Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 06-17-2012, 13:06   #16 (permalink)
Member: 1773155
4S No Network
I have a 4S which was working perfectly with Gevey on 5.0.1.
SOme JB app resulted in Sprinboard Loop even after reboot, so I had to update to 5.1.1. After Restore, I paid and got it factory unclocked too. but now there is no network. Keeps shuffling between "No Service" and "Searching". Replaced Network Antenna, but no luck. Does this mean I have to replace the Network IC? Can anyone guide me how I get this done in India?
The Following User Says Thank You to niceguy1430 For This Useful Post:
Old 06-23-2012, 09:38   #17 (permalink)
Member: 79221
Thanks Meter: 8
hello,
I have the same pb but I need to buy this component.
Who can say me what's name or where I can find it.
I have test to dissoldering on other iphone 4 but is very very small and I have loose the component.
It the first time, I test to soldering a very small component on circuit board.
Thanks for advance I wait about your advices
I haven't find solution, who can help me?
thanks
Old 10-10-2012, 12:15   #18 (permalink)
Member: 1821339
Hi There, same issue here. iPhone 4 with no Service, blue inductor coil is missing. is there a problem if i do shorting the connect pads with connectives silver or i have to by this part?
thanks for your advices.
cheers gaendalf
Old 10-10-2012, 12:53   #19 (permalink)
Member: 1012778
Thanks Meter: 245
you can make a bridge! ....but the coil is better....but you don't see a difference in function!
Old 10-10-2012, 19:47   #20 (permalink)
Registered User
Member: 1125280
Thanks Meter: 273
brother change U11_rf ic ill try this solution its work for me ....searching after no service
Old 10-12-2012, 08:26   #21 (permalink)
Member: 1821339
@kostele
hi, can u plz explain to me what does the coil do?
as i think this is an inductor and is plaing wicthcapacity of GSN Antena for a littlbit amplicance of Signal by certain frequnces as resonance curquit. am i right?
sorry my english
cu gaendalf
Sent from my iPod touch using Tapatalk
Old 10-15-2012, 20:31   #22 (permalink)
Member: 1766383
Thanks Meter: 4
no signl no wfi work no signal any shulation i phon4
Old 10-17-2012, 19:30   #23 (permalink)
Member: 1824251
After shorting out the connections where the Blue coil was I have service once again, but no 3G service.
Anyone else have this problem?
Old 10-17-2012, 21:31   #24 (permalink)
dog68's Avatar
Member: 1728699
Thanks Meter: 212
This is antenna switch, and/or skyworks ic.
The Following User Says Thank You to dog68 For This Useful Post:
Old 10-17-2012, 21:43   #25 (permalink)
Member: 1824251
Thanks,
But should it stop my 3G connection from working and only let me use the 2G network?
Old 10-18-2012, 15:53   #26 (permalink)
Member: 1816956
Sonork: alisa
I have a problem with the iphone 4s. imei is not detected for help in hardware solution
Old 10-21-2012, 15:17   #27 (permalink)
Member: 1766383
Thanks Meter: 4
Originally Posted by bader1988 View Post
ya man i'm sure
i change the antenna and i make software same thing
i think the ntwrk ic need to replace
can any one show me where is the ntwrk ic plzzzzzzzzz
yasir i phone.jpg chk it bro and reply mostly use this akt problims solws..
Old 01-01-2013, 20:38   #28 (permalink)
Member: 1367373
Sonork: 5678
Thanks Meter: 2
iphone no service only searching...................1000000000000000000000 %%%%%%%%%%%% %%%%%%%%%
solution
[IMG][IMG]http://http://www.google.com.sa/imgres?q=iphone+no+service&um=1&hl=en&safe=active& sa=N&tbo=d&biw=1024&bih=653&tbm=isch&tbnid=MKDkYCj hJAjZKM:&imgrefurl=http://chiastedduonlai.********.com/2012/10/problemi-in-citta-per-chi-ha-vodafon-il.html&docid=o7Sx695JbBqhDM&*****l=http://www.altafsayani.com/wp-content/uploads/2009/10/iphone-no-service-message.gif&w=270&h=229&ei=YDnjUNDOOsPl4QSKroGwDw& zoom=1&iact=hc&vpx=767&vpy=131&dur=2783&hovh=183&h ovw=216&tx=112&ty=122&sig=109012196647071907955&pa ge=1&tbnh=136&tbnw=158&start=0&ndsp=20&ved=1t:429, r:4,s:0,i:96[/IMG][/IMG]
conect itunes then reset netwoark setting ..............................
Old 02-06-2013, 23:27   #29 (permalink)
Member: 295092
Thanks Meter: 5
I have a similar problem, Rubbish signal but mostly No Service /Searching, Is it a hardware fault?
Old 02-07-2013, 01:16   #30 (permalink)
Member: 295092
Thanks Meter: 5
"UPDATE" I found my problem, It was so easy too = iPhone 4 4S Poor Cellular Signal Fix - YouTube
Hope it helps
The Following User Says Thank You to T1Cybernetic For This Useful Post:
IR between 6150 and IBM TP 600 favdijck Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 11-15-2011 13:08
wt603 and .pkd ARt Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 06-13-1999 19:18
Page generated in 0.17889 seconds with 10 queries
