supported : Lumia 510 RM-898 - Supported : Lumia 505 RM-923 - Supported Unlock Type : Read PIN and PUK Unlock Codes Other Notes : Disconnect USB Cable before Reading Codes ================================================== ======== 1. Make sure JTAG Connection is 100% OK 2. Always Disconnect the Phone BATTERY 3. Connect RJ-45 JTAG Cable to ATF Box 4. Disconnect USB Cable from the Phone 5. DO NOT click RESET JTAG button 6. Click RESTORE BOOT button to Start Reading Unlock Codes ---------------------------------------------------------- Waiting for Device Connection 10 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...Retry Resetting and Exploring JTAG chain...No Devices found in Chain! Waiting for Device Connection 10 second(s)...OK Resetting and Exploring JTAG chain...No Devices found in Chain! Waiting for Device Connection 10 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device... Searching for PIN/PUK Unlock Codes... Please wait for a while... Codes Found! ========================= PIN Unlock Code: 81098268 PUK Unlock Code: 95704022 ========================= Reading Unlock Codes Done! ================================================== ========================== 1. Remove JTAG Connection and Assemble Phone 2. Insert SIM Card from different Provider into the Phone 3. Power ON the Phone 4. Enter 8-digit PIN Code or 8-digit PUK Code when Phone Requires it 5. After Code is accepted, wait 30 seconds until Operator Signal Appears Write Down 8-digit PIN CODE on a piece of paper and attach it to the phone under the battery. This will allow the owner of the phone to unlock this phone again if he will flash the phone firmware in the future. ================================================== ========================== All Done!OK These code wont work for mine unit so i try some trick like I did flash unit but failure then back flash to original pc but same then i made disturb my dear friend,teacher x-shadow ( Advance-Box ) at sonork, i found him kind as well as he always and he solve mine problem with his own method using a spacial file after he calculate code via his method its great as new code unlock mine unit in first attempt. I am thank full to my Freind Advance-Box. warm regards. |
11-30-2013, 18:11 | #5 (permalink) |
Freak Poster Join Date: Oct 2006 Location: yaoundé avenue kennedy
Member: 381039 Status: Offline Sonork: 100.1603121 Thanks Meter: 12 | thank you for all thank you for all please use lumia 610 unlock error http://174.120.45.27/tmp/610_610C_510_505_UNLOCK.rar |
The Following User Says Thank You to ten_sev For This Useful Post: |
12-01-2013, 17:25 | #8 (permalink) |
No Life Poster Join Date: Jun 2006 Location: UK
Member: 294200 Status: Offline Sonork: 100.1586184 Thanks Meter: 658 | Nokia lumia 610 tesco successfully unlock ATF team is the best i succsessfully unlock nokia lumia 610 today locked on tesco mobile here is log http://postimg.org/image/7ct5ivg4j/ Zubair ZK MOBILES LTD UK |
The Following User Says Thank You to zubairok For This Useful Post: |
12-02-2013, 15:13 | #11 (permalink) |
No Life Poster Join Date: Jul 2009 Location: *VODAFONE UK* Store Age: 31
Member: 1082892 Status: Offline Sonork: 100.1585374 Thanks Meter: 412 | Lumia 510 successfully unlocked codes accept O2 Tesco: |
The Following User Says Thank You to Dami_gsm For This Useful Post: |
12-02-2013, 19:52 | #14 (permalink) |
Registered User Join Date: Oct 2007 Location: Miami
Member: 603261 Status: Offline Thanks Meter: 21 | sucess unlock lumia 610 telcel mexico https://www.dropbox.com/s/f6fkt9y2e5w53f3/610%20ok.JPG https://www.dropbox.com/s/dhtohl7zqr...20foto%201.JPG |
The Following 2 Users Say Thank You to alexdoor For This Useful Post: |
12-02-2013, 20:37 | #15 (permalink) | |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | Quote:
Hi, Next Time use this file: http://174.120.45.27/tmp/610_610C_51..._UNLOCK_V2.rar This will read all 5 Lock Levels... Sometimes the phone is locked to more than 1 lock level, in that case your AFP file will not be able to read it. B.R. | |
The Following 3 Users Say Thank You to Advance-Box For This Useful Post: |
