06-28-2014, 19:48 | #137 (permalink) |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,344 | Hi, where is 1° step "Normal Factory Erase" ??? Read good the procedure from first step here: http://forum.gsmhosting.com/vbb/10135977-post1.html Which order file want write and are sure are for I9300 and not N7100? Br allumts |
06-29-2014, 18:44 | #138 (permalink) |
Freak Poster Join Date: Dec 2003 Location: Bangalore, India Age: 58
Member: 45873 Status: Offline Thanks Meter: 35 | Hi Allumts, I have successfully recovered many i9300 phones . following the procedure Normal Factory Erase,Samsung Factory Format,Write EXT_CSD Backup File, Write USER AREA, and Write BOOT1 these 3 phones i am facing problem scan emmc every thing is fine.scan completes Normal Factory Erase completes after 3to 4 tries , Samsung Factory Format fails Write EXT_CSD Backup File completes after few tries Write USER AREA fails I am sure the cable connections all are 100% good and tested want to confirm its emmc chip problem or is there any other component related to this problem Regards Riaz |
06-30-2014, 05:14 | #139 (permalink) | |
No Life Poster Join Date: May 2001 Location: Bulgaria Age: 56
Member: 4627 Status: Offline Sonork: 57528:debeliamark Thanks Meter: 1,034 | Quote:
06-30-2014, 09:16 | #142 (permalink) |
Freak Poster Join Date: Dec 2011
Member: 1702232 Status: Offline Thanks Meter: 38 | please i try sem method test point conect ..& atf ( 5 in 1 ) cable i use..but tp conect proble show...help me please...i think confuse..2.8 voltage conect tp..atf team ..help me..urjent...please...thanks |
06-30-2014, 11:17 | #143 (permalink) |
Freak Poster Join Date: Nov 2005 Location: Romania Age: 46
Member: 198519 Status: Offline Sonork: 100.1604680 Thanks Meter: 63 | @bharatsubedi read here about 5in1 adaptor http://forum.gsmhosting.com/vbb/f609...arify-1809751/ . br. |
06-30-2014, 18:09 | #145 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,344 | @bharatsubedi, this 5 in 1 adapter by Gpg is FAKE, all pinout are WRONG, if you not modific this adapter how photo posted you never can use for eMMc direct function. So, or buy 4 in 1 adapter or modific this 5 in 1, no other way with this Wrong Gpg adapter cable, Br allumts |
The Following User Says Thank You to allumts For This Useful Post: |
07-01-2014, 13:15 | #150 (permalink) |
Member: 198519 Status: Offline Sonork: 100.1604680 Thanks Meter: 63 | @bharatsubedi Just modify 5in1 like in picture posted by Allumts . No need to remove U1 like in picture ,only cut before CMD and put jumper from TMS to CMD . No need to modify your atf nitro . br. |
