10-31-2014, 08:29 | #241 (permalink) |
Junior Member Join Date: Sep 2004 Age: 57
Member: 81491 Status: Offline Thanks Meter: 7 | If I make number from R1204 to 1206 then is like discard the resistors from the board,or make them as paralel 5k,is that what you mean? All 3 resistors ends on line 1v8 so number will make the r1204 and R1206 from 10k to 5k, correct? |
10-31-2014, 09:29 | #243 (permalink) |
Freak Poster Join Date: Mar 2006 Location: Punjab, India
Member: 252886 Status: Offline Thanks Meter: 25 | A1395 Ipad2 wifi byepass not possible with this method? R1204, R1205 are present in this model. Please clear sombody. as everybody says itune will activate with serial number after removing R1204 or R1205, then why A1395 will not be byepassed? or is their anypossiblity to update it with a1396 firmware after removing R1204 or R1205? |
10-31-2014, 11:44 | #244 (permalink) |
Freak Poster Join Date: Apr 2013
Member: 1915500 Status: Offline Thanks Meter: 37 | iPad a1475 ( Air ) 3 pcs done perfectly- remove r1506 component And gays stop asking same questions Just read first post is it so hard to do it or you just want to show us that you are i Di0ts |
The Following User Says Thank You to venelin For This Useful Post: |
10-31-2014, 11:53 | #245 (permalink) | |
Freak Poster Join Date: Apr 2006 Location: SERAF CELL (IT CENTRE. MDO)
Member: 258858 Status: Offline Thanks Meter: 96 | Bypass iCloud Activation Lock HardWare Solution! Quote:
Seems like u removed r1204 n r1205 so that itunes detected it as iphone? R1204, r1205, r1206 r the same value.. Now u have to jumper r1204 to r1206. Ofcours no r1204 anymore. Try to detected it to itunes, it should be ipad2. After all, restor it use ipad2 wifi ios Sent from my iPhone using Tapatalk | |
10-31-2014, 12:25 | #246 (permalink) |
No Life Poster Join Date: Sep 2006 Location: Allah is Greatest
Member: 358694 Status: Offline Sonork: 100.1597323 Thanks Meter: 994 | I have Ipad Air a1475 its done have imei on back side. But it have place for sim card. and also SN on back side. can i bypass its icloude. Because i try with this fone but after remove last resister it dont go in DFU Mode. i used this pic http://pasha4ur.org.ua/images/phocag...y-pasha4ur.png |
The Following User Says Thank You to alamgarh For This Useful Post: |
10-31-2014, 15:30 | #248 (permalink) | |
Freak Poster Join Date: Sep 2014 Location: Ukraine Age: 36
Member: 2261540 Status: Offline Thanks Meter: 303 | Quote:
10-31-2014, 16:31 | #249 (permalink) |
Member: 81491 Status: Offline Thanks Meter: 7 | It's so important those resistors to be there,or you can remove them all and then jumper? So jumber the r1204 with r1206 and no r1205, is this correct? Thank you friend |
10-31-2014, 17:19 | #250 (permalink) | |
Member: 258858 Status: Offline Thanks Meter: 96 | Quote:
Yes, no more r1205.. R u did my instructions? Im sure u'v done right? Hehhehe... Sent from my iPhone using Tapatalk | |
10-31-2014, 17:57 | #251 (permalink) |
Member: 81491 Status: Offline Thanks Meter: 7 | Yes,I did what you said ,no luck,still iphone,i did this- removed r1205 and jumber r1204 with r 1206. I have a camera microscope and I know I've done this correct,any other advice? Thank you for reply to my questions |
10-31-2014, 18:01 | #252 (permalink) | |
Can u capture ur board here? So that i can guide u Sent from my iPhone using Tapatalk | |
10-31-2014, 18:08 | #254 (permalink) |
Member: 81491 Status: Offline Thanks Meter: 7 | I have a nice question to all. What if we have an ipad wifi that the r1205 is missing from the board and we add a gsm module that we know is not locked and add the r1205' then I think that iTunes will ask for imei of the module and not the serial? If anyone know will be nice |
