Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 03-25-2014, 16:20   #91 (permalink)
allumts's Avatar
Member: 1564612
Thanks Meter: 12,344
Originally Posted by shoaibrao View Post
Sir Can You Share Here Clean EFS?
My HandSet Has Android 4.3 With New Bootloader(Knox Bootloader)..........
Here:
N7100_EFS.tar - Download - 4shared
if have problem rename .TAR only
br
allumts
Old 03-25-2014, 17:20   #92 (permalink)
shoaibrao's Avatar
Member: 412843
Sonork: 100.1604902
Thanks Meter: 497
Originally Posted by allumts View Post
Here:
br
allumts
I Tried This EFS But Same
Also Flashed With PIT+PDA After EFS Write But Same
Need More Help Plz.........
Old 04-01-2014, 18:43   #93 (permalink)
rasheedc007's Avatar
Member: 1245320
Sonork: 100.1612126
Thanks Meter: 140
atf network activation need for this operation???
Old 04-01-2014, 19:45   #94 (permalink)
allumts's Avatar
Member: 1564612
strange you not have Atf net active.... for this operation i not think you have need Atf Net
Old 04-01-2014, 20:05   #95 (permalink)
Member: 2159585
Sonork: 1987
great news atf team.
keep it up.
Old 04-02-2014, 07:37   #96 (permalink)
Member: 1702232
Thanks Meter: 38
sir i not have atf emmc ripair jig adepter rj 45 cable worked..? please example limua 900 tespoint unlock rj 45 cable.. that cable worked..? please sir urjent
Old 04-02-2014, 09:49   #97 (permalink)
allumts's Avatar
Member: 1564612
Jig Unbrick is one thingh.... 4 in 1 emmc Jtag Adapter is other thingh and Lumia 900 testpoint unlock RJ45 cable is another one...please explain CLEAR what do u want do
Old 04-03-2014, 17:00   #98 (permalink)
jakoy's Avatar
Member: 14852
Sonork: 100.1608716
Thanks Meter: 503
need N7105 eMMC REPAIR FILES...
Old 04-07-2014, 07:06   #99 (permalink)
rico_deep's Avatar
Member: 159757
Thanks Meter: 461
how to do this :
Step 8: Final Checks
Click "Scan eMMC" and make sure eMMC is set to BOOT PARTITION : BOOT PARTITION 1
successfully WRITE user data and BOOT1 but after i scan eMMC
Interface Reset OK!
eMMC Access Type: SECTOR MODE
eMMC Supported Voltage Range:
3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V
3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V
CID : 15010056545530304DF139FF24E0
CSD : D02701320F5903FFF6DBFFFF8E40406D
eMMC Boot Information
Revision 1.6 (for MMC v4.5)
BOOT PARTITION : USER AREA
PARTITION ACCESS : R/W USER PARTITION
PERM_BOOT_CFG_PROT : DISABLED
PWR_BOOT_CFG_PROT : DISABLED
eMMC FirmW UPDATE : DISABLED
EMMC CACHE SIZE : 0 KB
SUPER PAGE SIZE : 3584 KB
HC ERASE GROUP SIZE: 512 KB
USER AREA SIZE : 15758000128 BYTES
BOOT PARTITION SIZE: 2048 KB
RPMB PARTITION SIZE: 128 KB
eMMC Device Information
Manufacturer ID: SAMSUNG
Device Type : Embedded BGA
Application ID : 00
Product Name : VTU00M
Product Rev : 15.1
Product SN : 39FF24E0
Manufactured : January 2012
Card Specific Data
CSD_STRUCTURE : Extended
SPEC_VERS : Version 4.1/4.2/4.3
TAAC : 13 ns
TRANS_SPEED : 4000000 KHz
READ_BL_LEN : 512 Bytes
C_SIZE : HIGH CAPACITY
WP_GRP_ENABLE : YES
WRITE_BL_LEN : 512 Bytes
CONTENT_PROT_APP : NO
PERM_WRITE_PROTECT: NO
TMP_WRITE_PROTECT : NO
Extended CSD Saved:
15010056545530304DF139FF24E0_F4B78A9E.ext_csd
Backup Directory:
C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\
br.
FFC
Old 04-07-2014, 16:04   #100 (permalink)
rico_deep's Avatar
Member: 159757
Thanks Meter: 461
sorry mine mistake....DONE
thanks ATF
br.
FFC
The Following User Says Thank You to rico_deep For This Useful Post:
Old 04-08-2014, 01:11   #101 (permalink)
Crazy Poster
Member: 1631454
Thanks Meter: 9
Talking Can I leave permanently the two resistor Mod ?
Originally Posted by Advance-Box View Post
Here is ONE of the phones I was able to repair... (We also have a lot of phones which required eMMC Chip replacement. After lemor changed the eMMC, the phone was fixed).
Right After eMMC Repair Tasks were done...
Phone Info showing 4.1.1...
Download Mode showing Fixed "Product Name"
I flashed phone to 4.3 just to check if flashing is OK
B.R.
After the mod with the 2 Resistors on the ATF 4 in 1 can we leave there forever for any model or its better to have 2 ATF 4 in 1 wich one can be modded with the two resistors and the other without the 2 resistors?
The Following 2 Users Say Thank You to mctsofpr For This Useful Post:
Old 04-10-2014, 15:22   #102 (permalink)
FON-TECNO's Avatar
Member: 1201378
Sonork: 100.1594717
Thanks Meter: 303
Originally Posted by swechacnu View Post
Here is the i9300 emmc pinout with color code...and also direct rj45 atf big box connection...
BR,
Srinivas Reddy.
pls i will like to kn which color of wire gos to the VCC (2.8) and VCCQ (1.8), am useing the ATF 4 IN 1 Ultimate JTAG/EMMC/ISP/MMC Adaptor, an am some how loss there thanks
Old 04-10-2014, 20:24   #103 (permalink)
allumts's Avatar
Member: 1564612
@FON-TECNO,
loock good pictures of this post and undestand where are the VCC and VCCQ, if have BIG ATF can use Pin 2 for to have VCC 3,3V,
http://forum.gsmhosting.com/vbb/10135977-post1.html
Old 04-11-2014, 02:40   #104 (permalink)
rico_deep's Avatar
Member: 159757
Thanks Meter: 461
same here ...................................
br.
FFC
Old 04-11-2014, 09:48   #105 (permalink)
allumts's Avatar
Member: 1564612
@rico_deep @FON-TECNO,
Your answere is here:
So here you will see that I added 2 resistors (100 ohms) to the CMD and the DATA0 of the eMMC Adapter. Both of the resistors act as a Strong PULL-UP to 3.3v.
SO, you can leave for Samsung eMMc unbrick, but when you wont work whith wires for Test Point or Jtag in Nokia phone i think this value are falsed... Atf Team Correct me if I'm wrong
allumts
Page generated in 0.33259 seconds with 10 queries
