03-12-2011, 21:11 | #16 (permalink) | |
Freak Poster Join Date: Mar 2008 Location: india
Member: 723178 Status: Offline Thanks Meter: 37 | Quote:
how much does it cost??? this same with any iphone or no | |
03-16-2011, 19:38 | #17 (permalink) |
Junior Member Join Date: Mar 2011
Member: 1537906 Status: Offline Sonork: [email protected] Thanks Meter: 0 | bonjour, mon iphone ne s'allume pas, mais une fois sur le chargeur il donne des flache sur l'écran et une ligne horizontale. et quand j’enlève la batterie et je le met sur le chargeur il s'allume ensuite s’éteint. est t'il possible qu'il soit ce fameux circuit? Hello, My iphone does not ignite, but once on the charger it gives puddle onto the screen and a horizontal line. And when I kidnap the battery(drum kit) and I puts him(it) on the charger he(it) ignites then goes out. Is you he(it) possible whether it is this famous circuit? |
04-04-2011, 11:36 | #21 (permalink) |
Freak Poster Join Date: Sep 2002 Location: K S A Age: 42
Member: 15539 Status: Offline Thanks Meter: 100 | |
05-22-2011, 03:56 | #22 (permalink) |
Junior Member Join Date: Jul 2010
Member: 1354059 Status: Offline Sonork: calecho Thanks Meter: 0 | I think that my phone may have the same defect, this PMIC can be the cause of a dead iphone 3gs no visual damage, no heat problems, no shortcuts, did you fix any iphone 3gs completely dead changing the pmic chip i have reballing skills but don't want to spent money in this chip for nothing. I review all the schematics and connections available, also with a working 3gs and it seems all the voltages and components fine on both iphones but no more life on the damaged iphone. Any help wil be appreciated. Thanks |
06-21-2011, 06:34 | #23 (permalink) | |
Freak Poster Join Date: May 2009
Member: 1037562 Status: Offline Sonork: 100. Thanks Meter: 53 | Quote:
You can find 3Gs Power IC here Best Regards Stuffs for Apple | |
06-23-2011, 12:09 | #25 (permalink) |
Junior Member Join Date: Jun 2011
Member: 1594824 Status: Offline Thanks Meter: 0 | Do you have to press on the IC like in the video from it_repair? I am a bit afraid of this because it could lead to shorts under the IC. I would prefer just heating, but then there is the possibility that some balls wont get no contact. Do you use flux? Last edited by Olivanov; 06-23-2011 at 12:17. |
08-09-2011, 18:54 | #28 (permalink) |
No Life Poster Join Date: Jan 2005 Location: the earth Age: 41
Member: 103024 Status: Offline Thanks Meter: 616 | hi sr i just buy some pmics from aliexpress , the pmic lokks ok , process here 1.- reball ic 2.- mount on the pcb all its ok no broken points and pmic reballed ok , but i faced this problem on 3 iphone 3gs after install new pmic , phone charge ok, power on, but touch screen not work at all, also i cant enter in recovery mode, the phone its 100% recognized my itunes , what am i doing wrong sr, can you help me the main problem is the touch screen !!! and is comming from pmic i read are versions of pmic diference |
08-18-2011, 01:27 | #29 (permalink) |
Junior Member Join Date: Aug 2011
Member: 1637320 Status: Offline Thanks Meter: 0 | My Iphone 3gs is dead Hi I have seen your post, replacing the Power IC, it is great work, I have used my local power adapter to charge my iphone 3gs, suddenly its switched off and it is not responding and it is completely dead. Can you guide me what was the wrong with it. |
08-18-2011, 19:16 | #30 (permalink) | |
Member: 1637320 Status: Offline Thanks Meter: 0 | Quote:
Thanks in advance. | |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
