03-25-2014, 16:20 | #91 (permalink) | |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,344 | Quote:
N7100_EFS.tar - Download - 4shared if have problem rename .TAR only br allumts | |
04-02-2014, 09:49 | #97 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,344 | Jig Unbrick is one thingh.... 4 in 1 emmc Jtag Adapter is other thingh and Lumia 900 testpoint unlock RJ45 cable is another one...please explain CLEAR what do u want do |
04-07-2014, 07:06 | #99 (permalink) | |
No Life Poster Join Date: Jul 2005 Location: philippine
Member: 159757 Status: Offline Thanks Meter: 461 | how to do this : Step 8: Final Checks Click "Scan eMMC" and make sure eMMC is set to BOOT PARTITION : BOOT PARTITION 1 successfully WRITE user data and BOOT1 but after i scan eMMC Quote:
FFC | |
04-08-2014, 01:11 | #101 (permalink) | |
Crazy Poster Join Date: Aug 2011
Member: 1631454 Status: Offline Thanks Meter: 9 | Can I leave permanently the two resistor Mod ? Quote:
After the mod with the 2 Resistors on the ATF 4 in 1 can we leave there forever for any model or its better to have 2 ATF 4 in 1 wich one can be modded with the two resistors and the other without the 2 resistors? | |
The Following 2 Users Say Thank You to mctsofpr For This Useful Post: |
04-10-2014, 15:22 | #102 (permalink) |
No Life Poster Join Date: Jan 2010 Location: fontecno
Member: 1201378 Status: Offline Sonork: 100.1594717 Thanks Meter: 303 | pls i will like to kn which color of wire gos to the VCC (2.8) and VCCQ (1.8), am useing the ATF 4 IN 1 Ultimate JTAG/EMMC/ISP/MMC Adaptor, an am some how loss there thanks Last edited by FON-TECNO; 04-10-2014 at 15:28. |
04-10-2014, 20:24 | #103 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,344 | @FON-TECNO, loock good pictures of this post and undestand where are the VCC and VCCQ, if have BIG ATF can use Pin 2 for to have VCC 3,3V, http://forum.gsmhosting.com/vbb/10135977-post1.html |
04-11-2014, 02:40 | #104 (permalink) | |
Member: 159757 Status: Offline Thanks Meter: 461 | Quote:
br. FFC | |
04-11-2014, 09:48 | #105 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,344 | @rico_deep @FON-TECNO, Your answere is here: So here you will see that I added 2 resistors (100 ohms) to the CMD and the DATA0 of the eMMC Adapter. Both of the resistors act as a Strong PULL-UP to 3.3v. SO, you can leave for Samsung eMMc unbrick, but when you wont work whith wires for Test Point or Jtag in Nokia phone i think this value are falsed... Atf Team Correct me if I'm wrong BR allumts |
