04-12-2011, 11:12 | #198 (permalink) |
Freak Poster Join Date: Jul 2004 Location: 0xDEADBEEF Age: 42
Member: 71246 Status: Offline Thanks Meter: 40 | Can u try with this and tell me if it finds all the time correctly password please! Also if someone else want to test please tell us your VGA card setup and drivers used... The batch file will run same command 10 times ,if all is ok it must find password all the time..witch did not happening on mine config,that's why i want to test it as many as possible on different pc hardwares...!!! Last edited by randy_d4; 04-12-2011 at 11:18. |
04-12-2011, 11:19 | #199 (permalink) | |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | Quote:
http://174.120.45.27/tmp/11_phones_in_1.rar Download file above and Extract it... Phone #1 is the "7 minute" phone on 2 x 5970 ... B.R. | |
04-12-2011, 11:21 | #200 (permalink) | |
Here is Correct Example... http://174.120.45.27/tmp/11_phones_in_1.rar There are 11 phones in that Batch File. Try it on your PC... As Phone #1 takes only 7 minutes and 19 seconds on a 2 x 5970 Setup... So you can check if it is continuous on your PC. B.R. | |
The Following User Says Thank You to Advance-Box For This Useful Post: |
04-12-2011, 11:23 | #201 (permalink) | |
Something is wrong with your Command... Please download this: http://174.120.45.27/tmp/11_phones_in_1.rar And copy paste the command which is used inside the BATCH file. Just INJECT your HASH and 14 digit IMEI and it will be good to go. B.R. | |
04-12-2011, 11:30 | #202 (permalink) |
Freak Poster Join Date: Apr 2008 Location: http://donganhgsm.net
Member: 754345 Status: Offline Thanks Meter: 32 | I have 2 PC , my phone imei 35201204460735 , Advance team check 2 bat file I created please , Is it corect or not . PC1 40% , PC2 60%. 35201204460735-PC1.rar - 4shared.com - online file sharing and storage - download 35201204460735-PC2.rar - 4shared.com - online file sharing and storage - download Thanks ! |
04-12-2011, 11:40 | #203 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | How to RESTORE or RESUME a BF JOB ??? In case your PC Hang, Freeze or Prematurely Shuts Down, you can RESUME the Previous BF JOB by using the command line below: For AMD Cards and Windows 64-bit oclHashcat-lite64 --restore For AMD Cards and Windows 32-bit oclHashcat-lite32 --restore For NVIDIA Cards and Windows 64-bit cudaHashcat-lite64 --restore For NVIDIA Cards and Windows 64-bit cudaHashcat-lite64 --restore Here is an example: As you can see, the BF JOB Resumed at 63.51% You can also click "p" to pause your BF JOB anytime you want to stop your current BF JOB. Click "q" to exit the current BF JOB... You can Shut down PC or restart PC, then you can again RESUME your BF JOB via the same commands I have described above. B.R. X-Shadow |
The Following 8 Users Say Thank You to Advance-Box For This Useful Post: |
04-12-2011, 11:46 | #204 (permalink) | |
Yup, your files are correct! Start BF :O) | |
04-12-2011, 12:02 | #206 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | Update EVERYTHING (DRIVERS, CATALYST, BIOS etc..) Check here: http://forum.gsmhosting.com/vbb/f609...error-1244921/ |
04-12-2011, 13:09 | #207 (permalink) | |
No Life Poster Join Date: May 2005
Member: 149305 Status: Offline Sonork: 100.1612778 Thanks Meter: 804 | Quote:
04-12-2011, 13:46 | #210 (permalink) | |
Download this: http://174.120.45.27/tmp/359333036826719.rar B.R. | |
LinkBacks (?)
LinkBack to this Thread: https://forum.gsmhosting.com/vbb/f609/worlds-fastest-sl3-lbf-markov-edition-oclhashcat-lite-v0-10-atom-1244843/ | ||||
Posted By | For | Type | Date | |
LBF computer configuration | This thread | Trackback: | 07-04-2011 20:15 |
