Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 06-28-2014, 15:18   #136 (permalink)
Member: 45873
Thanks Meter: 35
I9300 unable to write
need help please
have 3 phones with same issue
Regards
Riaz
Old 06-28-2014, 19:48   #137 (permalink)
allumts's Avatar
Member: 1564612
Thanks Meter: 12,344
Originally Posted by riaz View Post
Hi, where is 1° step "Normal Factory Erase" ???
Read good the procedure from first step here:
http://forum.gsmhosting.com/vbb/10135977-post1.html
Which order file want write and are sure are for I9300 and not N7100?
allumts
Old 06-29-2014, 18:44   #138 (permalink)
Member: 45873
Thanks Meter: 35
Hi Allumts, I have successfully recovered many i9300 phones .
following the procedure Normal Factory Erase,Samsung Factory Format,Write EXT_CSD Backup File, Write USER AREA, and Write BOOT1
these 3 phones i am facing problem
scan emmc every thing is fine.scan completes
Normal Factory Erase completes after 3to 4 tries ,
Samsung Factory Format fails
Write EXT_CSD Backup File completes after few tries
Write USER AREA fails
I am sure the cable connections all are 100% good and tested
want to confirm its emmc chip problem or is there any other component related to this problem
Regards
Riaz
Old 06-30-2014, 05:14   #139 (permalink)
Member: 4627
Sonork: 57528:debeliamark
Thanks Meter: 1,034
Regards
Riaz
I was faced this error ( Samsung Factory Format fail ) on few eMMC IC-s ( claimed that they are brand new ) but they work when fill it with desided BOOT1 and USERDATA bin-s.
Old 06-30-2014, 09:10   #140 (permalink)
Member: 1702232
Thanks Meter: 38
please help atf team i try samsung N 7100 emc but not done ..
Old 06-30-2014, 09:12   #141 (permalink)
Member: 1702232
Thanks Meter: 38
Old 06-30-2014, 09:16   #142 (permalink)
Member: 1702232
Thanks Meter: 38
please i try sem method test point conect ..& atf ( 5 in 1 ) cable i use..but tp conect proble show...help me please...i think confuse..2.8 voltage conect tp..atf team ..help me..urjent...please...thanks
Old 06-30-2014, 11:17   #143 (permalink)
timiG's Avatar
Member: 198519
Sonork: 100.1604680
Thanks Meter: 63
@bharatsubedi
read here about 5in1 adaptor http://forum.gsmhosting.com/vbb/f609...arify-1809751/ .
br.
Old 06-30-2014, 13:45   #144 (permalink)
Member: 1702232
Thanks Meter: 38
but sir i use conection...
Old 06-30-2014, 18:09   #145 (permalink)
allumts's Avatar
Member: 1564612
@bharatsubedi,
this 5 in 1 adapter by Gpg is FAKE, all pinout are WRONG, if you not modific this adapter how photo posted you never can use for eMMc direct function.
So, or buy 4 in 1 adapter or modific this 5 in 1, no other way with this Wrong Gpg adapter cable,
allumts
The Following User Says Thank You to allumts For This Useful Post:
Old 07-01-2014, 07:51   #146 (permalink)
Member: 1702232
Thanks Meter: 38
sir N 7100 no need 2.80 voltage extranal..? please sie help me..
Old 07-01-2014, 07:56   #147 (permalink)
Member: 1702232
Thanks Meter: 38
N 7100 100 oms register 2.80 voltage no need..? with gpg 5 in 1 cable.. only modify.. cable working..?
Old 07-01-2014, 08:01   #148 (permalink)
Member: 1702232
Thanks Meter: 38
i have netro no big atf but i open atf netro & modify..netro jumper..
Old 07-01-2014, 09:45   #149 (permalink)
allumts's Avatar
Member: 1564612
You not need to modific you Atf Nitro, you have need of modific this Wrong 5 in 1 adapter by Gpg how in photo,
Old 07-01-2014, 13:15   #150 (permalink)
timiG's Avatar
Member: 198519
Sonork: 100.1604680
Thanks Meter: 63
@bharatsubedi
Just modify 5in1 like in picture posted by Allumts .
No need to remove U1 like in picture ,only cut before CMD and put jumper
from TMS to CMD .
No need to modify your atf nitro .
br.
Page generated in 0.19272 seconds with 10 queries
